Hplj m5035mfp 60.01 error - Office Equipment & Supplies
2 Suggested Answers
TimeDefensiv
  • 746 Answers
SOURCE: HPLJ 3030 "Scanner Error -
Hi, unplugged its data cables for two hours. It exists inside the printer right or left hand depends on model. After two hours replug and you will see that your problem will have been fixed.
Best of Luck
Posted on Aug 28, 2011
Best of Luck
Aug 28, 2011 | HP LaserJet 3030 All-In-One Printer
Hi,a want to forward a received fax to a email address with a hp m5035mfp,is it possible?
Yes you can, what you need to do is go into the embedded web server (type in the IP address of the printer into your browser). The function you need to turn on is called Fax Archiving. This will then use the email function of the 5035 to forward the mail to the address of your choice.
Apr 19, 2011 | HP LaserJet M5035 MFP Printer
Scanner error 8 in hplj m1522nf printer
A Scanner error 8 indicates a problem with the upper scanning bed.
There is no other solution than to replace it.
This printer is still under a warranty extension until 3/23/2011for the scanner and formatter boards that should be replaced at the same time.
Contact Hewlett Packard Technical support.
Jan 14, 2011 | Office Equipment & Supplies
HPLJ 4350 paper jam the paper does get stuck in the up the paper path just passing the toner I have to constuntly pull out stuck paper I get a error code of 13.00.
First you need to clean the machine. Next you need to try a nother toner cartridge. If it still does it you mite need a fuser.
Also does the paper reach the fuser?
Jan 21, 2010 | HP LaserJet 4350n Printer
HPLJ 4350 58.8 error?What is this error referring to?
Here is the information courtesy of the HP website.
Happy Thanksgiving,
Don
58.X PRINTER ERROR alternates with 58.X PRINTER ERROR To continue turn off then on Description A printer error has occurred where a memory tag central processing unit (CPU) error was detected, or there is a problem with the air sensor or power supply. X Description 2- air-temperature sensor 3- DC controller 4- power supply Action
  1. Turn the printer off and then on.
  2. Remove the printer from any universal power supply (UPS), additional power supplies, or power strips. Plug the printer into a wall outlet and see if this resolves the problem.
  3. If the printer is already plugged into a wall outlet, try another power source in the building that is independent of the one currently being used.
  4. The line voltage and current source at the printer location might need to be inspected to ensure that it meets the electrical specifications for the printer. (See the printer User's Guide for information about electrical specifications.)
  5. If the message persists, contact HP Customer Support.
Nov 25, 2009 | HP LaserJet 4350 Printer
HPLJ P3005x Error
8X.YYYY EMBEDDED JETDIRECT
ERROR
The HP Jetdirect embedded print server has
encountered a critical error.
● Turn the device off and then on.
● If the problem persists, contact
HP Support.
Sounds like it's more than memory failure.
Sep 17, 2009 | Office Equipment & Supplies
Error on my printer
turning machine off/on doesn't help?
The laser motor has failed most likely
Apr 16, 2009 | Office Equipment & Supplies
How to install an Hplj 4600 laserunit
NO . just make sure you replace the black laser.
Apr 06, 2009 | HP LaserJet 4600 Printer
Hplj 3030.. fax set up
Paste the link below in your browser
http://h20000.www2.hp.com/bizsupport/TechSupport/SupportTaskIndex.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=378056&taskId=110
Feb 20, 2008 | HP LaserJet 3030 All-In-One Printer
73 people viewed this question
jasbo
jasbo
