Toshiba sd-38vbkb dvd videeo player This is set up to my tv via satellite. The tape will only play for a few seconds. Does not let me choose the channel set up. When put on L1 for channels does not give any sound. Won't let me record.
Benimur
  • 6966 Answers
SOURCE: How to play a DVD on my Toshiba DVD Player
Using the Toshiba's remote, select either Video (1...X, if several) or S-Video depending to what Video INput the DVD was connected to the Toshiba.
Good luck and kind regards.
Posted on Nov 25, 2007
  • 7 Answers
SOURCE: new dvd/vhs player but old tv
The easiest thing to do would be get a new TV plain and simple sounds as if you could use one n e ways. But first make sure you are hooked up through coaxal to the tv that will allow everything to run on channel 3. Let me know your current hookup.
Posted on Dec 25, 2007
  • 13433 Answers
SOURCE: dvd/vcr combo
I'l make sure, but I beleave L1 and L2 are inputs. You need to select the one where the show comes from, Its it coming from the L1 connector or L2.
Your device doesn't have a tuner input jack. To record TV programs on your DVD/VCR, you need to connect this DVD/VCR to an external tuner device (e.g., set top box, cable box or satellite receiver) that has audio/video output jacks.
Il confirm this and reply to you in a moment.
Posted on May 18, 2008
SOURCE: video channel
you can connect this using a set or RWY AV leads connecting your VCR/DVD to one of the TV's AV inputs. This wont require any tuning and most TVs developed in the last 10 years have AV inputs. Then you would just need to put the TV onto the AV channel you have chosen and play the video. Presto you should have a picture.
Posted on Aug 25, 2008
SOURCE: Channel selection
L1 and L2 are just line inputs. This unit does not have a tuner so there are no channels to select.
It requires you to be connected to a TV broadcast via a cable or satellite tuner box... and then would only record what ever channel you were viewing. The DVD is a player only.
It sounds like you should have purchased a DVD Recorder or a DVD/VCR Recorder. The players normally do not have a tuner. A Recorder should have an built-in digital tuner. Some also have the old NTSC tuner and may also have a QAM tuner.
Posted on Dec 10, 2008
Toshiba sd-v295 tunerless DVD VCR Combo To Sony Digital TV Instructions
It will depend on if the Toshiba has an HDMI socket. If it has then the Sony TV will almost certanily have one. Then all you need do is get a HDMI lead and connect the two. The only other way would be via a SCART lead. If the TV has only one SCART and it's being used you can get a SCART Switching Box from places such as Amazon, where you will also get the other cables.
Dec 15, 2012 | Toshiba SD-V295 Tunerless DVD VCR Combo...
Since change over to digital dvd/vcr Toshiba SD-37VB does not record on Video tapes. What do I need to do to correct this or do I need to purchase some additional unit?
Subcribe to cable or satellite tv services.Ur dvd/vcr unit will able to be used to record on VHS tapes again.Because cable or satellite tv services the tv incomming broadcasting tv signal still do broadcasting comming in as analog tv signal for the analog devices as analog devices require as it needed.
Apr 27, 2011 | Toshiba SD37VB DVD Player / VCR Combo
Dvd in player but display says no disk
Check the regional code of the DVD you want to play. It is at the back of the DVD cover. It should be compatible with the regional code which your DVD player can play. If they are not tallying the disc will not be read
Feb 23, 2010 | Toshiba SD-K760 DVD Player
Attempting to play a DVD on a Toshiba player but not able to get full screen picture on TV. Can you help with the problem?
A DVD plays in "Letterbox" format. To have full screen, the TV settings need to be changed to full screen, or zoom. Found in the TV menu of most TV's.
Read ya
Z
Dec 31, 2009 | Toshiba SD-K760 DVD Player
My tape won't play, I just get an
ATR keeps showing on the TV screen when I am trying to play a tape.
Jun 17, 2009 | Toshiba SD-V290 DVD Player/VCR
VCR Issue with Toshiba SD-V295KU
This may be a bit late but I just ran across these posts. All these problems can be caused by bad tapes. Commercially-made tapes will usually play properly. But home recorded tapes, or very worn tapes, may not play back properly in every VCR. If the VCR isn't getting the right information off the tape for proper playback, it's muting the sound and the screen so you don't see any snow. It's also possible that the VCR heads already need a cleaning. It takes just one worn-out or defective tape to clog up the heads and cause the "no picture" problem, although in this case sound isn't usually affected.
Dec 21, 2008 | Toshiba SD-V295
Play dvd nothing - play s/d card (video) sound but no picture.
You need to update the dvd softwear. Check the default settings for playback of media,if it is set to windows media it won't work if you hav'nt installed the correct updates. Choose the Toshiba dvd player as the default player and it should work. If you prefer windows media then you can get the updated codecs from ' free-codecs.com ' Easier still,try uninstalling your windows media player and installing windows media 11, this will usually resolve the problem.
Oct 25, 2008 | Toshiba Satellite A100-S8111TD Notebook
Connecting VCR to TV
Oh man dont shoot your stuff instead use your remote and go to your menu and select your input. You tv is looking at your coaxial input but you can select which input you want. 1, 2 front back whatever you need. channell 3 or 4 has nothing to do with connecting up your dvd if you connect and choose the front connection in your menu.
Oct 21, 2008 | Televison & Video
I have just bought a Toshiba sd-k770kc dvd player and I can't play region 2 dvd's on it as I can't find the region change code for it. Any ideas
- Power ON
- Open Tray
- Enter Cod : 9879 and 0 For All Region Free ( For A Few Seconds In Uper Right Corner Will Appare : { Now Your Region Is Set To " 0 " } Or Some Thing Like That)
- Close Tay
- Power OFF
- Power ON
Try this it should work ok in making this player region free so you can play any dvd's.
Aug 05, 2008 | Toshiba Televison & Video
VCR thinks ALL tapes are write protected.
the record tab detection switch inside the machine is broken
Dec 12, 2007 | Toshiba SD-V392 DVD Player/VCR
Televison & Video Logo
91 people viewed this question
Top Televison & Video Experts
Electro Med Services...
