Question about Garden
How to change blade on atom turbo 301 lawn edger
How to change blade
    Sergeant:
  • 316 Answers
Hello, To keep the shaft or trimmer head from turning when trying to remove the bump knob or blade insert a screwdriver in the slot on the other side of the head and remove bump knob or blade,hope this helps,~~
Posted on Feb 18, 2012
moretons
  • 155 Answers
SOURCE: change the blade
try this site its called pats small engines just look up your model and it will show you a diagram
Posted on Jul 26, 2009
slohry
  • 87 Answers
SOURCE: how to change an old edger blade
Take a pair of vise grips and clamp the blade to a 2X4 for more leverage. Some old edgers had a left hand thread.
Posted on Apr 09, 2009
electrodynam
  • 35 Answers
SOURCE: Weed Eater ELECTRIC Lawn Edger sseized up. If I
If it is seizing up it is probably not worth fixing,but there is a chance that you just need to change the brushes.You can usually pull these out pretty easially,and have a look at them.If they are all eaten away try replacing them.Again though if it is actually locking the shaft,and pulling the brushes out does not free it up you may have to just toss it.
Posted on Jun 06, 2009
moretons
  • 155 Answers
SOURCE: can't get the nut off.. is there a secret to blade removal
Hi these are usually the opposite way to which the blade turns but you may have to use a rattle gun to remove this. If you have a look at the thread you should be able to determine which way it comes off. Just remember to fix the blade so it wont turn and take your fingers off.
Posted on Aug 04, 2009
backwoodsctr
  • 169 Answers
SOURCE: how to romove a rover lawn edged blade
PLACE A 2X4 ON THE GROUND TO PREVENT THE BLADE FROM TURNING, IF U DONT HAVE ONE I HIGHLY RECOMEND A 3/8 DRIVE IMPACT WRENCH, IT WILL LOOSEN THE NUT/BOLT RIGHT UP WITHOUT SKINNING YOUR KNUCKLES HOPE THIS HELPS!
Posted on Nov 19, 2009
Ariens lawn edger bogs down and stall when the blade is engaged
sounds like you need to return it and get replaced should be warrantied sounds like the bearings are seizing up on the blade shaft .
Jul 26, 2015 | Ariens Wheeled Edger - 986103
Change an edger blade
Start here to find User's Manual. Sometimes the nut/bolt holding the blade on is a Left Hand thread and requires CW turning to loosen and remove. Not sure on this model.
Aug 12, 2012 | Poulan Pp1000e 7-inch Pro Lawn Edger...
How do I change the blade
The blade bolt is normally 9/16, you will need a good socket and long tommy bar to remove the bolt, an impact wrench will take it out very quickly if you have or can borrow one,
Jun 16, 2012 | Poulan WEED EATER PE550 711431 22CC 2 Cyc...
How to lock shaft to change blade on atom turbo 301 lawn edger
hello, To keep the shaft or trimmer head from turning when trying to remove the bump knob or blade insert a screwdriver in the slot on the other side of the head and remove bump knob or blade,hope this helps,,
Feb 13, 2012 | Garden
How do I change the blade?
hold the blade and screw off the nut holding the blade on the motor shaft
May 28, 2011 | Yard Machines Red Edger
It's impossible to change a blade on a craftman edger. There is no way loosen the bolt holding the blade
Can you grip the blade and hold it still with say a pair of Vise Grips and remove the bolt that way? Lock the grips on the blade and then when it turns will it jam itself against the blade guard allowing removal. What type of bolt actually holds the blade on? Post back with more details.
Aug 16, 2010 | Craftsman Garden
Change the blade
Jun 12, 2009 | Yard Machines Red Edger
Are you supposed to sharpern the blades on the edger occasionally
Hello:
No. Edger Blades are Not Sharpened.
Respectfully
John
May 09, 2009 | Black & Decker Le750 Lawn Edger
How to change an old edger blade
Apr 09, 2009 | Garden
Garden Logo
428 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
