Question about Acer Computers & Internet
MY WINLOCKER MY WIN LOCKER OPENS BUT DOES NOT SHOW ANT DRIVES
My seagate 1Tb is actin strange.. when i try to explore it, it shows it's empty but when i check it through properties.. i have all my files hidden to it.. all my files got invisible.. please help..
Win 7 - open the drive on the computer, click the "organize" drop down menu on the left - go to "folder and search options" - select the second tab (view) - select "show hidden files, folder, and drives" - Hit apply then ok - all of your files should be visible now - select all files by hitting "CTRl" + "A" - right click on one of the files and select properties - uncheck hidden - when/if another window opens select the best option for you - now all your folders should be visible again - you can repeat the first few steps to make your hidden files invisible again if you wish.
Oct 15, 2013 | Computers & Internet
Tip
Did you know? The Windows key can be used for these tricks inside Windows 10!
Did you know you can use the following Windows key shortcuts inside of Windows 10 to do stuff?
Win+D = Show Desktop, hint: try tapping again!
Win+L = Lock's the account, this will take you back to the login screen!
Win+Tab = Takes you to a new layout similar to Alt+Tab. This new version is where you can hit the (+) symbol to generate a new desktop. Try it out! You can then Win+Tab between desktops (and Alt+Tab inside of them!)
Win+P = Projection, is a quick function that lets you select monitor outputs rapidly.
Win+M = Minimize all windows. Hide your gaming habits with this one!
Win+X = Same thing as right clicking your start button! Use this to rapidly access most of your core features inside of Windows 10. Control panel, task manager, system information, apps and features (formely add & remove programs)... It's all there!
Win+R = Opens the 'Run' command directly.
Hope some of these help, good luck!
on Jan 05, 2018 | Miscellaneous
Kindle fire hd lockscreen
Prerequisites:
1. Kindle Fire HD 7", Kindle Fire HD 8.9" or Kindle Fire 2
2. Rooted Kindle: http://forum.xda-developers.com/show....php?t=2069117
3. Google Play: http://forum.xda-developers.com/show....php?t=2069329
Custom Locker Step 1. Using Google Play, search for "No Lock". Download and Install No Lock - You may use this link to verify the software: https://play.google.com/store/apps/d...d.nolock&hl=en
Custom Locker Step 2: DO NOT Open No Lock, it will fail. Next, go to the Kindle, open up ES File Explorer or Root Explorer
Custom Locker Step 3: Be sure to enable Superuser on ES File Explorer. Navigate to /data/app, find org.jaf.androidnolock-1.apk - long press on the APK, select Move or Move To. Next, Move org.jaf.androidnolock-1.apk from /data/app to /system/app.
Custom Locker Step 4: Next find org.jaf.androidnolock-1.apk in /system/app. Long press and Choose Permissions (on Root Explorer) or Properties (on ES File Explorer). Change the Permissions to: Owner: Read Write Group: Read Others: Read - Click OK to apply the Permissions.
Custom Locker Step 5: DO NOT Open No Lock. Pull down the Upper Status Bar, Select More+, Select Sounds & Display and change the Screen Timeout to: Never and then reboot the Kindle.
Custom Locker Step 6: Once the Kindle is back to the desktop, open No Lock which is found in the Kindle Apps, select "Locking disabled".
Custom Locker Step 7: Using Google Play Search for MagicLocker Main which you can find here: https://play.google.com/store/apps/details?id=mobi.lockscreen.magiclocker - Download and Install Magic Locker Main
Custom Locker Step 8: Be sure to enable Superuser on ES File Explorer. Navigate to /data/app, find mobi.lockscreen.magiclocker-1.apk - long press on the APK, select Move or Move To. Next, Move mobi.lockscreen.magiclocker-1.apk from /data/app to /system/app.
Custom Locker Step 9: Next find mobi.lockscreen.magiclocker-1.apk in /system/app. Long press and Choose Permissions (on Root Explorer) or Properties (on ES File Explorer). Change the Permissions to: Owner: Read Write Group: Read Others: Read - Click OK to apply the Permissions.
Custom Locker Step 10: Using Google Play Search for MagicLocker Theme - Download and Install a few Themes that interest you. I use Starry lock screen and Jelly Bean lock screen.
Custom Locker Step 11: Launch MagicLocker Main, click on Next, Next, Next - You will now see a popup, click Next and choose Clear Defaults until it Grays Out, click on the picture of a house (Home Button), you will be asked which Launcher to Use, you choose MagicLocker Main <Select Default>.
Custom Locker Step 12: Launch MagicLocker Main, sometimes you are taken to your regular Launcher App, if this happens repeat Step 11. Select "Lost Robot Music" and click Apply. Next MagicLocker applies the Theme and asks if you would like to Customize it, answer Yes or No depending on your interests. I selected No so we can move on. You can always customize it latter.
