Question about Minolta Di251 All-In-One Printer
Di 251 code c0214 - Minolta Di251 All-In-One Printer
  • Minolta Master
  • 6,161 Answers
Power Supply, High Voltage Power supply or the Master Control Board, machine on a good surge protector if not after getting these part recommended you get one. Did you have a brown out or a black out. or electrical failure, 1st go with the Power Supply since that feed the other two, then the High Voltage then the Master board, all of this is predicated if you can get these boards the Di251 Series is a Legacy Minolta Series now Konica Minolta, good luck try below web site as a start to find parts
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Posted on Feb 19, 2015
3 Suggested Answers
Nitrotrike
  • 589 Answers
SOURCE: minolta di 251
That's a toner bottle motor failure code.
Check that the bottle isn't "jammed" into the machine and moves freely.
Posted on Jan 11, 2008
Daniel S
  • 4323 Answers
SOURCE: Problem on Minolta DIALTA DI
Hi
Error code C070 or C0070 is related to toner not seated properly. Power off the machine and gentlly take out the toner bottle. Turn on the machine without the toner bottle, let the machine go through its normal routine when the indicator comes on for toner install toner bottle. If the code comes back you have a problem with the Toner Bottle motor, gear, or Main Board.
C0500 means Heating Roller warm-up failure. Open and close the right side door. There's a switch hidden under the frontcover activated by the side door. Sometimes the grey plastic arm attached to the sidedoor is not actuating that switch properly.
To reset the error Localize hole on right side of control panel. In hole is switch. Press it. Machine will restart. Enter "3" from the 10-Key Pad when dot appears at the center on the left side of the screen while the start-up screen is being displayed. (Enter code 0000) You'll enter Initialize Mode. Press Trouble Reset. If error apears again, remove Fixing Unit and check lamp, thermo fuse or thermistor. Hope this helps... Please post back if you need more information.
Daniel
Posted on Jan 01, 2011
Am konica monlta c452
C-2553 is Magenta image unit so replace the unit, as for the 0214 0215 no such codes for that model of machine
Feb 18, 2014 | Konica Minolta Bizhub C452 Color Copier...
Code C-0214
C0214 Image transfer voltage problem
refers to high voltage - will need a service call
Nov 05, 2013 | Konica Minolta Bizhub C364 Color Copier /...
Di minolta 251 diplays the code c0500 if when the wires are connected properly and sufficient current is supplied. What do I do to correct it? Thanks.
Check Your Fusing unit. if there is any possible changes on it maybe wires wer cut off, or some pieces of paper left inside of it (fusing unit) blocking the thermostat or just simply buy an AVR.
Dec 08, 2012 | Konica Minolta Office Equipment & Supplies
Trouble code c-0214
Enter into service mode then prees machine then trouble the machine will display error code chat select C0214 and press C. Is should sort out your problem.
Bwalya
Jul 06, 2011 | Konica Minolta Bizhub c203 Copier
Problem on Minolta DIALTA DI 251? my copiers haVE detected problemS, one says code M4 What are the problems?
Touch the Utility, Meter counter, Stop00 stop 01, now in service mode now stop 9 select copy kit counter then select mode 1
M-4 is set up to monitor what ever the tech wants it to be
Jun 08, 2011 | Minolta DiALTA DI2510F All-In-One Laser...
How to reset a minolta Di 251 after replaceing Imanging unit
should when you replace the image unit with a new one, then the new one is not new
Jan 08, 2010 | Minolta Office Equipment & Supplies
MINOLTA DI ALTA 200 Y 251. NEEDS TO KNOW HOW TO MAKE IT SCAN.
well..the scan function is accessible from the main panel, OR the desktop manager. do you have a user manual for this elegant device?
http://tinyurl.com/6qcpgy
Aug 19, 2008 | Minolta Di351 All-In-One Laser Printer
Minolta di 251 srror code coo7o
Jan 11, 2008 | Minolta DiALTA DI2510F All-In-One Laser...
Minolta di 251
Jan 11, 2008 | Canon CLC 5100 Copier
Minolta Di251 All-In-One Printer Logo
76 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
