Question about HP Color LaserJet 5550 Printer
Clearing stale data on par port - HP Color LaserJet 5550 Printer
MA5600T GPON boards contain H801GPBC, H802GPBD, and H805GPBD. Can different GPON boards be replaced with each other?
Boards released later can replace boards released earlier and 8-port boards can replace 4-port boards. Specifically,
GPON: H805GPBD can replace H802GPBD and H801GPBC; H802GPBD can replace H801GPBC.
The above replacement is not limited by version and no additional data is required. Except for the above replacement, if a 4-port PON board needs to be replaced with an 8-port PON board, the slot data must be cleared first. Otherwise, the PON board cannot be registered.
Huawei GPBD Board Thunder link com
Oct 25, 2016 | Cell Phones
How do I retrieve my YouTube activation code?
Activation code for what? Parring with another device, or to login in the first place?
If you are parring with another device, here's the guide: YouTube
And if you're trying to access your account, the code will be provided on the e-mail, phone number or authenticator you have specified in your 2-step verification settings.
Hope this cleared some things.
-Matthew
Jan 08, 2015 | YouTube Computers & Internet
Magicjack troubleshooting
Your internet upload speeds are not up to par. Either there are a lot of people using the internet you are using at your home or office where your problem is, if not then you need a better internet service.
Jan 16, 2014 | Computers & Internet
My games
Some times firewall and antivirus software can interfere with loading into Facebook games. Many games that use Flash (such as FarmVille, PetVille, and most other games on Facebook) require you to have certain ports open at all times for sending and receiving data.
Problem may also occur with browsers. some games will be designed for certain browsers. Always try to use firefox or chrome.
It's always a good idea to clear cookies as well, because this stores login information for various sites. Clearing your cookies allows the game to create a new one when you try to load in, which will help if you have stale data being stored.
If the game you are playing requires Adobe Flash, you may need to update to the latest version.
Jun 13, 2013 | Facebook Social Network
Why won,t my games load
some times firewall and antivirus software can interfere with loading into Facebook games. Many games that use Flash (such as FarmVille, PetVille, and most other games on Facebook) require you to have certain ports open at all times for sending and receiving data.
Try this link to know more,
Facebook game loading troubleshooting guide
Stale ice after a new water coil is installed
The water became stale inside copper lines feeding ice maker most likely. Dump your ice for a few times until this clears you should have ask for some money back for copper poison, (joking) Thanks,Sea Breeze
Feb 23, 2012 | Kenmore Refrigerators
22 PAR I0 ERROR
Haven't seen one of these printers for a long time. I think 22 is a datacomm error and the PAR IO would suggest it is a problem with the parallel port.
Verify cable is correctly connected. Try new cable.
Can't remember if the port on this printer is a slot in module, if so turn off printer, remove model ensure contacts clean, re-insert and retest
good luck
Sep 01, 2011 | HP Refurbished LaserJet IIISi printer...
HOW CAN I OPEN A PORT TCP AND UDP IN FRENCH FOR DSLG604T V3.00
Exemple : Vous accueillez un web server sur un PC qui a l'IP address de LAN de 192.168.0.50 et votre ISP bloque le port 80. Nommez le Virtual Server (par exemple : Web server) écrivez l'IP address de la machine sur votre LAN (par exemple : 192.168.0.50 Entrez dans le port privé comme [80] Entrez dans le port public comme [8888] Choisissez le protocole (par exemple TCP). Assurez que le programme est placé à toujours Cliquez sur sauf pour ajouter les arrangements à la liste virtuelle de serveurs Répétez ces étapes pour chaque règle de Virtual Server que vous souhaitez s'ajouter. Après que la liste soit complète, clic sauf des arrangements au dessus de la page. Avec cette entrée de Virtual Server, tout le trafic sur Internet sur le port 8888 sera réorienté à votre web server interne sur le port 80 à l'IP address 192.168.0.50.
My French isn't good sorry.
Feb 15, 2010 | D-Link AirPlus G DSL-G604T (790069265662)...
A fine green vertical line displayed on the Sony Bravia 46.
Thats a pixel data problem, there's no data being sent to that row of pixels so they don't change color. This is a pixel address registry (PAR) issue and the PAR circuits need to be serviced its usually due to open or shorted SMT components on the PAR circuits. PAR also sends data, voltage, and control to each pixel, the green line you see are pixels that have voltage but because there's no data sent too them their all green because there's no control. If the pixels have voltage but no data or control they show up as green red, blue, yellow, or whit line vertically down the LCD panel. The vertical-horizontal section of PAR are controlled by 16 to 32 bit micro-controllers which may need replacing. If its under warranty take it back if not have your local repair center fix the tv for you...
Nov 09, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Rough idle, staling, backfiring
You are going to need to do some testing to find this...first thing I'd look at is to check for any intake or vacuum line leaks, then check map sensor and tps. I can only offer a good guess, as I too would need to do testing before offering anything better. You can get test info in most inexpensive manuals.
Jul 14, 2009 | 2000 Jeep Grand Cherokee
HP Color LaserJet 5550 Printer Logo
311 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
