Question about Lands Phones
Doro hs111 Wired Mono Headset wireing diagram
Doro hs111 Wired Mono Headset want to know how to wire a different plug onto the lead
SOURCE: Wiring
first, what is the model number? I'll shoot you a wiring schematic.
Posted on Dec 07, 2007
  • 35 Answers
SOURCE: phone jack wiring
Its typical in apartments for the phones to come in through a single source and then fan out to other wire leads to the rest of the phone jacks in the place. However, I think its odd that your 'source 2' has 9 wires. I'd expect 8.
One idea is to take off a phone plate in another room and see if the wire colors on source 2 or 3 match the unknown source wires. If so, then just match the wires that connect to the same plugs in the plates.
Posted on Jan 26, 2008
SOURCE: how do i wire a jl w3 to a jl 500/1 mono
wire the sub in series it will give you best bang
Posted on Mar 16, 2009
fredpurplefi
SOURCE: lost installation manual. specificaly wiring diagram
i damn sure didnt throw away 25 bucks; i guessed and got it.
Posted on Mar 25, 2009
SOURCE: Wiring diagram for PowerBright VC-1500W Step Up&Down Transformer
I just had a similar problem but only a couple wires popped out. I took a guess at where they came from and it works again.
Top right corner - left hole - black wire
Middle, right side - left hole - brown, right hole white
bottom centre - left hole - blue and green, right hole yellow and green
Posted on May 03, 2009
How are the speakers wired on a Motorola S9 HD bluetooth headset?
Regrettably we don't have wiring diagrams.
Mark
Motorola Support
Jun 23, 2015 | Motorola Radio Communications
Motorola H721
No. Most mono Bluetooth headsets cannot play music. You need a stereo bluetooth headset or a wired headset.
Mark
Motorola Support
Jun 20, 2014 | Motorola Mobility H721 Bluetooth Headset
Kenwood dnx7100
If someone cut the cords you will either need to know how to rewire them or buy a new headset.
Apr 27, 2014 | DreamGear DG360-773 Headset - Wired...
How do i install 2 ckicker cvr to my amp
Here are a couple of diagrams 2+4 ohm dual voice coil wiring.
Option 1 (parallel/parallel) = 1 ohm load
Voice coils wired in parallel, speakers wired in parallel
Recommended Amplifier: Stable at 1 ohm mono 2_4ohm_dvc_1ohm.gif
Option 2 (series/parallel) = 4 ohm load
Voice coils wired in series, speakers wired in parallel
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_dvc_4ohm.gif
Option 1 (parallel/parallel) = 0.5 ohm load
Recommended Amplifier: Stable at 1/2 ohm mono 2_2ohm_dvc_05ohm.gif
Option 2 (series/parallel) = 2 ohm load
Recommended Amplifier: Stable at 2 or 1 ohm mono 2_2ohm_dvc_2ohm.gif
Option 3 (series) = 8 ohm load
All voice coils wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_2ohm_dvc_8ohm.gif
Apr 12, 2010 | Kicker CVR12 Car Subwoofer
How do i hook up kicker solo baric in the box
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_2ohm_dvc_8ohm.gif Option 1 (parallel/parallel) = 1 ohm load
Apr 10, 2010 | Kicker Solo-Baric L5 Car Subwoofer
How do i install my L5 solo barics to a 2 channel amp if there is only one connection on the enclosure next to the vent? If I bridge the amp to 1x1000W will the power distribute evenly between both...
Option 1 (parallel) = 2 ohm load
Speakers wired in parallel
Recommended Amplifier: Stable at 2 or 1 ohm mono 2_4ohm_svc_2ohm.gif
Option 2 (series) = 8 ohm load
Speakers wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_svc_8ohm.gif
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_dvc_4ohm.gif Option 1 (parallel/parallel) = 0.5 ohm load
Apr 09, 2010 | Kicker Solo-Baric L5 Car Subwoofer
Hearin myself in just one side of the headset!! help
Make sure when you create a new track in your software, you are creating a Mono track, not a Stereo track.
Create a Mono channel and choose a single channel.
Mar 23, 2010 | Portacom Porta-Com COM-60FC 6 Headset...
DONT KNOW HOW TO RUN 2 OHMS
Hello storres18,
If you have the Kicker model number 06CVX122, with dual 2ohm voice coils, they can be connected to a mono amp at 2ohms. First jumper the voice coils in series, the dotted positive (+) to the undotted negative (-) (or vice versa). Each sub is now 4ohms. Then wire both of the remaining positives and negatives together on the amp terminals (in parallel). The amp sees a 2ohm load. Here's the diagram:
If you have the Kicker model number 06CVX124 with dual 4ohm voice coils, they cannot be wired to present a 2ohm load. They can only be wired as a 1ohm load (too low for the amp) or as a 4ohm load (at reduced power). Here is the diagram of the 4ohm wiring:
Hope this helps.
May 10, 2009 | Visonik V900XD Car Audio Amplifier
2 channel amp to 6-6x9 wiring diagram
Hello magoocsl,
Yes, with the use of 2 high-pass and 1 low-pass crossovers, that Kicker amp will operate in what they call stereo and mono simultaneously (SAMS). You'd run 4 of the 6X9's in mono. Wire them in series-parallel with a low-pass crossover on the positive leg to the amp. The amp would see a 4ω load. The other two 6X9's would be wired as stereo, one to each channel with a high-pass crossover. Again, the amp sees a 4ω load.
Here's a link to the appropriate wiring diagram. The diagram is on page 5. Just substitute your 4 6X9's wired in series-parallel where they show the "mono" speaker.
http://www.kicker.com/sites/default/files/02KX300_400_500_800_2AmpManual.pdf
Hope this helps.
Apr 01, 2009 | Kicker KX500.2 Car Audio Amplifier
Problem with Headphones
Can you pls add a few more details:
1. are the 2.5mm jacks stereo (3 pins) or mono (2 pins):
2. is your universal headset monaural or stereo; and
3. originally, did the universal headset came with 2 separate plugs?
At most that I can give you is a general/generic idea. The external speaker/microphone (or in your case the universal headset) uses also the charge jack, chances are that it is a multi terminal/pin jack. Pls refer to the diagram below.
The reason it is in continuous transmit is because one of the mini speaker is wired to the PTT trigger or the pins are wired wrong;
This would also explain why no transmit audio either manual or via VOX.
Hope this be of some help/idea. Post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 02, 2007 | Radio Communications
Lands Phones Logo
32 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
