Question about Garden
How to lock shaft to change blade on atom turbo 301 lawn edger
    Sergeant:
  • 316 Answers
Hello, To keep the shaft or trimmer head from turning when trying to remove the bump knob or blade insert a screwdriver in the slot on the other side of the head and remove bump knob or blade,hope this helps,,
Posted on Feb 18, 2012
slohry
  • 87 Answers
SOURCE: how to change an old edger blade
Take a pair of vise grips and clamp the blade to a 2X4 for more leverage. Some old edgers had a left hand thread.
Posted on Apr 09, 2009
electrodynam
  • 35 Answers
SOURCE: Weed Eater ELECTRIC Lawn Edger sseized up. If I
If it is seizing up it is probably not worth fixing,but there is a chance that you just need to change the brushes.You can usually pull these out pretty easially,and have a look at them.If they are all eaten away try replacing them.Again though if it is actually locking the shaft,and pulling the brushes out does not free it up you may have to just toss it.
Posted on Jun 06, 2009
moretons
  • 155 Answers
SOURCE: change the blade
try this site its called pats small engines just look up your model and it will show you a diagram
Posted on Jul 26, 2009
moretons
  • 155 Answers
SOURCE: can't get the nut off.. is there a secret to blade removal
Hi these are usually the opposite way to which the blade turns but you may have to use a rattle gun to remove this. If you have a look at the thread you should be able to determine which way it comes off. Just remember to fix the blade so it wont turn and take your fingers off.
Posted on Aug 04, 2009
backwoodsctr
  • 169 Answers
SOURCE: how to romove a rover lawn edged blade
PLACE A 2X4 ON THE GROUND TO PREVENT THE BLADE FROM TURNING, IF U DONT HAVE ONE I HIGHLY RECOMEND A 3/8 DRIVE IMPACT WRENCH, IT WILL LOOSEN THE NUT/BOLT RIGHT UP WITHOUT SKINNING YOUR KNUCKLES HOPE THIS HELPS!
Posted on Nov 19, 2009
Ariens lawn edger bogs down and stall when the blade is engaged
sounds like you need to return it and get replaced should be warrantied sounds like the bearings are seizing up on the blade shaft .
Jul 26, 2015 | Ariens Wheeled Edger - 986103
Edger blade quit turning
remove and inspect blade for damage. if all is well check flex shaft conection, may have damaged the inner flex shaft or the ends to the flex shaft
Sep 10, 2012 | Craftsman Convertible 25cc Curved Shaft...
Stihl fc 44 edger blade not moving when I press the throttle
check both where the shaft attaches to the motor and also to the guard housing. they sometime vibrate loose and need to slide back in place. also the clutch can wear out.. try the shafts first...
Sep 07, 2012 | Stihl Fc, 36, 40, 44 Trimmer Edger Clutch...
What holds pully on shaft for lawn keeper blade
I have an old model Lawn Keeper gas edger with a 2HP Briggs and Stratton engine. It uses a 30" fan belt to drive the cutting blade and both pulleys have an alllen head set screw holding the pulleys to the shafts. The pulleys are cast aluminum and the set screw and shafts are steel so I find need penetrating oil and heat to loosen the set screw in order to push the drive pulley further on the shaft to make room to replace the drive belt.
May 17, 2012 | Mtd 25B-520D200 CA Gas Lawn Edger
How to change blade on atom turbo 301 lawn edger
hello, To keep the shaft or trimmer head from turning when trying to remove the bump knob or blade insert a screwdriver in the slot on the other side of the head and remove bump knob or blade,hope this helps,~~
Feb 13, 2012 | Garden
How do I change the blade?
hold the blade and screw off the nut holding the blade on the motor shaft
May 28, 2011 | Yard Machines Red Edger
Ryobi 775r edger blade does not turn. Motor runs
Have you made sure the drive shaft cable is tuning and is properly installed and that there is no debris or dirt stopping the blade from turning?
Jun 13, 2009 | Ryobi Garden
Jun 06, 2009 | Garden
How to change an old edger blade
Apr 09, 2009 | Garden
Garden Logo
150 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
