Question about Motorola Mobility RAZR V3i Cellular Phone
Razr vc3 thru reachout wireless wont ring
I was fooling around with my phone last nite,but today it rang,cept i kept switching back and forth between speakerphone cause i was driving.now it wont ring but will vibrate
  • 1 more comment
  • Richard Hooper
    Richard Hooper Feb 13, 2012
    still wont ring today ,,,refiferished phone to the disabled,all it will do anyway is text n talk-jailbroke-not a razr at all,,,,,,,,,,,,,,,,,,,,,,,,,,,,,!!!
  • Richard Hooper
    thanks,but i've got enuff sence to check all that 1st,,,!
  • Richard Hooper
    Richard Hooper Feb 14, 2012
    it is jailbroke
I have a verizion cell that wont work or turn on anymore and i have anotherone that works and want to use it how can i getit done
If you would like to replace or update your present Reachout Wireless phone, go to the website, under 'Wireless Phones Replacement', to choose new phone. You will have an option of several products to choose from. You can find out, if the phone comes with bonus minutes, and how many you will receive. If you do not see the cell phones you are looking for, contact the company.
Check to see phone providers in your state.
Reachout Wireless Phones - Upgrade Now Nexus Communications, Inc. Enrollment Support: 1-877-870-9444
Jan 21, 2014 | YouTube Videos
I put my Droid Razr on charger but battery symbol comes on with ? mark. Won't charge or turn on.
1. Turn off your phone when it's not in use. If you're not using your Verizon Wireless Razr, then shut it off. Your battery will last much longer if you regularly do this.
2. Charge your phone less. If you charge your Razr nightly, then your cell phone battery won't last long. Try to charge your phone only a few times a week to extend the battery life.
3. Keep your Bluetooth turned off when you're not using it. Applications, like Bluetooth, are notorious for sucking the power from a cell phone battery.
4. Protect your Razr from extreme temperatures. Your cell phone battery lasts longer if kept at room temperature.
5. Discharge the Razr fully. Before you charge your phone, let it completely die. You can extend the life of the battery by regularly discharging and then fully charging it.
6. Leave the battery in the phone. Keep the Razr battery dry and free of dirt to prolong its life.
Aug 20, 2012 | Motorola Mobility Motorla MOTXT912 DROID...
My reachout wireless phone won't let me dial out or recieve calls.It says [No Service] on the screen.What do i do?
  • Turn your phone off and then turn it back on. If your phone has been disconnected from the network for some reason, this should reconnect it.
  • If "No Service" stays on, you may be in a weak coverage area. Try your call again from another area.
Jul 13, 2011 | Toys
I need to change the phone number on a used motorola razr vc3 because I lost my old phone but the info I have found so far has not worked. does anyone have some solutions? thanks in advance!
You need to contact the service provider and get them to activate you a new phone and give you the proper equipment to program the phone with a new number.
Feb 13, 2011 | Motorola Mobility RAZR V3c Cellular Phone
Sony ericsson w910i
remove Battery and then try again
Oct 05, 2008 | Cell Phones
Razr troubleshooting
none of the keys work and key pad is not locked. Recieved phone last night worked fine. Today I can only answer calls and only by flipping phone open.
Nov 22, 2007 | Motorola Mobility RAZR V3
Verizon VC3 shut itself off
the date/time needed to be set is normal especially if it took you a longer time to put a battery back again. if you are having problems with the phone that is not charging and it's not with your charger or with the battery, ou are having problems with the phone. However, if this had been in contact with liquid like water or sweat, this can cause liquid damage on the phone. check if the the tiny round sticker at the back of the phone if it is white.
Aug 13, 2007 | Motorola Mobility RAZR V3c Cellular Phone
PHONE WILL NOT POWER ON
Some phones like to lock up suddenly for no reason. Try removing the battery and leave it out for about 10 seconds then reinstall it. This idea has cleared up many problems.
Apr 27, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3i Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
