Question about Irwin Miter Saw Laser Guide Attachment 3061001
Batteries for 3061001
Battery
  • 885 Answers
The Irwin laser guides I've worked on take three LR44 button batteries.
Posted on Mar 08, 2012
    Problem Solver:
  • 5 Answers
Posted on Oct 19, 2012
Laser doesn't come on, batteries new
I have the same problem. I have 2 ,1 on each of my daily chop saws. I have had them for about 10 years so I will just buy a new one. For the record a few times I had a wood chips blocking the lens.
Good luck
Nigel.
Apr 09, 2013 | Irwin Miter Saw Laser Guide Attachment...
I need a new battery for my 1986 Oldsmobile ninety-eight regancy sedan. fully loaded. what type of battery would i need?
Attributes Battery BCI # : 75
Battery CA @ 32 Degrees F : 775
Battery CCA @ 0 Degrees F : 630
Battery Height : 7 1/4"
Battery Length : 9 3/4"
Battery Posts Type : Side Post
Battery Reserve Capacity : 90
Battery Voltage : 12 volt
Battery Weight : 33 lbs.
Battery Width : 7"
Wet or Dry : Wet
A lead acid battery with the fallowing specs
group 75
Battery Width : 7"
Wet or Dry : Wet
Battery Width : 7"
Wet or Dry : Wet
Battery BCI # : 75
Battery Width : 7"
Wet or Dry : Wet
Feb 27, 2011 | 1986 Oldsmobile Regency
How can I make it fit?
Im hopeing you saved your receipt , Because they only work in low light areas anyway . I bought one a while back and I cant see it most of the time.......go get your money back !!
May 18, 2009 | Irwin Miter Saw Laser Guide Attachment...
Nikon D40x indicate battary low
Rechargeable Lithium-ion 7.4V 1000mAh Nikon D40x battery for sale,20% off! Full one year warranty! For more info visit: http://www.nikon-coolpix-replacement-battery.com/d40x.htm
May 13, 2009 | Nikon D40x Digital Camera
Lazer not working after batterys replaced
Mine did the same thing. I think it's a bad contact situation. I ended cleaning all the contact springs in the battery compartments and also putting a small dab of silicon on each battery before re-fitting the cover plate. This made sure the batteries were nice and snug in their housings. Make sure the batteries all have have the positive symbol (+) upwards when you refit them. You can also check the centrifugal switch. This is located under a triangular plastic cover. If you hold the batteries in place with your thumb, you can gently push the tiny weight against its contact and the laser should light up. DON'T LOOK DIRECTLY INTO THE LASER WHILE YOU DO THIS!!! This worked for me but I can't give any guarantees but, hey, what have you got to lose? Good luck.
Jan 01, 2009 | Irwin Miter Saw Laser Guide Attachment...
Irwin laser light for miter saws
The way it works is when it spins the spring part touches the other conductor. I had this problem but slightly and very carefully bent/moved the straight conductor toward the spring without them touching and has worked perfectly ever since with a visible line even in sunlight. If you unscrew the cover there will be a black plastic piece underneath, take that off and that is where the straight and spring conductors are. Be sure to put the plastic triangle back on and the cover screwed back on.
Dec 02, 2008 | Irwin Miter Saw Laser Guide Attachment...
I just purchased a Hitachi C12LSH. The blade hits the guard in the cutting trough. How do you move the saw blade to center it?
you should be able to adjust blade up a little bit, you only want blade to cut through tile bout 1/4 inch ,should be big knob you lossen to lift up motor and blade good luck
Aug 02, 2008 | Irwin Miter Saw Laser Guide Attachment...
RYOBI TS254 change saw blade???
should have blade lock button remove blade with proper size wrench reinstall new blade in reverse remember some of these the loosening of the blade will be clockwise so if nut dont come loose try clockwise to loosen good luck
Apr 22, 2008 | Irwin Miter Saw Laser Guide Attachment...
Fitting a craftsmans 12" compound saw
Theres no fix here-if you want a laser, you'll need to get one that will fit the Craftsman.
Dec 02, 2007 | Irwin Miter Saw Laser Guide Attachment...
Irwin Miter Saw Laser Guide Attachment 3061001 Logo
279 people viewed this question
Top Irwin Saws Experts
Tom Chichester
ray gallant
Are you an Irwin Saw Expert? Answer questions, earn points and help others
