Question about Toshiba Computers & Internet
How to open bios in toshiba tecra a6 when i forgot the password
TECRA A6-EZ6312
4 Suggested Answers
kenners2k
  • 89 Answers
SOURCE: I need to disassembly one toshiba tecra a6 PTA60U
Here you go check out this handy website.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-M105/take-apart-notebook-1.htm
Hope this helps
please Rate!
Posted on Jan 26, 2010
  • 17 Answers
SOURCE: Toshiba Tecra a6-ez6311 Removing Power-on Password
Unplug and open laptop and remove BIOS battery and leave unplugged and this will reset BIOS.
Posted on Jun 04, 2010
mariolands
  • 2296 Answers
SOURCE: the password bios is closed.
We can't send you the password, but you can reset it. To reset the BIOS password read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Posted on Jan 03, 2011
I have toshiba tecra a6-ez6312 on win 7 32 bit. I replaced the user accessible memory slot with a 2GB module. I'm unable to boot - beeps and black screen. Do I need to also add a 2gb memory
Here is the quick manual. Tells all you need to know about memory. Your computer only takes PC 4200 or PC 5300 DDR2 ram. If you mix pc 4200 with pc 5300 it will not work, you can have 1 gig and 512 meg as long as they are the same speed of PC4200 or PC5300. YOu need to check which you have.
Jan 31, 2015 | Toshiba TECRA A6-EZ6312 (PTA60U05T00F) PC...
Tip
Toshiba Bios Password Deletion Satellite P100 & Satellite Pro P100 With...
With notebook turned off;
  • Open Wi-Fi Cover
  • Remove Mini Card Wi-Fi card
  • Locate & Short Out JP8 for 5 Seconds
  • Remove short and turn on
  • NO BOOT
  • Press & Hold Power button to turn off
  • Turn on again & password is cleared
Satellite L10, L20, L30 & Satellite Pro L20
  • Open Wi-Fi Cover
  • Locate & Short Out JP1 for 15 Seconds
  • (Satellite L10)
  • Satellite L20/Pro L20 short out G1
Satellite M100 & Tecra A6
  • Open Memory Cover
  • Remove Memory
  • Remove Black plastic insulation
  • Locate & Short CMOS CLR1 for 15 Seconds
NOTE:
All the following models use the same password removal process.
Satellite: 17xx Series, 1000, 1110,1130, 1200, 1900, 2430, 3000 P20,P30, P33, A30, A70, A80, M40X, M50,M60, M70, M100
Tecra A3/S2, A5, A6
  • The jumper is always located under or near the memory modules
  • Depending on the model the jumper could be labelled J1, J2, J5, J7, J9 or CMOS CLR1 (M100 & A6)
Satellite A100 & Tecra A7
  1. Remove Strip cover
  2. Remove 2 x K/B screws
  3. Move K/B Unit up but don’t disconnect
  4. Release & Remove Mini Card Wi-Fi Card
  5. Locate & short C88 Pin 1 & 2 together
  6. Power on Machine while still shorting Pin 1 & 2
  7. As soon as the TOSHIBA logo appears, remove short
  8. If machine boots, Password has been removed
  9. Satellite A100 (PSAA2A-02C01N)
    1. Remove Memory Cover from base of machine
    2. Release & remove right side Memory Module
    3. Lift black plastic insulation
    4. Locate & short PAD500 Pin 1 & 2 together
    5. Power on machine while still shorting Pin 1 & 2
    6. As soon as the TOSHIBA logo appears, remove short
    7. If machine boots, password has been removed
    TECRA A4 & Satellite M40
    1. Open modem & Wi-Fi card cover
    2. Remove mini PCI Wi-Fi card
    3. Lift up black plastic
    4. Locate & short C738 Pin 1 & 2 together
    TECRA S1
    1. Open palm rest cover
    4. Locate & short C5071 Pin 1 & 2 together
    TE 2300
    1. Remove 2 x B12 screws from bottom of system
    2. Remove strip cover
    3. Remove keyboard screws 1 x B2.5 & 1 x SF4
    4. Remove 1 x 4mm screw & Wi-Fi cover
    5. Remove mini PCI Wi-Fi card if fitted
    6. Locate & short points as shown in picture below
    7. Power on machine while still shorting points
    8. Short for 5 seconds
    9. Nothing will appear on the screen
    10. Turn system off holding down power button
    11. Password is now removed
    Satellite A60
    1. Open Wi-Fi slot cover
    2. Lift up black plastic
    3. Locate & short C561 Pin 1 & 2 together
    4. Power on machine while still shorting Pin 1 & 2
    5. As soon as the TOSHIBA logo appears, remove short
    6. If machine boots, password has been removed
    If you need your Toshiba bios password removed and your model is not listed above then chances are it's a procedure that can only be done at an authorised repair centre.
on Jun 08, 2010 | Computers & Internet
Toshiba Tecra A6 laptop sound has suddenly stopped working
Have you tried downloading and reinstalling the sound driver from http://support.toshiba.com?
May 25, 2011 | Toshiba Tecra A6-EZ6411 (PTA63U-003003)...
The password bios is closed. Its model is TECRA A6. Can you send me the password
Dec 29, 2010 | Toshiba Tecra A6-EZ6311 Notebook
Jun 03, 2010 | Toshiba Tecra A6-EZ6311 Notebook
How to remove BIOS memory cache
Since it is a Toshiba Tecra if you are not worried about losing data on the laptop you can try turning on the laptop and start pressing the zero key. It should give you the option to restore your laptop if you haven't deleted the restore partition on the laptop.
Mar 20, 2009 | Toshiba TECRA A6-EZ6312 (PTA60U05T00F) PC...
Non responsive
ok start your computer pressing f8 key and boot in safe mode then you can goto system tools and restore your computer to the time it was good earlier hope it works
Jan 27, 2009 | Toshiba Tecra A6-EZ6311 Notebook
Tecra a6 device manager , drivers req ethernet, mass storage, network controller, pci driver
hey just go to thoshobas website and select support and then fing your model & download the driver !
Jan 07, 2009 | Toshiba Tecra A6-EZ6311 Notebook
Toshiba Tecra M4 Bios Password Reset
there are two way
open take cmos you will see one littile batry in you laptop when you open take that battery out for mint then put back in
secound way is
jummer setting
Aug 15, 2008 | Toshiba Tecra M4 Notebook
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
