My hard drive was removed from my dell xps 420 with out the data being backed up. Is there a way to recover the data and programs? or is the computer now junk?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 52 Answers
Computer is not a junk if u install new HDD i sould work...to back up ur data u can visit a local hardware tech and he can guide u....only if u are not able to use that HDD in any other PC to remove data
Posted on Feb 13, 2012
Beni S-P
  • 1006 Answers
SOURCE: Hard Drive Data Recovery
Yess it is:
Put that hdd in another pc who have WIN XP SP2 and REMOVE JUMPER from HDD!
Download this program and recover your data:
DOWNLOAD
Posted on Dec 26, 2007
  • 3 Answers
SOURCE: xps 420 keeps freezing or going to blue screen
change/clean the cpu fan or try to reduce heat arround the processor
Posted on Jun 24, 2009
kevin000
  • 1847 Answers
SOURCE: dell xps 420 desktop intel manager states missing hard drive raid
Do a scan disk.
Seems issue with the drive.
Posted on Jul 07, 2009
joecoolvette
  • 5660 Answers
SOURCE: My Dell XPS 420 will not turn on. Power light
Hey! Nice Computer! ( At least while it was working! Specifications show some high-end hardware parts)
Steady amber light on the Power On light, means a bad power supply.
The Dell XPS 420 uses the standard ATX style of power supply found in 90% of computers out there.
(Personal computers. Not the Cray Supercomputers!)
This is Dell Support, and the User Manual - Removing and Replacing Parts - part of the manual,
http://support.dell.com/support/edocs/systems/xps420/en/OM/HTML/parts.htm#wp1466871
From Me:
1) Computer unplugged from power, computer case open. TOUCH the metal frame BEFORE you reach inside.
Your body carries Static electricity.
Static will fry out computer hardware components.
You won't see it, or feel it.
Computer unplugged from power, you are safe.
Touch the metal frame Before reaching inside, your computer is safe.
Should you get up for any reason, walk away, then return, Touch the metal frame again)
You either have a 375 Watt, or a 425 Watt power supply.
I would recommend a power supply with more Wattage, and more Amp's on the 12 Volt power rail.
The Dell XPS 420 comes with an Intel Core2 Duo processor, or an Intel Core2 Extreme processor.
These puppy's can use a lot of power when gamin', or other intense programs are being used.
The Nvidia GeForce 8800 Series of graphics cards offered, use a lot of power when maxed out.
The motherboard with the Intel X38 motherboard chipset, uses a lot of power.
I would recommend a 600 watt power supply for a replacement.
My recommendation would be an OCZ StealthXStream 600W
Why?
1) If the temperature of this PSU is kept under 118 degrees Fahrenheit, the PSU can put out 728.8 Watts reliably. (47.9 degrees Celsuis)
2) It has Four - 12 Volt power rails.
EACH power rail can handle 18 Amps.
That's a total of 72 Amps!
3) It has all the power cables you'll need.
A) 20 + 4-pin ATX motherboard power cable
B) 8-pin 12 Volt power cable (8-pin EPS)
C) 4-pin ATX power cable
D) SATA power cables [ 3 ]
E) Peripheral power cables, (4-pin Molex) [ 6 ]
F) 6-pin PCI power cables. [ 2 ]
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3092557&CatId=106
Not advertising for the above website, nor the PSU manufacturer. Recommendation supported by personal preference, and experience.
Information about the various PC power cables and connectors,
http://www.playtool.com/pages/psuconnectors/connectors.html
Posted on Jan 04, 2010
  • 78 Answers
SOURCE: Dell XPS 420 won't boot at all not even a BIOS screen
the bios is not starting ...
check the memory ram if its inserted correcly or
chek the beeps wen cpu starts and
http://kb.iu.edu/data/afzy.html
se if tha link is help full
Posted on Apr 29, 2010
How i recover my data?
download a free program called RECOVA.......this great and free program will scan your hard drive and then give you a long list of programs and files to recover. Warning, if you have installed other programs on this computer you may have totally overwritten your lost data! Good luck
Feb 26, 2015 | Hard Computers & Internet
Dell hard drive had gone failure know need to data recover?
Remove the hard drive and put it into an enclosure.Plug it into another computer as a slave.Then you can copy your files on it.
