Question about Samsung Washing Machines
Samsung WA85VPL 6.5kg top load
Panel lights are working but machine is not at all working
2 Suggested Answers
  • 6277 Answers
SOURCE: What are the setting we
Methinks you could do with a manual- for now and later!
Now- unfortunately FixYa cannot provide manuals direct - members of the forum are just people from all over the world, probably working from home, and not representing any particular manufacturer ;-0)
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Sep 17, 2011
Why won't my Samsung Front Load Washer Model # WA45H7000AW turn off automatically?
Samsung Top Load Washer WA45H7000AW/A2 ' Front ...
www.samsung.com > ... > Top Load Washers
Samsung Electronics Rating: 3.9 - ‎254 reviews - ‎$699.00
4.5 cu. ft. Capacity. Washer capacity has a direct impact on how much time you spend doing laundry. ... Top Load Washer with VRT (White) ... Owner's Manual.
Oct 16, 2015 | Samsung Washing Machines
How to calibrate samsung top load washing machine
there should be another 7 letters/numbers after wa14 maybe the full model number is on the back or in a manual
Sep 19, 2015 | Samsung WA5451ANW 4.7 cu. ft. Top-Load...
Change heating element Samsung Dv5451aew Front Load Dryer
On most front load machines the first piece that must be removed to access anything is the top. There are a couple of screws/bolts at the top rear that secure it. It then opens, sometimes by sliding it slightly rearward fist to release the catches. Then you can start removing other panels.
Sep 16, 2014 | Samsung Dv5451aew Front Load Dryer
How can I best access the pump on my Samsung front load washer? I don't know how to remove the front panel
Some samsung washers have the water pump located in the back of the machine. If your model does not have a small door located in the bottom of front than remove back service panel to access the water pump.
Jun 21, 2017 | Samsung WF328AAW Front Load Washer
What are the setting we have to set in Samsung washing machine WA85VPL fully automatic
Manual
John C.
Sep 17, 2011 | Washing Machines
My top loading machine always stops on Rinse
Did you find a solution? Mine is doing the exact same thing : ( Thanks.
Mar 22, 2010 | Samsung SW62ASP Top Load Washer
Samsung SW65ASP2 top load washing machine only lets water in slowly.
there may be an obstuction at the wateer inlet valve turn off your water and remove the hoses and check for anything that would be restricting the water flow if this does not work you may need to replace the inlet valves.
Jan 31, 2010 | Samsung SW62ASP Top Load Washer
After my washer spends the rubber comes
Do you mean the door seal has come loose.
Disconnect the machine from the power. Open top hatch by removing two screws in the back and sliding top lid back and up to remove.
Check down from the top of the machine and feel around the door seal. Make sure there are no holes or tears in the seal. Try and refit seal. there is a metal ring around the drum and also around the front panel where the door seal joins. Make sure the are tight and fit in properly.
Let me know if I didnt understand the problem.
Good luck.
Ash
Oct 22, 2009 | Samsung WF448AAP Front Load Washer
Samsung washing machine F1245 control panel stuck??
I have Samsung/korea-SW905Washer.When power is switched on the Fault-'1E' appears. what could be the reason.( narrate list of control component failure).
Bought in the year 1996 at India ( voltas mega washer top loading-7.5kg) and working till last month.
after few wash cycles the machine stopped at aforesaid indication and it is not functioning due to above fault indication'1E'
provide me remedial measures or electronic control board circuit.
May 29, 2009 | Samsung WE356A5W Washer/Dryer Laundry...
Washing Machines Logo
70 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
