Question about Welding Tools
Manual for jiali mig 135
135
Porblem with lincoln mig welder 135
Use a voltage tester to make certain you have current at the steel roller assembly that the wire feeds through. Check the diameter of the wire also, to assure contact at the feed rollers.
Mar 18, 2012 | Lincoln Electric Welding Tools
I HAVE A XLT142 WHERE CAN I FIND A MIG GUN FOR IT
Hi:
You can fin a miller M10 or a tweco replacement gun at any welding supply store like: Praxair, there are more than 1000 stores all over the country check your internet for the nearest one to you.
Apr 20, 2011 | Miller MilWeld MLL907263 /AutoArc XLT142...
Have a Hobert handler 135 i can't control the wire feed speed it seems to run wide open.
Sounds like the restate that controls the wire speed is gone. Replace it.
Jan 05, 2011 | Hobart Handler 140 Mig Welder
Lincoln 135 PRO MIG Welder feed stops after a few minutes
1/4" plate with a 135 amp machine is probably beyond it's duty cycle abilites. If you are using a mixed gas, and pushing the max on the settings, it will be cutting out because it is designed to.
You might want to get a higher amperage welder for consistent welding of 1/4"
The 140 Pro maxes out at 5/16" using inner shield wire. and 1/8", or 10 guage with gas.
Mar 19, 2010 | Welding Tools
I have a 135 hobart and the wire feed only works for a short time then it stops
Lots of MIG/MAG units have a Stich and spot facility, these are indicated by Stitch -------- and spot by .......with a timer control numbered 1-10sec make sure that both are switch to off, anti clockwise, These switches are a bit fragile so be a little carefull with them.
Lets know how you get on,,
KEN
Jan 23, 2010 | Hobart Handler 140 Mig Welder
My Lincoln 135 mig welder suddenly doesn't have enough arc to weld. How do I determine the cause?
check the diodes that there not short or open circuit you will need a meter with diode test..
Jun 19, 2009 | Lincoln Welding Tools
What setting do I need to weld aluminum for a 135 miller mig welder?
start slowly turning up the wire feeder,and the amps till you get the sound of bacon crackeling and youll know your there. hope this helps jojogunne
Mar 13, 2009 | Miller Welding Tools
Welding Tools Logo
412 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
