Question about Konica Minolta Laser Printer
.. i need simulation and how to solve this error c-2201 please solve it
Need simulation this machine
My machine sharp MX 3100N is giving the error code U2-05, what steps should i use to solve it
This error refers to a discrepancy between the HDD & the machine. If the hard drive has not been swapped out & nothing has changed on the machine then try resetting the copier to see if that rectifies it.
To reset the machine you will need to enter simulation mode.
First, make sure the copier is in COPY mode.
Then press the following 4 keys in quick succession: # * C *
You should then have a screen showing simulation mode.
Then enter 16 & press either of the copy keys (black or colour).
This should then display U2 ERROR RESET.
Press EXECUTE, YES then press the CA key.
The machine will exit simulation mode & restart.
If after restart the machine displays U2 again then you will probably have a HDD fault. Unfortunately, the HDD would have to be replaced by an authorised dealer as new Firmware would have to be reload to allow the machine to recognise a new HDD.
Hope this helps.
Dave.
Jan 19, 2017 | SHARP MX-3100N
Tip
BlackBerry Error Code
When using the <i>BlackBerry</i> device <i>simulator</i>, you can sometimes meet this Application <b>Error inside JVM</b> Access Violation Reading 0x00000000 when you try to start the simulator. Here's how to solve your problem.<br /> <br /> <b>BlackBerry simulator ERROR</b>:<br /> <br /> <ul> <li><i>Application Error <br /></li></i> <li><i>Error inside JVM: <br /></li></i> <li><i>Access violation reading from 0x00000000</i></li></ul> Open the folder to install the <b>simulator BlackBerry</b> for example: C: \ Program Files \ Research In Motion \ BlackBerry Smartphone 4.6.1 simulators \ 4.6.1.199 (8900) if there is a file called clean.bat use it. Try to open the <b>simulator,</b> and if you get Error inside <i>JVM: Access</i> violation reading from 0x00000000 error again, close to the simulator, open the installation folder again and delete all. DMP files to be installed in the folder and start the mortgage again.<br /> <br /> <b>If this fails, try the following</b>:<br /> <br /> <li>Uninstall the JDE SDK and the BlackBerry Simulator</li> <li>Reboot your PC - do not bypass this step</li> <li>Install JDE SDK and the BlackBerry Simulator</li> <li>Start the Simulator</li>
on Dec 14, 2010 | Cell Phones
My oce fx 2081 trouble code 05 help me pleas
OCE clear error message replace toner oce fx 2081 ... - Fixya
www.fixya.com/tags/clear_error_message_replace...oce_fx_2081/.../oce
Ask your Clear error message replace toner OCE fx 2081 questions. ... ...error code0501 message, though we've vacuumed it the toner as best as possible. ... ...error 2201 switch on/off messages very frequently on my oce 9400 machine, any solution!!! thanks Might be NTC6, which is located in ... 05 is appearing on the.
clear error message replace toner oce fx 2081 Questions ...
www.fixya.com > Forum > Tags
Find solutions to your clear error message replace toner oce fx 2081 question. ... ...error code 0501 message, though we've vacuumed it the toner as best as possible. Well ... ...error 2201 switch on/off messages very frequently on my oce 9400 ...
Sharp ARM 550/620/700 Reset Machine with Error Code ...
Dec 15, 2015 | Office Equipment & Supplies
I have oce tds 100,this machine is showing this error code: 2201 error what could it be please any help
The safety relay is not activated. There may be a problem with the fuser.
Jun 05, 2014 | OCE 3140 Copier
Konica minolta bizhub 363 error message c-2201
remove the toner bottle let machine thur its paces when it says install toner bottle install correctly
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 24, 2012 | Minolta Office Equipment & Supplies
Konica minolta 363 error message c-2201
remove the toner bottle reinstall when machine ask for it.
Sharp ar5516 f2 error
We have bought this machine on Date-28/07/2011 and it is still in warrenty. now already 11,000 copies put it And the now machine shows F2 indication after starting and the company not repairing it. And the after sell service of company is not good.We tell the company to change the the machine or repair and they neither repairing it nor changing the part.
I request you to solve my problem please.
Nov 14, 2011 | Office Equipment & Supplies
Sharp AR275 copier error message received is "call for service u2-40" please what can i do to solve the problem?
in order press
* Entering the simulation mode
1) #/P key (program) ON → Asterisk (*) key ON → CLEAR key ON →
Asterisk (*) key ON → Ready for input of a main code of simulation
Simply # * C * and the machine will enter simulation mode.
Then enter the number 16, which is U2 code correction, follow what the screen says, Normally just press start and the machine will reset.
U2 codes are software glitches. A U2 40 is a CRUM fault which is a drum or toner chip problem.
Sim 16 almost always clears them.
May 19, 2011 | Sharp AR-275 Copier
I am In possession of South western Bell Freedom
Here is a direct link to all Southwestern Bell's products - Manuals - and Accessories!
http://www.swbfreedomphone.com
The phone number for their product support is
1-800-366-0937
they are open M-F 8:30AM - 9:00PM EST and
Sat 8:30AM - 12:30PM EST
Thanks
Len
Need more help? Just ask! We'll dig further!
Mar 08, 2009 | Southwestern Bell Lands Phones
KM 1505 copier machine
click cancel+start+light then release all then press cancel.... you are now in simulation control service..... press the zoom in and out so that it will display 163.... after displaying 163 press start... the machine will restart then the code will lost.. if it return there is machine problem somewhere in the fusing unit....
Dec 20, 2007 | Kyocera KM-1505 Copier
Konica Minolta Laser Printer Logo
78 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
