Question about Dishwashers
Error code "intensive light flicker fleetly
The intensive light keeps flashing and you can hearthe pump run but it does not stop and does not reset. new wash will not start
SOURCE: dishwasher error codes please help
I too had this problen today. Printed off a manual from the Hotpoint website. Very helpful troubleshoot section. Anyway, flashing eco and fast lights and beeping sound indicates 'water feed pipe blocked' You need to check the water inlet connections on your tap.However, when we pulled it out we noticed the blue water inlet pipe was slightly kinked. Straightened this out and hey presto! It works fine again. How this happens when its worked ok for 18 months will never know but still. Try it! hope this was helpful...shewoo
Posted on Jul 21, 2007
SOURCE: Whirlpool ADP951 Dishwasher
Processor board sound bad. May be a loose plug ( or corroded connection on the plug ) . Unplug the dish washer from the wall plug before servicing. The open the front panel to expose the panel control board. Unplug the panel plugs and inspect them to assure no corrotion is apparent. If you see corrotion, use a pencil erracer to clean all contact points on the board and clean the plug the best possible. Plug the dishwasher plug back in the wall and check the unit for proper operation. If the operation is not correct, replace the circuit board. I hope this helps
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 06, 2008
  • 172 Answers
SOURCE: KENMORE ELITE DISHWASHER - MULTI-LIGHTS FLASHING
Look at your manual, usually available on net for reading or downloading. Blink lights are often used to code out a problem with various combinations and repetition rates to indicate trouble code number for look-up in manual.
Posted on Feb 22, 2009
SOURCE: asko 1605 cycle stopped, pump keeps running
Thanks my Asko did the same and tilted it forward, drained excess on the floor, even though I thought i'd bailed the whole lot and woolaa fixed - thanks x
Posted on Feb 28, 2011
kel1guy2002
  • 3740 Answers
SOURCE: keeps flashing pf while not
Flashing PF = power failure. The power source and connections need to be inspected for bening loose or hot. This would be at the wall connection and in the bottom of the dishwasher. If the supply power source is good all the way to the dishwaher and to the dishwasher control.. suspect corrosion in the control area as the source of the problem. When corrosion gets on an electronic board it starts acting like a conductor for the low voltages produced by the PDB transformer which starts causing all kinds of weird symptoms. If the PCB can be cleaned carefully you can maybe get 6 months to a year out of a PCB that has / had corrosion problems. My 40 years experience is that only one in 5 can be salvaged back into service. Additionally those that are placed bacm in service eventually have other problems.
If you have a loose plug, wires, outlet or power cord... your in luck.
Thanks for choosing FixYa,
Kelly
Posted on May 29, 2011
Testimonial: "Sounds good. Definitely water damage. time to buy a new dishwasher!"
When I on the machine LG WF-F5700PCX ,all the lights are blinking. water is not flowing in.
Washing machine all the lights flashing, error codes on ...
www.how-to-repair.com/.../washing-machine-with-all-the-lights-flashing...
Oct 25, 2014 - In this video I'll be showing how to fix a washing machine with all the lights flashing and how to identify error codes or fault codes on Hotpoint, ...
Washing machine lights flashing - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - Flashing lights Many modern washing machines display error codes if they detect a fault, but they don't all display a readable error code.
Flashing Lights on Washing Machine How to Repair ...
? 8:05
https://www.youtube.com/watch?v=P6WZNLO6wE4
Oct 22, 2014 - Uploaded by how-2-repair.com
Flashing Lights on Washing Machine How to Repair Hotpoint, Ariston, ... flashing like this.error faults are available at our website for all makes.
Indesit Washing Machine Repair: Flickering Or Flashing Lights
? 4:36
https://www.youtube.com/watch?v=S1L2N7srXKs
Mar 27, 2014 - Uploaded by DextersLab2013
Indesit Washing Machine Repair: Flickering Or Flashing Lights... Since making this video i have had to replace all of the remaining capacitors ...
Jan 11, 2016 | Washing Machines
Need to do a reset on a gw612 after changing the cold valve
There is no reset for these.
If you are getting error code 48,49,50
your motor controller board is faulty.
Feb 21, 2014 | Fisher and Paykel Fisher & Paykel Washer
Samsung DMT - 400 delicate light blinking
please follow this steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 09, 2013 | Dishwashers
The panel is stuck on pots/pans for cleaning and wont let me run the dishwasher. the pots/pans light keeps flashing
To reset the dishwasher push in this order the,
HIGH TEMP WASH- HEATED DRY- HIGH TEMP WASH- HEATED DRY - CANCEL/OFF
the control will be reset...but more importantly how many times in a row does the light flash..it will indicate what error code its displaying??
example if it flashes 4 times then a pause then flashes 4 times again its displaying the error code#4
7 flashes then pause then 7 flashes its displaying the error code#7 ect ect
GENE
Sep 06, 2011 | Whirlpool 24 in. DU1055XTPS Stainless...
I just bought a 2008 Suzuki B-King and it keeps flashing the fi code and the fi light is on. It has aftermarket exhaust on it, how do I stop it from flashing because it wont let me see the trip meter at...
Take it to the shop and have them read the error code. The flashing is an error code and wont stop till you fix the problem or shop resets the code for you... That is my experiences with these issues....
I hope that this helps you and please do not forget to rate/vote and place a testimonial on my advice.
Wicked Angel
Nov 19, 2010 | 2008 Suzuki B-king
Check engine light is on
Call first, but I think all of the chain auto parts stores will still do a free scan of your computer and the error code read out should give you and idea of the source of the problem. The error memory can also be reset which sometimes is all that is needed since problems can be related to a momentary glitch in the electronics. Since we are remote from such services, we bought our own scanner from Harbor Freight during a sale and of our family 'fleet,' only one 1987 toy (summer) car is immune from scanning.
Sep 06, 2010 | 1999 Jeep Grand Cherokee
My Kenmore Elite keeps flashing LD after I start to wash. Then the machine stops washing. Clothes are not wet, but I heard water going into the machine. How can i fix this?
“F21” (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jul 27, 2009 | Kenmore Washing Machines
Gaggenau dishwasher keeps running
press the intensive and crystal buttons @ the same time, the display will change to 0. Close the door the pump will run for a while when the pump stops the dishwasher is reset.
May 26, 2008 | Gaggenau GI936-760 Dishwasher
Dishwashers Logo
Top Dishwashers Experts
