Question about Princeton Digital VL173 Monitor
Vl173 screen off center
The screen is off to the right about 2 inches and to the bottom about half an inch after doing an auto set in the screens menu \
    Problem Solver:
  • 12 Answers
Sounds like the trouble may be in trusting the auto-set defaults. If you haven't already, try setting the horizontal and vertical settings manually and see if it helps. Those adjustments should be easy to find, and if that will solve the issue, it will be a very simple fix. I hope this helps. -Steve
Posted on Sep 22, 2012
Pt 65 margins
Opening Your Document
Open your Microsoft Word document by double-clicking the Word icon on your desktop. If you do not see the icon on your desktop, then you can locate it where it is buried on your "Start" menu. Click "Start," followed by "All Programs." Then click "Microsoft Office," followed by "Microsoft Office Word." A new document will open on your screen. Click the "Office Button," followed by "Open." Scroll through the files listed, and double-click the one you would like to print. It will open on your screen.
Check Your Margins
By default, your page margins are set to 1-inch margins on the top, bottom, right and left of your page. You can check your margins or change them by clicking "Page Layout," followed by the "Margins" button.
Select New Margins
Select a different margin size, such as "Narrow," which indicate 1/2-inch margins, or "Wide," which indicate one-inch margins on the top and bottom and two-inch margins on the left and right. You also can select "Moderate," which indicate one-inch margins on the top and bottom and 3/4-inch margins on the left and right. Finally, you can select "Mirrored," which indicates one-inch margins for the top, bottom and outside. The inside margins are set at 1 1/4 inches.
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For Brother Printer Support
Apr 20, 2014 | Brother PT-1000 Thermal Label Printer
Panasonic plasma tv th42px8ob 2 inche vertical line showing
do the proper isolation proceedure and try unhooking the Su from the SC board to see if you then get a normal picture all the way across the bottom half of the screen? I am assuming the Vertcal extends extends all the way from top to the bottom of the screen?
Aug 06, 2012 | Panasonic Televison & Video
How do I change margin setrtings foe Lexmark P4350
If you are preparing to print a document that you have created in Microsoft Word, you may be concerned that all the text on the page will print exactly as you see it on your screen. This is not always the case. You can adjust your print margins to ensure that your text prints on each page exactly the way you would like it to appear.
Check Your Margins
Select New Margins
Print Your Page
Print your page. Press "Control" plus the "P" button. The printer dialog menu will come up. Make sure that "All Pages in Range" is selected. Press "OK." If your printer cannot print your new margins, then a new menu will pop up telling you to adjust your margins.
I hope you find it very helpful. Best regards.
Aug 22, 2011 | Lexmark P4350 All-In-One InkJet Printer
We are running a few computers (Dell 2400's, 4700's for the most part) and with the drivers downloaded from Dell's site, the screen shifts about an inch and a half to the left. Clicking auto position...
Go into the monitor menu and try to put the settings back to the factory default. Most video cards will also enable you to adjust screen. I'm sure you've probably attempted to do so, but if not you can right click the desktop and choose properties. In this box there will be an advanced tab where you can adjust settings to. The only other recommendations would be to ensure you have the correct drivers and that your video card is not the problem. Hope this helps.
May 24, 2010 | Dell E228WFP LCD Monitor
My screen is stretched with a 1 and ahalf inch black space on the top and bottom
Most LCD monitors have a couple of control buttons at the top or on the side. Inside the menu, there should be an option called "Auto Adjust" which senses the input signal and resolution, and then shifts the monitor to match it. Have you tried to auto-adjust the screen? There may even be a button called "Auto" on the monitor.
May 13, 2009 | Computers & Internet
Darker fatter letters every 2 inches apart from top to bottom
it is called phase you can attempt to let the lcd monitor auto set or you can disconnect the power over night then plug in and then do not auto set this default usually seems best some times
Nov 29, 2008 | Proview PL926WBi 19" LCD Monitor
Streaks make letters fatter every 2 inches apart across screen
this is called phase it can be set auto by the button or you can disconnect the power and next day reconnect and leave it in default which can be better than letting the monitor try to set the phase.
Display is off-center
Try the Auto adjust button on the monitor buttons first.
If the entire picture of the computer is showing you can try to shift and stretch the picture through the menu button.
Sep 04, 2008 | E-Machines eMachines Monitor E15T4
Toshiba 32 inch tv made1990
yes,you can adjust it by your remote control,find the service menu and from there you can now adjust the vertical from of your tv.
Oct 30, 2007 | Toshiba 32AF43 32" TV
Computers & Internet Logo
121 people viewed this question
Top Princeton Digital Computers & Internet Experts
jairo sanchez
Sunday Ojelabi
Sunday Ojelabi
Daniel Dollive
Daniel Dollive
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
