Question about Aiwa CA-DW248 Cassette/CD Boombox
AIWA CA-DW470 Cassette/CD Boombox, cds have trouble when get to track 8 or more
Someone gave me a cd to use to clean my boombox. I used it. Not sure if that caused a problem or if something else went wrong but after that point, I had trouble playing cds. They play fine until track 8, or 10 or more. When it hits the touble point it gets stuck sometimes or it jumps back other times. I had it into a shop to fix twice but I paid more to fix it now than I would have to reasonably put toward a new one. I can continue using it as is and just listen to part of the cds but I would like it if there was something that could be done to fix the problem. I would also like to know if using a cd to clean machines, really can cause some problems. After using this cleaner my daughter's boombox stopped working and I noticed a short while later (not sure if related) that the Symphonic DVD player that had rarely been used, wasn't working.
  • 275 Answers
SOURCE: Cassette Player Stopped Working
In all likelihood the Drive belts have snapped. Get them replaced.
Posted on Sep 25, 2006
Arpi
  • 326 Answers
SOURCE: Remote not working
You can use any digital camera or camcorder in order to check the remote control. Direct the remote (press any button) in direction of camera lens. If remote works you will see the bright spot on your camera screen. If you need more info please advice.
Posted on Mar 24, 2007
AvioriX
  • 689 Answers
SOURCE: Getting a whine from CD player
Have you performed lens cleaning process?
Posted on Mar 06, 2008
simplemitch
  • 752 Answers
SOURCE: CD player on boombox
The laser is dead or damaged. Try swabbing the laser with rubbing alcohol on a Q-Tip, then IMMEDIATELY blowing dry with canned air. If this fails, the laser is dead. If it is a Sony KSS-2xx series laser (try to peek in the laser slot to see the decal on it) you can get replacements online. If not, it's junk.
Posted on Aug 04, 2008
  • 44 Answers
SOURCE: CD-R Playback Issue
Have the same problem with one of the cd-players in my home. A technics cd-player. Some fo the home-burned cd's work now and then. Sometimes it plays them, sometimes not.
Posted on Jul 07, 2009
How do I record from a tape cassette to a cd?
You cannot, with this device. It doesn't have a CD-burner... those are usually only found in VERY high end audio systems, or on home computers. That said, you can find devices on the internet that will let you rip audio tracks from a cassette player to an MP3 file, which you can then burn to a CD or put on your computer.
May 05, 2012 | Aiwa CA-DW530 Cassette/CD Boombox
The cd plays first 2 tracks only and shuts on 3rd
There may be foreign material on the sled motor and or the sled shaft keeping the steping motor from advancing to next track. Especially if it does this on all CD's you try. You will have to have the unit cleaned and also the stepping motor could have a chiped gear on it, the only reasonable way to solve this problem is to have the laser assembly replaced.
Oct 03, 2009 | Aiwa CSD-TD49 Cassette/CD Boombox
I believe the lens is dirty
Maybe the lens just needs cleaning:
Radio Shack2.gif has a laser lens cleaner for DVD's (Item# 42-227 $14).
It is an "Audio CD2.gif", so read the instructions carefully and have your speakers / headphones on to listen to what is on the audio CD.
It is a CD with a single row of tiny brushes. No chemicals involved.
Get it... it may fix the issue.
Sep 23, 2009 | Aiwa CSD-TD21 Cassette/CD Boombox
I've lost the power cord to my Aiwa CADW248
Radio Shack or similar small electronics shop. 5-10 bucks. Hope this helps
Jul 09, 2009 | Aiwa CA-DW248 Cassette/CD Boombox
Remove speakers from Aiwa CA-DW630 boombox
They may be heldin by the handle, or tabs that you either need to push or pull on the sides or bottom of the unit.;
Jun 23, 2009 | Aiwa CA-DW530 Cassette/CD Boombox
Aiwa CA-DW535
optical lazor fulty and the controler thattriggers it and cheak cable connecting it if u can get in it otherwise cd rom bad ther go bad after 2 3 yrs on these ones
Feb 03, 2008 | Aiwa CA-DW535 Boombox
Durabrand 3-Piece CD Boom Box w/ Radio Cassette Recorder,
Does it happen when playing cassette or radio? might have a problem with the speaker wires.
Oct 23, 2007 | Durabrand CD Player with Cassette...
Aiwa CA-DW248 Cassette/CD Boombox Logo
568 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
