Question about Air Tools & Compressors
I hit a curb in my 05 dodge stratus on the driver rear tire ummmm and now tire looks loose and tire looks like it wants to come off. what happened what needs to be replaced.
  • 28 Answers
Remove the wheel and take it to a tyre repairer. He will reseat the tyre and inflate it. If the hit was hard enough to do damage to the tyre itself it will have to be replaced.
Posted on Feb 13, 2012
Why is my air pressure low in front but high in back on my 05 town and country
depends on how often you check tire pressures. you could over time be loosing air by it leaking out around the tire bead, or the tires hitting a curb or pot hole that can cause air to leak, a dirty rim may need to be cleaned or someone is keeping the pressures the same that is noted on the decal on the drivers door jam. I trust you have used a good tire gage and not just looking at the tires, as there is more weight on the front tires than the rear and the front will look like they are lower in pressure.
Sep 29, 2014 | Cars & Trucks
Sloppy loose steering
first check the lug nuts... second, jack the vehicle up one wheel at a time move it every possible way while looking for anything behind it that might be loose.
Feb 11, 2014 | Saturn Cars & Trucks
2006 dodge stratus hit curb now tire is pushed back
You may have bent the rim, bent or broken the Control arm, bent the tie rod, or strut.
Nov 11, 2013 | 2006 Dodge Stratus
93 Dodge Spirit hit curb Hit curb on back driver side tire. Nothing wrong with tire but right after I hit the curb, my car started to shake and slow down. It turned off completely when at a stop. Oil...
the smoke came from the spilled oil leaking onto a hot surface ( manifold) No problem there. The oil light coming on was probably from the oil surging away from the oil pickup in the sump momentarily allowed the oil pump to suck air hence a drop in oil pressure. To have all that happen, the hit on the curd was substantial. so I thinking bent axle flange and broken engine mounts could explain vibrations and engine shaking
Jan 07, 2013 | Cars & Trucks
Swaying in rear
Have all the rubber isolator bushing in the control arms check for wear.
Jun 15, 2012 | 2003 Dodge Stratus
Rear passenger side tire is aimed at the front driver side tire
Nothing pulled loose or broken. The upper control arm was warped really bad.
Feb 03, 2009 | 1996 Dodge Stratus
MY CAR HELP
It sounds like you also will need a wheel bearing on that same wheel. ... Thanks Dan
Jul 10, 2008 | 2005 Dodge Stratus
HELP
You have most likely bent a tie rod also.
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
