Question about LG KP500 Cell Phone
Key reset for LG KP500
On my LG KP500, the touch screen seems to not work (or, at least works very-very slow; only '"slide to right" command...) but the keys (real buttons) are OK. I want to try a hard reset but in this conditions, I could not give him a hard reset by entering a code (as 1809#*500#) because, as I said, my touch screen don't react (or react with problems). So, the question is: is there a key combination to perform a hard reset for an LG KP500?
firesnake09
  • 2923 Answers
SOURCE: my touch screen isnt working at all on my LG KP500
For unresponsive touch screen, the common cause of the problem is a damaged digitizer.
Since the LG KP500 does not have a keypad that you could use, you need to replace entire LCD assembly unless you can get a split LCD/digitizer assembly.
If you're not sure how to replace it, you can either send the phone to the manufacturer or take it to a local cell phone repair shop.
Thank you and good luck!
Posted on Jun 17, 2010
  • 26 Answers
SOURCE: LG KP500 touch screen not working
It seems you have A damaged digitizer. Genereally need to replace entire lcd assembly unless you can get a split lcd/digitizer assembly.
Posted on Sep 01, 2009
SOURCE: front keys will not work on my lg env2
Mine does the samething. Call customer support and let them know your phone is not working and you need a replacement. Mine is getting replaced. Mine started as just the "ok" button now it's moved to the 4-5-6 row. very frustrating.
Posted on Jun 01, 2009
  • 5 Answers
SOURCE: My LG rumor keyboard doesn't work
Smack it
Posted on Aug 20, 2009
SOURCE: it ks660 LG phone the touch screen not working.
the solution to this problem is this - pull down(put pressure) the silver line between the screen and key pad, you will notice that the screen will start responding. So what i did was that i removed my screen protector(foil), fold it into two then push it down on the right side then cut it with a sharp razor blade.
the whole idea is just to put pressure between the silver line and the screen region.
Try it!
REGARDS
Godfrey Ekele (Port Harcourt Nigeria)
Posted on Sep 17, 2010
THE SCREEN IS BROKE ON MY LG MS 770
I don't know if you were able to fix it. But Metro PCS is offering this phone for $99 with a $50 rebate (Visa gift card). So net price is $49. It may be less costly to just buy a new one??
Dec 28, 2012 | Cell Phones
Tip
With article and troubleshooting guide solution for Android Hard reset way
  • Note: the different types of methods are numbered, method 1, method 2, method 3, etc.
1. When the phone is powered off, press and hold the Volume Up and the Volume Down keys both at the same time, then press and hold the Power key until a test screen that shows some available options appears, usually takes about 15-20 seconds. When that screen pops up you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlights FACTORY RESET then press the Power key to select it.
2. Power the phone off all the way, press and hold the Volume Down key and press then release the Power key, still holding the volume down key for about 10-15 seconds. When you see some additional options pop up on the screen you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlights the reset option; it usually says FACTORY RESET, then press the Power key to make the selection.
3. While powered off, press and hold the Home key, while continuing to hold the home key power the device on by pressing the Power key.
Once the Android Recovery screen appears release the Home key, then while on the Android Recovery screen, press the Volume Up and Volume Down keys both at the same time.
If/when you're on the Android System Recovery screen release all the keys, and then use the Volume down key to navigate down to the "wipe date/factory reset" option. Once it's highlighted press the Power key to select it.
Once you see the "Confirm wipe of all user data?" Press the Volume down key to highlight "Yes-delete all user data", then press the Power key to select it.
4. Power the device off, then press and hold the Home key and press and release the Power key (while still holding the Home key).
From the Android Recovery screen, press the Search key.
Tap to select wipe data/factory reset then select Ok (located in the lower left of the screen). Note: if screen is not responsive use the Volume keys to scroll and the Camera key to select.
Select Yes - delete all user data, and then select OK (again lower left).
Select "reboot system now" and press OK.
5. Here is an alternate reset for a Motorola Atrix still running on the 2.2 Android OS...
While the phones power is off, press and hold the volume down button and press and release the power button (note: if it doesn't work after all the steps listed try holding down the power button along with the volume down button in this first step).
A "Fastboot" screen should pop up, press the Volume down key to cycle through the choices until you get to "Android Recovery", then press the Volume up key.
Wait for the "triangle!/Android". Once it pops up you'll need to tap on the bottom right corner of the screen (note: it may take a few attempts). A menu should pop up.
Tap on "wipe data/factory reset", and then tap OK. Another confirmation screen will appear. Tap Yes and then OK.
After the data is cleared the "reboot system now" option should appear and is highlighted by Default. Tap OK.
Note: this type of reset is common on the 2.2 (Froyo) before the tech geeks wised up and removed the need to use the touch screen.
6. This reset is for the same phone, the Motorola Atrix, but one that's running on the 2.3 OS.
Power off the phone, press and hold the Volume down button and Power button simultaneously while powering on the unit.
The "Fastboot" screen should pop up. When it does press the Volume down key to cycle through the choices until you get to "Android Recovery", and then press the Volume up key to boot in this mode.
Wait for the "triangle!/Android" screen to pop up. Once it does press both the Volume up and Volume down keys simultaneously. A Recovery Menu should pop up.
