Question about HP LaserJet 8150dn Printer
Hp laserjet 8150 Tray 3 empty error how can i fix it?
4 Suggested Answers
  • 81 Answers
SOURCE: hp laserjet 8150 printer jams from tray 3
I would recommend replacing the PIU paper Input unit on the printer.Having repaired several hundreds of these printers this always rectifies these feed proble. The clutches can go weak as can the paper tray lift mechanics
Posted on Oct 13, 2009
  • 83 Answers
SOURCE: hp laserjet 8150. i have a problem, tray 3 empty,
CAUSE: This error message indicates the paper present sensor flag in one of the trays does not detect paper in the tray. This could be caused by one of the following:
  • A broken sensor flag
  • The tray paper guides being set too close and restricting the paper from being pulled
  • The tray is not lifting
SOLUTION: Follow the steps below to determine the cause of a false TRAY X EMPTY message. Tray 2 empty
  1. Verify there is paper in the tray.
  2. Open the duplex unit access door just above Tray 2 on the front of the printer.
  3. Check the black-paper present flag by looking in through the duplex access door.
  4. Open and close Tray 2 and observe the tray lifting looking through the duplex unit access door.
The tray lifts but the error is still present
  1. Inspect the paper present flag on the PIU located just behind the pickup rollers. Ensure the flags are present and not damaged.
  2. Remove the tray guides from the tray and reseat them. Ensure the guides are seated correctly and are in the correct slot for the size paper in the tray. Add paper to the tray and try printing again.
  3. Try another known good tray, if available.
The tray does not lift and the error is still present
  1. Remove the tray, remove the paper in the tray, and inspect the lifting plate in the tray for damage. Ensure it will lift freely by hand.
  2. Try another known good tray if available.
Tray 3 empty
  2. Remove Tray 2.
  3. Open and close Tray 3 and verify it lifts by observing through the Tray 2 cavity.
  3. Try another known good tray if available.
Tray 4 empty
  2. Open Tray 4 and check for an extra **** of paper stored on the left side of the tray. This can cause the tray to stall while lifting and result in a tray empty message.
  3. Defeat the interlock in the vertical transfer unit (VTU). Open and close Tray 4 and watch the tray lift through the VTU door on the lower-right side of the printer.
    NOTE: Follow troubleshooting steps for Trays 2 and 3 when working with the 2 X 500 sheet-input tray.
  1. Check the tray guides to ensure the guides are seated corrected and are in the correct slots for the paper size in the tray.
  2. Inspect the paper present sensor for damage.
  3. Check for any broken plastic pieces in the tray that may be a broken sensor flag.
The tray does not lift and the error is still present Defeat the VTU interlock on the right side of Tray 4. Open and close Tray 4 and observe the tray lifting.
Posted on Nov 25, 2009
seeker5211
  • 1089 Answers
SOURCE: Hp Laserjet 8150.
Start by pulling out tray 2 and setting it on the floor. Next take out tray 3 and slide it into tray 2. Print from tray 2. If it works, take the tray on the floor and put it into the tray 3 slot. Print from tray 3. If it fails change the feed rollers.
Posted on Jan 24, 2010
62.0 error
62.XX error
There is a problem with the printer's memory. The x value refers to the location of the problem:
0 = Internal memory
1 to 3 = DIMM slots 1, 2, or 3
Recommended Action
Reseat or replace the specified
DIMM
It might also be the formatter but start with reseating the DIMMs
Dec 04, 2013 | HP LaserJet 8150dn Printer
What Causes an EIO 2 Error 82.0180 on an HP 8150 LaserJet Printer?
Usualy that is an JetDirect card error. Try with another JD card.
May 25, 2012 | HP LaserJet 8150 Printer
Configure HP 4050 printer to prompt 'load paper'
You'll have to change the paper TYPE of tray 3 to a different type as in tray 2.
Jul 28, 2010 | HP LaserJet 4050 Printer
Can not print to Tray 2 on HP 3800 printer. Says Tray is empty
check the paper type and the paper size from the printer menu, if it is ok then you will try to check the paper sensor on tray 2
Jan 08, 2010 | HP LaserJet 3800n Printer
Hp laserjet 8150. i have a problem, tray 3 empty, always but have paper in tray 3
Tray 3 empty
  2. Remove Tray 2.
Tray 4 empty
Nov 25, 2009 | HP LaserJet 8150n Printer
Hp Laserjet 8150. Does not pick up from Tray 3....but the tray does lift
Nov 11, 2009 | HP LaserJet 8150 Printer
HP laserjet 8000 tray 2 not empty
Do you hear the paper "drop" when you pull out the paper tray. If not, it could be a lift motor
You will have to pull the Paper Input Unit to repair it.
Small items are not available for us to purchase.
If you can't fix, you need a new unit. About $400.00
Feb 11, 2009 | HP LaserJet 8000 Printer
Hp laserjet 8100 8150 13.1.42
hp printers typically do not have an error message to cover every known condition, thus if the printer needs maintenance in an undefined area, it will invariably indicate a paper jam. The printer usually responds to the installation of a maintenance kit which will include transfer roller, pickup rollers, and fuser.
Oct 03, 2008 | Office Equipment & Supplies
Tray 3 open or Empty
While tray 3 is detachable, when I remove it from my 2430dtn the printer won't display tray 3 options in any menus, so it looks like your printer recognizes that it is there.
The micro-switches that detect "open drawer" or "no paper" in tray 3 may be malfunctioning or the electrical connector built into the top of tray 3 may need cleaning.
(or, tray 3 may be out of paper <wink>)
Nov 19, 2007 | HP LaserJet 2430dtn Printer
HP LaserJet 8150dn Printer Logo
213 people viewed this question
Seeker5211
Seeker5211
