Question about Cecilware FMS-40 Deep Fryer
Hi-limit trips, How it works and how to trouble shoot?
  • tract Nov 19, 2008
    A thermometer was used to check oil temp. Too hi. Adjusted thermostat. Problem hasn't returned.
  • 21 Answers
Jump the hi limit by connecting the two wires in the back of the limit control after 45 minutes with the fryer on and does not go off the limit is bad and should be changed we have aLL THE PARTS IF NEEDED ASK FIXYA TO CONTACT ME
Posted on Nov 19, 2008
Trouble shoot Rascal 200 mobility scooter. Horn works. That is all.
Hi check reset circuit reset button .it might have tripped . Cheers
Nov 26, 2016 | Health & Beauty
Need help trouble shooting heater problem
Yes this is your Hi Limit (High Temperature) sensor.
This is a safety device so replace it.
On most DreamMaker spas the Temperature Hi Limit sensors share the same 4-Wire plug, you will have to replace both.
If your sensors have a telephone style plug you can replace the Hi Limit with out replacing the Temp sensor.
Feb 07, 2012 | Dream Maker Spas Pool & Spa
Fryer is cutting out after certain temp and tripping hi limit. I replaced Hi Limit, Thermopile and Thermostat and it worked great for two days and then kicked out again, tripped Hi Limit. I'm baffled...
Hi there
Hi limit will trip at 450F.
Check your thermostat setting, then check its calibration, this way you will be able to verify where the problem is.
If the setting and calibration of the thermostat is good, check the hi limit sensing bulb, it should not touch the fire tube because if it does, it will sense high temperature and will cause premature tripping.
Jul 11, 2011 | Pitco Frialator SG14 Deep Fryer
Trouble light comes on, can barely read the instruction around it(faded over time)It says to push a red button but not sure where the button is. Help!!
When trouble light comes on, it indicates that the hi-limit is tripped (this happens when oil temperature exceeds 450 Fahrenheit). The red button is located at the upper back panel of the unit, give it a push to reset but if nothing happens after resetting the button, the hi-limit needs to be replaced. Also try to check if the thermostat is working, stuck thermostat's mechanical contact will cause the hi-limit to trip.
May 05, 2011 | Wells F14 Deep Fryer
I have a 40c+ss pitco fryer.the pilot will go out at random times.Could be 1hr or 24 hrs after it is lit. The gas valve has been change, and the thermalpile has been replaced.
Check if your pilot flame sufficiently heats thermopile during operation and make sure also that it is free of soot or any form of dirt, thermopile generates small amount of electricity to energize pilot and main valve of the gas valve for pilot and main burner operation. This electricity passes through hi limit mechanical contacts. Hi limit on fryers act as safety device which will shut down pilot and burner flame when oil temperature reaches 450F.
If your fryer is set at 350F and over shoots up to 450F (which will trip hi limit and shut down pilot and burner flame), the thermostat is not good, but, if hi limit trips on temperature much lower than 450F, hi limit is bad.
Nov 12, 2010 | Pitco Frialator 40CNG Deep Fryer
Fan motor in outside unit is not running
If it is not running and the compressor is, then you have a bad can get a new motor easily online from
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
Aug 12, 2010 | Goodman CKL60AR60 Air Conditioner
34000 btu, outside condenser unit keeps tripping breaker. Unit was manufactured 02-20-2005
Hi, It is tripping the breaker because the compressor is locked up and will not start..
Aug 11, 2010 | Haier Heating & Cooling
My dryer will run but will not get hot. The trouble shooting guide says that on of the two house fuses in the circuit may be blown or the thermal limiter is tripped. Where are the fuses in the dryer. I...
First id make sure you have both phase of AC power coming into dryer.
Go to your house panel and reset yoru house breaker for the dryer. If in the USA the breaker should be a 240volt / 30amp breaker. It will have two breakers tied together at the trip switch.
If AC power is good at the dryer outlet then it could be one of the followings.
  1. Open Thermal limit fuse or trip switch.
  2. Open Heater Element.
  3. Control board is faulty.
Oct 26, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Pool heater fires up and starts heating the water outflowing into the pool, but only stays warm for 5 minutes or less then cools and stops heating
You are tripping a temp limit switch. You either have a bad switch which you can jump the wire to confirm. This is a trouble shooting technic only. Jumping the wire permantly might cause bigger problems.
Aug 17, 2009 | Hayward H Series Propane Electronic...
Cecilware FMS-40 Deep Fryer Logo
234 people viewed this question
Top Cecilware Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
john h
Are you a Cecilware Kitchen Appliances - Other Expert? Answer questions, earn points and help others