Tap on the Volume down key until "wipe data/factory reset" is highlighted, and then tap the Power button. Another Confirmation screen will come up. Tap on the Volume down key until it highlights "Yes" and then tap the Power button to make the selection.
After it's done make sure "reboot system now" is highlighted and then tap the Power button.
In this method you don't have to use the touch screen any more. So let's say your touch screen isn't responding therefore you can't navigate the phone or go into your settings and do a regular factory data reset. Well now on the 2.3 there is hope. Just power off the phone and perform these steps and the reset should go through.
7. Here is a hard reset for a Sharp Android Smartphone.
While the device is off, hold the Sym button (it's located on the keyboard) and the Power button simultaneously.
Once the Android boot screen appears highlight the Wipe data/factory reset option by using the volume buttons. Then use the Return key (on the keyboard) to actually make the selection.
Scroll down to Yes - delete all user data and then press the Power key to confirm.
Once it is done select reboot system now and press the Power key to confirm and reboot your handset.
8. Here is a common method used to hard reset an LG Android smartphone. So if you need to hard reset an LG Optimus this is the hard reset key combination to try first.
After the LG phone has been powered off, press and hold the Volume Down button. While holding the Volume Down button, press and hold the Home button. While holding both the Volume Down button and Home button, press and hold the Power button.
Continue holding these three keys down simultaneously until the LG logo appears.
Once the LG Logo appears release all of the keys. This will complete the reset on many LG phones; you will be given the option to "Select your language" and can proceed with setting up your device as if you were setting up the phone for the first time.
If however, you are taken to a fastboot screen or a screen with additional options then use the Volume Down key to scroll to and highlight the wipe data/factory reset option and then press the Menu key to make the selection.
The phone might give you a confirmation screen in which you can use the Volume Down key to scroll to and highlight Yes -- delete all user data and then press the Menu key to make the selection.
If you get an option to reboot system now then select that option with the Menu key. The phone will reboot, which can take a couple of minutes, and the hard reset will be complete.
Now you know how to hard reset an Android Smartphone and the next time your touch screen stops responding, your phone freezes, your phones power cycling, you forget your password, or pretty much any reason you wouldn't be able to perform a reset through the settings, you'll be set.
If I have forgotten any key combos that you know of, leave the method in the comments below so that I can add it to the list. Don't forget to check out some of our many other popular posts and don't forget to power your phone off every couple of days and watch what applications you choose to download onto your device that way you can keep your phone healthy and efficient. Hope you enjoyed the article, have a fantastic day, and enjoy your phone.
Thanks for checking out this Solution. Phonetolls.blogspot.com contents provide include dozens of cell phone artical additional, pictures, with hardware and software troubleshooting guides for you. Support us like and connect with this blogger for latest newsletter please follow me. By Admin shahid abbas
Phonetolls
on Jun 24, 2015 | Cell Phones
My LG KP500 doesn't turn on
You can buy all sorts of cell phone parts on ebay. Are you sure you have a fully charged battery in your phone? If the battery is charged, and the phone will not boot past the welcome screen, you will either need to do a hard reset to reinstall all of the operating system files or replace the motherboard. Do an internet search for LG KP500 hard reset for detailed instructions for the hard reset. Caution - this will delete all files which were saved on your phone. It will not delete files on your SD memory card.
Mar 28, 2012 | LG KP500 Cell Phone
There is a key combination to perform a hard reset for an LG KP500?
  1. Start by pressing Power button, device must be working to succeed this operation.
  2. Pressing Call key will open phone's Dialer.
  3. Type in this code into dialer. (Code: 1809#*500#)
  4. Factory reset operation needs to be confirmed by clicking green Call key.
hard reset for an LG KP500 Google Search
Jun 19, 2017 | LG KP500 Cell Phone
My lg cookie kp500 is not working properly the touch screen seems to have frozen ?
To solve your problem you need to FLASH your handset.
And then also your screen doesn't works then you need to
change it.
Thanks
Aug 28, 2011 | LG Cell Phones
Touch screen is not working. it stopped working all of a sudden
LCD Display +Touch Screen Digitizer for LG KP500 KP501 Cookie ~ Repair Parts Replacement by Buythestuff Permalink: http://amzn.com/B003GX7W2W THIS WILL FIX YOUR PROBS ONLY $26 !
Apr 11, 2011 | LG KP500 Cookie
Hello i have LG KP500 phone, the touch screen is not working. i am unable to use all the functions keys.
check the touch pad.the strip may get damaged replace it or if you have warrenty claim it . or reset the phone.
Nov 16, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
LG KP500 Touch Screen Not Working
Gently bend it like you're trying to split it with screen facing upwards or squeeze around the camera. Amusing solution but it works. recalibrate your touch settings afterwards (menu>settings>touch settings) for perfect operation
Nov 01, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
i squeezed around the camera and it came good
Sep 01, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Touch screen not working seems to be locked cant
did you checked the settings on your cell because there are some adjustments to the lighting of the screen surely you didn't put lighting and that's why it wont turn on
Jul 25, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
LG KP500 Cell Phone Logo
158 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
