Question about Gateway GM5472 PC Desktop
Heat censor gone bad
I don't know if it has completely went bad, I pulled the card that held the s-video and blew it out and blew out the CPU. so i get ready to put it back together , I put it in exactly as I took it out and I have did this before to other CPU i had, But this time i hook it up and turn on the switch, But just the fan motor on high. No blue light where its suppose to light up when it turns on or nothing on the monitor,I made sure that the heat censor was tight by just pushing over the thumb part that tighten it with. Do you think the some of those little pins got bent when i wiggled the censor, O maybe i just unplugged something that I wasn't suppose to. Please let me Know? It was my neighbors.
bizzyb0t
  • 26 Answers
SOURCE: Bent CPU Pins
Line them up in the light. Pins should be evenly spaced in BOTH directions. Look at the pins at eye level and try to line them up straight very carefully, using tweezers gently nudging individual pins. Those pins are VERY fragile and if you bend them too much they'll break. Try to very gently slightly wiggle the CPU into the motherboard without pushing down. Make sure it is lined up with the orientation marker before trying this. Good luck!
Posted on Oct 12, 2007
shakydogg
  • 17 Answers
SOURCE: GT5032 W/XP Media Edition
Try unplugging and opening the PC and removing the mainboard battery. *It's about the size of a quarter, a little thicker though" Hit the power button about 5 times. (Mind you this will reset ther board to factory settings and you will have to go into set-up and set the time back) plug the pc back up and you may be in buisness.
Hope this helps!
Posted on Jul 03, 2008
  • 916 Answers
SOURCE: Fan is running, power button with blue light is off, cpu won't boot up
Your cpu might have died. As the computer is starting tap F8 and choose last known good configuration to see if you can get it started.
Posted on Apr 26, 2009
joerobby1822
  • 6 Answers
SOURCE: Cannot get new Motherboard to boot up in Normal Mode
what u may have done is wwhen u were installing the new board, gave a static shock to the system...that will cause only the fans to come on and nothing more...this is a bad problem bc u cannot fix it...if u figure out something else is wrong, and it gets fixed, let me know
Posted on Jun 20, 2009
lsteward68
  • 331 Answers
SOURCE: Gateway 5056 Media center doesn't boot everytime.
did you look on gateways website for a bios update. the firmware on your motherboard maybe corrupt. go here and check since I dont have your serial number... gateway has a java based scanner that might be able to repair it for you
http://support.gateway.com/support/drivers/dlcenter.asp
please rank me if you can
Posted on Jun 22, 2009
Shuts off and reboots then shut off in the middle of reboot.
these posts are endless here, truely
had to google it ah a DESKTOP
old Pentium 4 processor
circa 2003 , tiny HDD, and memory. old, Goodwill has 1000s parked.
well it can be many things,
did you remove all the cards first, (yes all)
does that hold up power? now?
it will beep, like that, if video car is pulled
and then pull memory, and it will give the ram missing beep codes
all this is covered in the great HP service books.,
beep codes and all
the power switch can be bad or the line cord. to wall. bad.
the power switch unplugs and you can short its 2 pins
to turn on PC< hold up now>?
hold up, means stay running,
you can strip it down, to just mobo and PSU
sure can,.
the CPU can overheat, sure can. and can be checked.
cpu fan works so is not that. im sure. and new thermal grease.
data sheet shows. (pull it,?)
nVidia GeForce4
GeForce4 MX
MX
440 440 AGP
AGP 8x
8x graphics
graphics card
card
Mar 12, 2017 | HP Pavilion A250n (DF253A#ABA) PC Desktop
Hi, I have a newly installed desktop with Biostar A770E3 motherboard, AMD Phenom II X 4 945 3.0 GHz CPU, XFX GeForce 8600GT video card and Logisys case with 480W power supply. And Corsair 4GB X2 DDR3 RAM....
if you have a different video card try that, seems like the fan should spin on the video card. or pull the video card then reinstall see if that makes a difference beeps or something
Apr 20, 2017 | Biostar A770E3 AM3 AMD 770 ATX AMD...
I need a fuses for my durabrand home theater system and model is ht-3916. i went to radio shack and purchase a fuse 1.6 amp volt fuses and it still don't work can you please help me thank you
Do you mean it blew them again or that it didn't work and the fuse is still intact?
If it blew it again the problem is not the fuses. Instead what you have is a semi-conductor device that has developed a short and that is blowing the fuse. Check any devices in the power supply section, look for signs of damage or heat and also any devices on the heat-sink.
If the fuse did not go and it still doesn't work check the power supply only or the on-off switch.
May 24, 2011 | Durabrand HT-3915 System
I have an HP pavilion dv9540us laptop that is having screen issues. I can only get the screen to work randomly...and then only for a few minutes. If i restart the computer it goes completly black or has...
I had the same problem on a dv9000 as well.
Did you use the laptop much on the couch/beds etc? (So the temperature went up)? My video chip became "unsoldered" by a manufacturing fault.
If above is the case, please contact your local dealer.
If not, Please try updating your videocard driver (try using save mode with networking if Windows doesn't want to startup the regular way anymore) The drivers are on HP's website, here : support.hp.com
May 09, 2011 | HP Pavilion dv9540US PC Notebook
I have a cisnet c133-s33. I have no signal to the monitor.Pluged monitor into another computer and it works.I install a Diablotek varx-8p ati rage xl 8mb video card but still have no signal.Do I need to...
You can try clearing the BIOS & if you don't know how, don't do it!! I doubt it would help anyway. That's an old, off brand pc, good chance the motherboard is bad.
Apr 29, 2011 | Computers & Internet
Computer on, but no video output
sounds more like your motherboard,
unplug everything so all you have is ram (1 piece), cpu + harddrive(essential parts) no sound card, use on board graphics if you have it and if no luck then more likely the motherboard. Ihad a works machine go down before christmas with the same symptons and the problem was the motherboard
hope this helps
Apr 01, 2009 | ASUS P4V8X-MX Motherboard
CPU Failure?
Try a different video card. Usually this problem is a defective or video card that has gone bad.
Dec 20, 2008 | Computers & Internet
Dell dimension 4700 video card upgrade problem
Be careful with this computer. The cooling system works by blowing air INTO the machine over the cpu then the heat slowly comes out of the holes on the side panel (on the left side of the machine). One reason the text may be blurry is because the video card is heating up too much. This problem is specific to this machine. Most computers have the cooling fan blowing the heat out of the case and not sucking air into the case. On the plus side at least this PC is near silent right? I would know since I own this machine. Amazingly silent it is.
Apr 22, 2008 | Dell Dimension 4700 PC Desktop
Shutdown
There could be any number of reasons for this to happen. However, the most likey reason - assuming that it runs for a bit, and then shuts down - is that the heatsink/fan on the CPU is not working, or not installed properly. Once the CPU heats up to a certain point, it will shut down to prevent damage. Perhaps the CPU fan as gone bad, or is completely clogged with dust.
Feb 03, 2008 | Computers & Internet
Problems after Power Management changes
Experience a similar problem with a FIC MB. I cleared CMOS then removed MB battery for 1 hour. Restarted the unit with just the video card and hard drive installed. After unit rebooted I added sound card, network card, etc.
Jan 06, 2008 | FIC P4M-915PD1 Motherboard
Gateway GM5472 PC Desktop Logo
35 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
