The fax machine get wet - Office Equipment & Supplies
Black lines appear on documents faxed
Black lines generally mean a dirty glass plate. Clean the glass with a dry cloth and try again. If this doesn't work use something like a 'wet-wipe' and lots of elbow grease. The glass may look clean but it just takes a bit of dirt that you can't see to make the lines appear. This solution applies to all faxes/scanners.
Jan 13, 2014 | Ricoh 3310LE Plain Paper Laser Fax
Paper wont feed from drawer
clean the pickup roller with wet cloth
Oct 13, 2010 | Brother IntelliFax-2820 Laser Fax
FAX not used for a long time. How do you clean
in the main menu it should have a clean ink jets function if not take them out and soak them for 5 secs on there ink oulet section on a wet towel to loosen up dried ink
May 13, 2010 | Sharp INKJET FAX UX-A1000
Reciveing a papeer jam ussually on any fax with a
Try to clean the pick ADF with a piece of soft cloth wet with alcohol
Apr 06, 2010 | Brother IntelliFAX 4100 Laser Fax
Unwanted verticle line on fax copies
Most likely a fax has been sent or a page copied with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, scanning or sending a fax, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page. If this is the cause you will also find that faxes you send to other people will also have this line (although faxes you receive are not affected by this problem with your machine).
To fix the problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Feb 22, 2010 | Brother IntelliFAX 560 Plain Paper Fax
I have a black line showing up on my faxed documents. I have opened it up, changed the film and re- set it, but the problem persists. The machine is about 5 years old.
If this is your problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Feb 07, 2010 | Brother IntelliFAX 775 Plain Paper Thermal...
Black lines down the side on the fax
hmmm...can you try clean the carrier and cartridge nozzles of your cartridge ..
first open the front cover of your printer in order to reach the carrier and cartridge then clean the carrier by a wet cloth and wipe also the cartridge nozzles on a clean wet cloth .
thanks.
pls rate if it work.
Nov 30, 2009 | Office Equipment & Supplies
Cannon Fax Machine Paper jams when fax in use
Clean feed rollers with a wet clean cloth.
Nov 26, 2009 | Office Equipment & Supplies
Upon incoming message, multiple sheets of paper
Switch the machine off,remove the document and plain paper tray,at the intake of the plain paper parth there is two gray rollers,Clean them with a strong soap sullution,just make sure the main board dont get wet.
Nov 19, 2009 | Canon FAXPHONE B640 Plain Paper Bubblejet
Cartridge problems
PICK UP THE FRONT COVER YOU WILL SEE THE DRUN AND THE TONER CART THERE TAKE THE CARTRIDGE OUT AND GET A REPLACEMENT AT STAPLES OFFICE DEPOT AND MAKE SURE IT IS A OEM REPLACEMENT GOOD LUCK BROTHER SR TECH
Dec 28, 2008 | Brother IntelliFAX 560 Plain Paper Fax
15 people viewed this question
jasbo
jasbo
