Question about Gateway MT3422 RTL Notebook
Medion MD 96290 how do i remove the laptop keyboard
How do you remove keyboard from a Medion MD 96290 laptop
I have removed all screws from the base but still can not remove keyboard
can any one help
  • clarkiesshop Jan 31, 2009
    I've got the same problem - I've managed to source a new Keyboard but don't know how to remove the casing to replace the old one
  • Anonymous Feb 28, 2009
    Keyboard only works correctly when it has been run for about an hour. The problem was caused by water.
    As such I need to remove the keyboard to clean it and if necessary replace the keyboard.
    Where did you get the new keyboard from?
    I've tried to get to the keyboard via the front and by the base as well but it's not clear what needs to be done to remove the case base.
    Scholar:
  • 149 Answers
It a bit tricky this one....none of the screws actually holds the keyboard in....you'll need to remove the plate over the power buttons...this is held in by pressure clips...ie it snaps into/out of place....to do this I eased up the plate by gently prying the hinged brackets up and prying the facia off....be careful its only thin plastic......once you've done that the keyboard is ready to slide up towards the hinge brackets....its a bit tight so be careful but its only held onto the board by the data cable.....reverse procedure to fit new one...
Posted on Mar 19, 2009
Follow the previous advice (very accurate).
The keyboard has sticky pads on the bottom of it. This makes it a little bit difficult to remove.
The keyboard connection has a little slider on the motherboard slip (don't pull out completly) this out very gently this helps with removing the keyboard cable and inserting the new one.
The keyboard code for the MD9620 is MP-03266GB-442A.
I tried Medion and they wanted £105 plus parts, they would not sell me just the keyboard.
John @ www.notebookrepair.co.uk says he can get me one within about a week so I've ordered one.
Given the part number a Toshiba Equium L20 keyboard may work (looks very similar - slightly different key markings - part number for this is MP-03266GB-920).
If you bust the plastic facia, there are a few people selling this on ebay (may help with removing having a look)
I would suggest putting a finger nail between the silver and black plastic at the back of the laptop hinge. Then use a wide'ish but thin flat screw-driver to lift both sides. You will need to lift the plastic along the top of the keyboard as well. Do this carefully. There are however quite a number of catches. The extreme left and right are easier to lift out if you have lossened all the other catches off then pull gently away from the keyboard at a shallow angle as the catches for these sides sit under the silver section.
NOTE: Make sure you have removed the battery and power cord before you start doing any of this as the motherboard is likly to have voltage if you don't. Also beware of static.
Keyboard fascia (not the best of pictures):
http://cgi.ebay.co.uk/MEDION-MD96290-POWER-BOARD-HINGE-COVER-KEYBOARD-TRIM_W0QQitemZ380104962753QQcmdZViewItemQQptZUK_Computing_LaptopAccess_RL?hash=item380104962753&_trksid=p3286.c0.m14&_trkparms=72%3A1690|66%3A2|65%3A12|39%3A1|240%3A1318
Posted on Apr 18, 2009
  • dbld Jun 25, 2009
    Finally have the replacement keyboard. They had a few problems getting a medion one.
    The keyboard is not a medion one, but it is close enough (function keys have different symbols - you could carefully swap the keys out - but I would advise leaving well alone).
    The details on the keyboard are:
    KB 99N458D0U61390015VHSA
    Model: NSK-ACD0U
    Darfon Electronics Corp
    The connector is slightly off to the left by 0.5cm, but doing two very careful bends aligned it sufficiently.
    Keyboard works so all's fine.
Why not source the keyboard direct from Germany! I did and the service wasw excellant. The kb slotted right in.
I went on the German ebay site, paid by paypal = 39 euros all in!
Siralli
Posted on Dec 02, 2009
How disassambel laptop medion md41700?
Model not found on support site MEDION UK Manual But laptops have small screws holding them together. And snap locks that need to be released gently. I use my finger nails or a razor blade to start pry open the release snaps. To open up a laptop after removing the screws. Each laptop is different, keyboards usually can be removed after removing any screws and prying up from the top (where the F keys are" other screws are under there for getting to the motherboard.
Cables for keyboard video differ by models and makes as well. You have to know the type of connector used for removal and re-locking when putting back togther.
May 20, 2014 | Computers & Internet
My medion 95924 keyboard is locked. I am unabe to
Does the keyboard work in Dos mode or when you boot up goto set up and see if you can use keyboard to adjust settings
Nov 01, 2009 | Medion MD 96340 Laptop
How to Upgrade Medion MD96500
Chances are, you can find this info included in a video on youtube. There's a LOT of people who like to share their expertese on this type of subject
Sep 18, 2009 | Medion MD 96340 Laptop
I need a replacement keyboard for Medion laptop model no: MAM2100. OR MD 96327.I spilled water on the keyboard, some keys work, some don't. Want to replace the keyboard but cant find one to match. I HAD TO...
Check first for a spare on Ebay, that will be cheaper than buying a new spare, but parts for this model are difficult to find.
For example here is a RAM2000 keyboard, contact Medion to find out if it is compatible:Cybercom MD42792 Medion Ram2000 Replacement Keyboard
If you do not find a compatible part, call medion, they can supply parts and tell you what parts are compatible:Medion.com
Try also Computer parts for MEDION
In US you can also contact Quanta that distributes medion parts internationally, they are locaed in US and ask part price and availability: Contact Us
May 17, 2009 | Medion MD-40954 Notebook
Keyboard on my Medion MD 40812 PC Notebook will not work
the keyboard needs to be check to see if it is not clip in propery or if the keyboard need to be replaced.
Aug 18, 2008 | Medion MD-40954 Notebook
Medion MD41349
You need to remove all the screws from the back also, then remove the cover to the rear on the bottom and remove the wireless card (make note as to connection colours) and there is 2 (I think) screws under there, then one also under the battery, then the whole top opens up.
Make sure you have removed all screws from the bottom case, including the four under the rubber feet at the rear.
This was the most awful laptop I have ever worked on!
May 11, 2008 | Medion MD-40954 Notebook
Medion MIM2120 Laptop
Remove the large panel (7 screws) on the base of the machine.
The memory is situated under a black flexible plastic cover about 75 x 30 mm - amost directly below the earphone and mousepad area.
Memory is held in position by clips at each side - press them outwards and memory card will pop-up.
A second card can be fitted below and slightly higher than the first.
I have just fitted IGb and will probably put in another (max 2GB), - cost about £15.
Hope this is of use.
Feb 23, 2008 | HP Pavilion dv6000z Notebook
Medion Mid2020 MD-41060 Switches self off
Probably....overheating. Maybe....the CPU fan or chassis fan(s) need to be replaced. Or...perhaps...the thermal sensor on the Motherboard is failing.
Jan 11, 2008 | Medion MD-40954 Notebook
Gateway MT3422 RTL Notebook Logo
6,447 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
