Question about Bosch Saws
How to change blade
How to remove blade I don't know how
3 Suggested Answers
  • 226 Answers
SOURCE: my two idiotlights don't come on when you turn key on and head lights don't work. have replaced ing. switch with no change
check for a fuse near the engine to tractor wiring connector. check battery cables for looseness & corrosion. tighten the ground cable where it connects to the chassis and inspect the engine to chassis bolts. loose connections can cause backfeed problems, such as when you step on the brake pedal in your car, and can then turn on the radio...
Posted on Dec 20, 2012
drseng
  • 4 Answers
SOURCE: I have a DW402 4.5'' angle grinder and do not know how to remove the blade to install a new one. Could someone help please?
The button on the top of the gearcase is used to lock the shaft only when you are tightening the nut. It is of no use when removing the nut. The DW402 was an early model and made no provision for removing the nut.
Posted on Dec 22, 2014
On top of the head there is a button to press to lock the blade arbor. Press it down and turn the blade by hand until it locks in place. Then you need either a spanner wrench or nut wrench depending on which arbor nut you have. Grinders usually come with whichever wrench they need. Most grinders have an arbor nut with two or four holes and require a spanner wrench with two studs that fit into two of the holes to remove the arbor nut. Some have an arbor nut with a hex fitting, like a regular nut & bot setup, that the arbor wrench fits on. If you don't have the proper wrench sometimes you can get the arbor nut off with a pair of vice grips or pliers. You will want to turn the nut in the same direction as the blade spins when the grinder is on to remove it. When you put the new blade on, get the arbor nut hand tight, it is self tightening and will get tighter as you use the grinder.
Jul 18, 2012 | Dewalt Saws
I have a toyota blade and i want to change the language to english , but don't know how
You can't display English. Bit this site shows what the screens mean. http://au.toyotaownersclub.com/forums/topic/51250-toyota-blade-dashboard-display-japanese-to-english
May 31, 2012 | Toyota Previa Cars & Trucks
Broken blade in dewalt sawzall
Remove broken blade, install new one. These blades don't change themselves, unfortunately.
May 06, 2012 | Dewalt Dw938 18v Reciprocating Saw Sawzall...
Heiniger clippers won't clip
It's likely the tension nut or screw needs to be tightened a little more providing the drive block is in place and the blades have been put on correctly.
You shouldn't need to buy new blades even when they go blunt just send them to a professional sharpener
May 05, 2012 | Health & Beauty
How to change blade arm and plastic blade guard
Don't forget that the bolt that holds the blade against the arbor (the motor hub connection point) is threaded COUNTER-CLOCKWISE. This is the opposite of nearly everything else we encounter. Be sure to use the two wrenches you got with the saw, and like the directions always say, "Unplug unit before servicing!"
Mar 15, 2012 | Saws
I think that I over tightened the lock nut on one side (not using a tort wrench) after changing the mowing blades. I don't think it is cutting now. When I take the blades off from cutting, one blade...
there is a star shaped, or other, pattern on the bottom of the mandrel which fixes it into the blade. this has stripped so the blade is freewheeling on the mandrel. if you cannot remove the blade bolt, I think you are going to have to remove the deck and take it to a fabrication or machine shop to have them remove the blade from the mandrel. then you buy a new mandrel and a new blade, at a small engine repair shop, put it back together. take a picture of the top of the deck before you remove the deck belt so you know how to put it back on after you have the new mandrel bolted in. if it is old you may just want to replace all the mandrels while you are at it. they are less than 50 bucks each.
Aug 24, 2011 | Toro Garden
I have just bought this model second hand, and the blade is fitted upside doen for some reason. How do i change blades?
Hi marill469,
Here is a website where you can download the owner's manual for your saw: http://www.retrevo.com/d/ds/progress?doc=e045b5a9143e1e2ea028b778addd77ca&rk=0.7594880065395843
The instructions for blade insertion and removal are on page 7.
As far as I know, there is no upside down on a recip saw blade. You can use it either way. Upside down allows you to get the blade in tighter spaces due to the shape of the saw.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jul 19, 2011 | Makita JR3050T Recipro Saw 9 Amp
We are having problems looking for the location of the shift solenoid on the 2002 ford explorer. could you email the picture or a diagram of the location of the shift solenoid
Put your trans model into your search engine
& find out where they are
May find a picture,may not
If you know nothing, there is plenty on all
transmissions made for fords for the last 70 years
YOU TUBE is always a good place to go
You can play with that & watch anything
I think you remove the pan to get to them
You don't go changing anything on a wish & hope,
push & poke theory
If you don't know what they do or how to test
them & you won't,go to a trans shop
Jun 12, 2011 | Ford Explorer Cars & Trucks
I can't find the blade lock used to remove my old blade. My model # is sears 315.108230
There should be a small black button on the right side of hand grip. You can also use a small block of wood between the blade teeth and the shoe to hold the blade in place while you loosen the blade nut.
Oct 31, 2010 | Sears Saws
Saws Logo
Top Bosch Saws Experts
Parson's Repair...
Parson's Repair...
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
