Question about Garden
I need a rear sprocket for my victor pro 12 - Garden
2 Suggested Answers
paul4265
  • 592 Answers
SOURCE: I need sprocket for victa
Yes, the Victa brand is an Australian manufactured mower, and appears to have a minly Aussie client base. However, I did find a Australian company atht will ship worldwide, and they do in fact carry Victa products.
http://allpower.net.au/
I wish I could me of more asistance, but as this is a relatively obscure brand, evn though it does get high mrks for quality and innovation, it took some hunting just to find a supplier for what you need.
Good luck with your repairs!
Posted on Jan 20, 2011
Torque settings for front sprocket nut and rear sprocket nuts
Hi, Anonymous sorry you can't find the first and best tool you ever bought for your Kawasaki despair not for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Sprocket Torque Specs
http://www.kawasakininja300.com/forum/12-ninja-300-appearance-modifications/1556-installing-15t-front-sprocket-7.html
Kawasaki Ninja 300 Service Manual
Kawasaki Ninja Owners Manuals
Apr 17, 2016 | 2014 kawasaki Ninja 300 ABS
What is the torque spec for a 2003 jeep wrangler 2.4 connecting rods
  • ENGINE 2.4L
DESCRIPTION
N·m
Ft. Lbs.
In. Lbs.
Balance Shaft Carrier to Block-Bolts
54
40
Balance Shaft Gear Cover-Double Ended Fastener
12
105
Balance Shaft Sprocket- Bolt
28
250
Balance Shaft Chain Tensioner-Bolts
12
105
Balance Shaft Carrier Cover-Bolts
12
105
Camshaft Sprocket-Bolt
101
75
Connecting Rod Cap-Bolts
54 +1/4 turn
40 +1/4 turn
Crankshaft Main Bearing Cap/Bedplate - M8 Bolts
34
250
M11 Bolts
41 +1/4 Turn
30 +1/4 Turn
Crankshaft Damper
136
100
Cylinder Head Cover- Bolts
12
105
Flex Plate to Crankshaft
95
70
Flywheel Mounting Bolts
81
60
Engine Mount Bracket Right-Bolts
61
45
Exhaust Manifold to Cylinder Head-Bolts
23
200
Exhaust Manifold Heat Shield-Bolts
12
105
Intake Manifold - Lower -Bolts
28
250
Oil Filter
20
15
Oil Pan-Bolts
12
105
Oil Pan Drain-Plug
27
20
Oil Pump to Block-Bolts
28
250
Oil Pump Cover Plate-Bolts
12
105
Oil Pump Pick-up Tube-Bolt
28
20
Oil Pump Relief Valve-Cap
41
30
Spark Plugs
28
Timing Belt Covers - Front Covers to Rear Cover-Bolts
12
105
- Rear Cover-Bolts
12
105
Timing Belt Tensioner Assembly-Bolts
61
45
Sep 27, 2014 | Cars & Trucks
Yamaha banshee
I would get at least 12 additional links, to account for the larger diameter sprockets making the overall length longer.
Ultimate 2018 Guide for Side by Side UTV Parts Accessories
Feb 08, 2018 | Yamaha 2005 Banshee Base
How put a pitbike 12inch rear wheel on
Buy a 12 Inch rear wheel with the same diameter axle as you ha e and with a centre hub that looks identical. Remove the old axle, remove chain, swap disc tyre and sprocket over then refit
Jan 21, 2014 | Pit SSR 110CC Pro Beginner Bike
How to assemble the rear gear and chain on a 21 speed mtn. bike
Hi victor ernest yessler
Go to the following website and view how to adjust the rear gear and chain
Please rate me
Bud
http://www.youtube.com/watch?v=2j1gSwhsVN8
Sep 27, 2012 | Cycling
I don't understand how to shift my 12-speed Adventurer bicycle and am looking for online manual or some help. The right-hand shifter has numbers 1-6, but I don't seem to know how to match it up...
It sounds like you have 2 sprockets on the Front (Crank) sprocket-
and likely 6 sprockets on the rear?
So-- when you have the chain in the smaller diameter sprocket on the front, and you have the chain on the biggest sprocket in the rear-- you have the most mechanical advantage-- and you can climb hills the best-
If you started in this gear, (sand you are pedaling on the level road) you could gradually work you way up thru those 6 sprockets-- until you are cruising-
Then -- for all practical purposes, you can shift the Front sprocket to the larger sprocket, and now you have at the fastest ratio possible. (In other words you pedal slower, for a faster rotation of the rear wheel-- make sense?)
There is no need to switch back and forth 12 times, as you go gradually faster-- (It is not like driving a big truck! :-)
Does this help?-- if not, let me know what I missed in your question?
Mack B
Jul 04, 2011 | Cycling
I need to know the timing marks for the timing belt on a toyota highlander 2006 , v6 , 3.3 litre. the location of the cams, is it 3 oclock, 6 oclock, 12 oclock?
the timing marks for the cams are on the rear timing cover (behind the cam sprockets). They are very hard to see, especially the rear cam. Align the cam sprocket marks with rear timing cover. Because this engine is mounted at a 60 degree angle, you must use the marks. Rear cam should feel compression while front cam is free!!
Oct 13, 2010 | Toyota Highlander Cars & Trucks
I need to know is smaller sprocket rear for fj1100cc
Smaller sprockets will only give you about 500 less RPM.
May 03, 2010 | 1984 Yamaha FJ 1100
What size chain and sprockets are fitted to a 1993 suzuki TS 185 thank you
Front sprocket NT 12
Rear sprocket NT 39
Go for 520 O-ring chain 120 links.
D.I.D. or Regina chains will have you covered (retailer's will have bike model charts), or some more trick MX kits are available from m'cycle accessories stores. Cheers.
Apr 15, 2010 | 1981 Suzuki TS 185
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