Custom Locker Step 13: Next MagicLocker will show you an example of the Theme. Unlock it by pulling down the circle in the Android Picture.
Custom Locker Step 14: Now we need to customize the way MagicLocker reacts when you unlock to the Left which is a Phone Call and when you unlock to the Right which is a SMS Application. Unlock straight down just unlocks the screen.
Custom Locker Step 15: OK, lock the Kindle by depressing the Power Button for 1 brief Second until the screen turns black. Depress the Power Button briefly again, you will see the lock Screen. Unlock to the Right, next you are asked which is your SMS Software, I use Go SMS Pro. Check the Box to "Always use this application". Unlock to the Left, next you are asked which is your Phone Software, I use Google Voice and Groove. Check the Box to "Always use this application".
Custom Locker Step 16: Next, let's install the Themes. Find the name of the Themes you downloaded in Step 8. In this example we picked Starry lock screen and Jelly Bean lock screen. So go into the Apps. Find Starry lock screen, click on Starry lock screen and select "Install this theme". The installer will process and you will be back at the MagicLocker main Theme Menu. Exit MagicLocker, then go to Apps, find Jelly Bean lock screen, click on Starry lock screen and select "Install this theme". The installer will process and you will be back at the MagicLocker main Theme Menu.
Custom Locker Step 17: Now we need to let MagicLocker know what is your Default Launcher, so launch MagicLocker, find Preferred Home Launcher, click on Preferred Home Launcher and select your Launcher, we use Nova Launcher Prime.
Custom Locker Step 18: Let's eliminate the Ads from ever appearing again. Open either ES File Explorer or Root Explorer, navigate to /system/app find the dtcp_apk.ap, long press dtcp_apk.apk select Rename. Rename dtcp_apk.apk to dtcp_apk.old.
Custom Locker Step 19: Reboot the Kindle.
Custom Locker Step 20: Whenever you reboot, the Kindle Fire Framework starts before anything else, so you may see the Kindle lock screen at Reboot IF you do not let everything start. If you can not wait 5 to 10 minutes, unlock it and let all the services start, usually 10 minutes is sufficient. Once you unlock it, you will notice there are no more Ads! After 10 minutes No Lock Service kicks in and disables the Kindle Fire Lock Screen. We have attempted to play with the start-up timing and ended up with Framework missing, so Amazon was smart when they thought out this function. Also, the service that controls the lock screen is part of the same group that displays the Kindle Framework when you unlock it. Finally, if you do wait 10 minutes you will never see the old Kindle Fire Lock Screen!
That is it! Next we will offer you a solution with the stock lock screen but you will need high resolution photos to make it function properly. Be sure to look at our new Backup and Recovery Software for the Kindle Fire Series: http://forum.xda-developers.com/show....php?t=2096888
May 31, 2013 | Amazon Kindle Fire HD
My disk D says me when I try to open it do you want to format? how Ican solve this
u have to install window 7 again in ur pc , If u install window 7 than bit locker again give u option to unlock the disk using password but if u forget ur password of bit locker then it give u another option to open it, and this opition is to fill the recovery key into bit locker if u saved it and it is different to all driver ,if u also do'nt have this than there i s no method to open the hard drive without formatting it
Jan 15, 2013 | Computers & Internet
Locked laptop do not know password
What OS are you having?
You can reference the methods below to reset windows password
On XP you can try this:
Boot computer and press Ctrl+Alt+Delete twice when you See Windows welcome screen / login screen. It'll show classic login box. Now type "Administrator" (without quotes) in username field and leave password field blank, press Enter and you should be able to login Windows.
Now you can reset your account password from "Control Panel -> User Accounts".
On Win 7 or Vista:
Ctrl+Alt+Delete won't work, you have to use some windows password recovery software. I recommend Windows Password Recovery Tool
Jun 19, 2012 | Computers & Internet
How do i install my winlocker back onto my acer?
Sometimes files are stored under old files. Do a search for winlocker and abbey by going to start - search and enter file name.
Dec 11, 2011 | Acer Aspire 5241 5251 5332 5334 5338 5516...
Winlocker
yes u can uninstall it through add and remove programs (it mite ask for a password for removal )
winlocker info //This simple little security device is all that is needed to keep your computer secure whilst you are away from it. Simply type your chosen password in twice, if you type the password in wrong either time you will be alerted to this, then simply click SECURE your computer is now safe. To unlock your computer again simply type your password in again.
Mar 11, 2010 | Acer Aspire 5610-4648 Notebook
Folder Lock Opens empty Locker - Should not be empty.
try usin it on another computer,please scan for viruses
Feb 04, 2010 | Computers & Internet
Computers & Internet Logo
41 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
