Question about HP Color LaserJet 5550 Printer
CLEARING STALE DATA ON PAR PORT.
128 ************** clearing stale data on par port
HU8643773
Here is what I have for that model of PS2.
The 128-Bit Emotion Engine is the first chip of its kind. No other mass-market computer technology on the market comes close to its power. In the PlayStation2, this chip is used as the workhorse of the console. It processes all physics and math calculations.
The PlayStation2 has a 128-Bit Emotion Engine. The 128-Bit part of the title means that this chipset both processes information and sends it over a 128-Bit bus (A Bus is the pathway between chips on a circuit board. A wide bus carries more bits of information and is thus faster than a narrower bus).
You may think that your PC has a faster processor, but remember that the Emotion Engine has inherently faster 128-Bit processing and it is just a part of the overall PlayStation2 power.
A small note for the really detail oriented: The reason that the speed is 294.912 MHz, is that it must be a multiple of a required processor speed that supports the DVD ROM operations.
* Dimensions: 301mm (W) x 178mm (H) x 78mm (D), (12" x 7" x 3").
* Weight: 2.1 kg (4 lbs. 10 oz.).
* Media: PlayStation2 CD-ROM, DVD-ROM, and PlayStation CD-ROM, CD Audio
This means your PlayStation 2 will basically play all your old PlayStation games (but not make them look any better), all music CDs and all North American DVDs.
* Interfaces: Controller Port (2)
These are the same as the controller ports on the current PlayStation.
* Interfaces: Memory Card Slot (2)
These slots are very similar to the ones on the original PlayStation, except they support the new, faster transfer rate.
* Interfaces: AV Multi Cable Output (1)
This is where you plug the cord that goes to the back of your television.
* Interfaces: Optical Digital Output (1)
This port will let you send data directly to a digital receiver. This is perfect if you plan to plug your PlayStation into a DTS or Dolby receiver and get perfect sound.
If you don't use digital output, your data will be converted to an analog signal and then be converted back to digital at the receiver.
* Interfaces: USB Port (2)
USB enables you to connect any number of devices to your system with a high-speed data link.
* Interfaces: I.Link (IEEE1394) (1)
The IEEE139 port is known by two names: I.Link and for Mac owners, FireWire - there are some minor differences between the two. This high-data transfer port has the advantage of supplying (some) power to devices that are connected. You can expect that an enormous number of hardware devices will use this port including speakers, printers, and other like devices.
* Interfaces: Type III PCMCIA Card Slot.
This slot is a lot like a laptop's add-in slot. Here you will be able to plug in a modem and eventually the connection for Sony's planned broadband network and hard drive.
Jul 28, 2014 | Sony PlayStation 2 (PS2) Console
My games
Some times firewall and antivirus software can interfere with loading into Facebook games. Many games that use Flash (such as FarmVille, PetVille, and most other games on Facebook) require you to have certain ports open at all times for sending and receiving data.
Problem may also occur with browsers. some games will be designed for certain browsers. Always try to use firefox or chrome.
It's always a good idea to clear cookies as well, because this stores login information for various sites. Clearing your cookies allows the game to create a new one when you try to load in, which will help if you have stale data being stored.
If the game you are playing requires Adobe Flash, you may need to update to the latest version.
Jun 13, 2013 | Facebook Social Network
Why won,t my games load
some times firewall and antivirus software can interfere with loading into Facebook games. Many games that use Flash (such as FarmVille, PetVille, and most other games on Facebook) require you to have certain ports open at all times for sending and receiving data.
Try this link to know more,
Facebook game loading troubleshooting guide
Construct both an ungrouped and a grouped frequency distribution for the data given below: 139 130 128 134 140 139 136 130 136 128 138 137 134 128 127 136 140 132 141
Sorry to disappoint you but I will just give you directions to do it yourself.
Ungrouped
First sort the data in ascending order (from lowest to highest value)
Create a two-column table
In the first column enter a data value.
In the second column enter the frequency of a data item
Count how many times one particular data value appears in the set (how many repetitions). If it appears only once, its frequency is 1; twice, frequency 2, etc.
For each single (different) data value complete the frequency column.
Grouped
For grouped data representations you create classes: A class is just an interval of values, for example between [125, 130[
For each class interval you create, count how many data values fall within the interval. For the class given as example it will encompass all values between 125 and 129, It I counted correctly its frequency is 4.
Complete the frequency table for the class.
How many classes should you create? Usually this information is given to you. If not, create a moderate number of classes (4,5) It depends on the span of the distribution (highest value- lowest value). The intervals should have equal length. Read your instructions.
Sep 02, 2012 | Office Equipment & Supplies
Existing TALLY file damaged D:/Tally/0001/Tr01339.500 Size:116992 Position:116224 Chars:128(done 128)
Please post your question in the form of a question including all necessary details **** as operating system, what you are doing when the error occurs, what you are trying to print, from which application, etc etc etc.
Aug 15, 2011 | Tally T2250 Matrix Printer
A fine green vertical line displayed on the Sony Bravia 46.
Thats a pixel data problem, there's no data being sent to that row of pixels so they don't change color. This is a pixel address registry (PAR) issue and the PAR circuits need to be serviced its usually due to open or shorted SMT components on the PAR circuits. PAR also sends data, voltage, and control to each pixel, the green line you see are pixels that have voltage but because there's no data sent too them their all green because there's no control. If the pixels have voltage but no data or control they show up as green red, blue, yellow, or whit line vertically down the LCD panel. The vertical-horizontal section of PAR are controlled by 16 to 32 bit micro-controllers which may need replacing. If its under warranty take it back if not have your local repair center fix the tv for you...
Nov 09, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Corruption of tally 7.2file
Exiting Tally!
File Damaged
File:C':Tally7.2\Data\009\manager.500
Size 180180
Position: 180352
Charj : 128 (done128)
Jul 04, 2008 | Tally T2250 Matrix Printer
Casio FA-128
how to upgrade Casio FA-128.
Dec 17, 2007 | Casio Boss Business Organizer
Recover tally data
Dear Sir/Madam,
I am getting the following error,
Existing TALLY file damaged File:C:/Tally/0001/Tr01298.500
Position:149760
Chars:128(done 128)
Please give me a solution to get my data and I am using Tally7.2 version...
Thanks & Regards,
S.Prasada Rao
Sep 10, 2007 | Tally T2250 Matrix Printer
HP Color LaserJet 5550 Printer Logo
613 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
