Question about Motorola Mobility Droid Razr
How do you connect a motorola razr to a car's Blue and Me?
  • Brad Brown Feb 13, 2012
    Depends on the car
Blue screen, says Bootloader USB Init at bottom, won't restart with power key
1.go to http://www.modmymobile.com
2.download p2ktools zip file
3.extract zip file
4.down firmware for motorola razr v3 zip file
5.extract razr v3 zip file
6.open p2ktools extracted folder open p2ktools exe file
7.read help how to flash your motorola razr v3
Aug 24, 2011 | Motorola Mobility RAZR V3
Have blk moto razr v3a cell phone. when connected
down load motorola phone tools from www.modmymoto.com the proper drivers will load and youll be fine
Mar 02, 2010 | Motorola Mobility RAZR V3a Cellular Phone
I have the same problem but I can't enter the debug menu using
I have a Motorola RAZR V3x which has worked reliably for about 3 years. Very recently (having been recharged a couple of hours earlier & without any prior suggestion of impending battery failure), the phone has refused to turn on and attempts to charge it with the factory charger do not even light the blue charge indicator. An attempt to charge it through the computer's USB port lit the blue charge indicator for about 1 second but also failed to charge the battery.
Aug 19, 2009 | Motorola Mobility RAZR V3
My Razr phone 'unable to connect' to blackberry 8310 bluetooth
you have to hold down the power icon till it flashes red and blue then its ready to connect, then select your search settings from your razr. it should find it and ask you for a code. its usually 0000
Apr 15, 2009 | Motorola Mobility RAZR V3
Bluetooth will not stay connected on my 2006 BMW z4
Depending how far of a range your getting, between your razr and your blue-tooth is important. Any range of 30ft or over is less likely to connect/search/and or pair with any capable blue-tooth device.
Try pair the two devices again, but remember to save the trusted blue-tooth to your device so that disconnection can be prevented only by your command.
If your blue-tooth has a short, or battery is extremely low then that TOO can cause disconnection.
Hope this information can be of a benefit to you. Thanks.
Mar 16, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Downloading pictures from Razr v3 cell phone
just connect data cable and transfer pictures from pc to mobile
Jun 14, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Razr v3 display
This will probably be your bluetooth connection, you can turn it off in connections.
Feb 22, 2007 | Motorola Mobility RAZR V3
Blue light on outside display 1/2 on.
The blue light indicates that BlueTooth is powered on. On my phone it flashes. You can turn it off by going to Settings - Connection - Bluetooth Link - Set up - Power. Select and change to Off.
Feb 10, 2007 | Motorola Mobility RAZR V3
Motorola Mobility Droid Razr Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
