GOT A CODE 49 FAULT ON A LW712 FISHER & PAYKEL
  • Richard Cesan Feb 13, 2012
    Does anyone know what this fault is?
aborcass
  • 2651 Answers
SOURCE: fisher & paykel washing machine fault codes
try removing hte screws from the rear of console and within the console usually is a techsheet with an explanation of hall hte major faults
Posted on Mar 12, 2008
  • 27 Answers
SOURCE: I have a fisher and
Hi there. FC 49 has a few possiblities
1. the wiring connection to the cold water valve has been disconnected
2.the cold valve has failed, compare resistance with hot valve (they should be the same)
3 the motor controller has failed
I hope this helps
Posted on Oct 25, 2008
  • 10 Answers
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Posted on Aug 03, 2009
SOURCE: fisher & paykel intuitive Fault code 136
Sounds like a motor problem Check the motor harness,connectors and motor for discontinuity.This can be done by taking a resistance measurement between phases of the motor harness at the motor control mudule end.should be approx 32 ohms.You can also check at the motor,I have seen a few open circuit connections where the motor connections (spade clips) Push into the plastic motor housing,Hope this helps.
Posted on Sep 14, 2009
  • 343 Answers
SOURCE: what is error code 136 on a fisher & paykel IW...
136 fault is 'motor stall'...Quite often this is a broken wire to the motor. However it could also be a Motor fault, or Rotary Position Sensor problem. Water damage can cause this fault as well. After a visual check for broken wires or water damage, and if your machine is in good condition, you should consider a tech....Good luck...Nomess
Posted on May 24, 2010
Error code 49 f&p aqua smart wl80t65c
49 is a cold water valve fault. test the valve for voltage while filling, it should be recieving 24V. if not, the problem lies with the motor controller.
Aug 30, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher paykel aquasmart fault 49
Fault code 49 is water valves, But the Aqua-Smart board is outputting the wrong code here, The Smart pump has blown the water valves fuse, A common thing in Aqua-Smart Machines.
The Smart pump has jammed with lint and caused over current to the board and taken out parts on the board that drive the pump.
Best to get a new/recondition board for your machine.
Apr 20, 2013 | Fisher and Paykel Aquasmart wl80t65c
Fisher paykel aqua smart fault 49
Fisher and paykel MW511 pride model lights 3, 4 and 8 comming up
That is fault code 49
Here is fault code info.
49.
(00110001) Cold Valve or Cold Valve & Hot Valve Faulty
The Motor Control Module has measured a voltage from the valve diagnostic circuit that
indicates the cold valve or both the cold and hot valve is faulty. The most likely cause is
that the valve harness has not been connected correctly or the valve(s) is open circuit.
Primary Source: Wiring.
Action: Check the valve harnesses are correctly fastened to the valves and
the motor control module or the pins are not bent backwards.
Secondary Source: Water Valves.
Action: Measure the resistance of the cold and hot valve coils.
Tertiary Source: Motor Control module.
Action: Replace the Motor Control module.
Oct 23, 2012 | Fisher and Paykel Washing Machines
I have an Intuitive Eco Fisher and Paykel top loading machine. When I turn it on a continuous beeping sound comes on with the message Fault Code 49 apearing on the screen. What can I do to solve the...
Hi just read your posting.Error Code 49 means your Cold water valve is faulty,Or your control module is faulty.To test this fault you need an electrical test meter to test the water valve coil for conductivity.Have you or can you borrow a test meter to check the water valve?Please reply on how you would like to proceed and I am sure I can guide you throe the steps needed to rectify this fault.Looking forward to your reply.
Jul 27, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Code 49
it probably Needs a new cold water solenoid valve.
Sep 02, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Error Code 49 on Fisher & Paykel Intuitive Eco
Fault 49 usually points to the cold inlet valve, either open circuit or not connected correctly. I often come across machines that the motor controller is the problem too.
Jan 06, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Code 49 and Manual Book
Fault 49 usually points to the cold inlet valve. I have come across many with this fault that the valve tests ok and it needs the motor controller replaced.
Fisher@paykel aquasmart WL80T65CW1 fault code245 and code49
hi my fisher & paykel aquasmart has a message saying fault 49 what does this mean?
Sep 03, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