If it shows up in 'my computer' as a drive letter(like E: drive) but you can't access it,you can recover data from hard drive with data recovery program.Tenorshare data recoveryis a professional data recovery software that can recover data after deeply scanning your hard drive to look for lost data due to drives crash, physical damage,system sabotage, virus attack etc.You can get it here: http://www.any-data-recovery.com/product/datarecoveryprofessional.htm After you recover your data,you can format it to check out whether it can be fixed.
If the hard drive can't be detected,you can try this way.Put it in a zip-lock bag and put it in the freezer for overnight. Then while it's still cold plug it into the computer and you may be able to view it in 'my computer'. And if needed, run the recovery program to recover your data on it.
If it fails, you will have to go to a recovery office where supply data recovery service but let's hope not because it will cost you a lot of money and whether they can recover data is not guaranteed.
Sep 21, 2011 | Dell Latitude C640 Notebook
Everything is wiped out and there's absolutely no files or pictures or music or anything. I really want them all back! Please help me step by step with my computer! It's known to be XPS 410 PC...
How did the computer get this way?
You'll have to gauge how important the data you've lost is to you, as it's fairly expensive to have a drive recovered through a data recovery service.
drive recovery services Google Search
There is software that may recover some or all of your lost files, but you would want to install and use the software from another computer to read the drive that you're trying to recover data from.
drive recovery software Google Search
May 19, 2017 | Dell XPS 410 PC Desktop
I have a Dell xps 1530 Laptop , that service tag is J4WMD3J , i try to change my cmos password at that time system will goes off after that my old password and new password r not working, so that i cant...
If you have not placed a password on the hard drive then you can recover your data from your hard drive by removing the hard drive from the laptop and plug it into an USB hard drive adapter.
Then plug this USB adapter into a working computer's USB port and this computer will see this as an external storage device. You can then open the various folders and files to back up your data.
Aug 29, 2010 | Dell Inspiron 1318 Laptop Computer PC...
Fix error code 146 dell xps 1330
Error 146 pertains to hard drive error. If there is still a chance to back up your files do so as this kind of error indicates a faulty
hard drive.
Aug 16, 2010 | Dell XPS 420 (dxcwqj1_2) Intel Core2 Duo...
When i try boot my dell xps 420 it states that there is no boot device available. Why does it say this?
A boot device stores your operating system (i.e. Windows), and is usually your hard drive, but can be any storage medium such as a floppy, usb flash drive, or even a cd rom. When you turn your computer on, your motherboard looks for your OS on any of the storage devices specified in your bios, in the order specified to look first (Ex. Boot order: 1. CD-Rom, 2. Floppy, 3. Hard Drive, 4. Network). Your Dell is telling you that it can't find Windows on any of these devices. Most likely cause is that your hard drive stopped working, your Windows boot.ini file became corrupted, or you have a USB device plugged into your computer, and it needs to be unplugged before turning on your computer.
Jul 05, 2010 | Dell XPS 420 PC Desktop
DELL XPS M140 MXC051 LAPTOP BIOS PASSWORD
Most laptop or notebook computers feature enhanced BIOS security, and BIOS passwords on laptops are hard to bypass. Several companies offer laptop security chip services that can be used to bypass the BIOS password on Dell laptops or notebooks and reset the security. They can provide a master password from the Dell Service Tag of your Dell laptop. This master password will allow you to bypass the existing password and enter the BIOS and reset the unknown password. To generate the master password they need to know the Dell Service Tag of your unit. Dell Master Password Recovery does not require soldering or disassembly of the laptop and supports most Dell models.
Dell BIOS passwords can also be reset by replacing the laptop security chip. Passwords can also be recovered from security chips that have been removed from laptop or notebook systems. These passwords may be required to attempt to unlock protected hard disks. Passwords recovered from these chips are the original BIOS passwords and may be the same as the hard disk password, but are not guaranteed to be the same and may not unlock the hard disk.These are usually damaged in the process of recovering the passwords and are not suitable for replacement into a computer.
Apr 08, 2010 | Dell Inspiron XPS M140 Notebook
Xps 420 keeps freezing or going to blue screen
Same with my Dell Vostro 420. At this rate I will just buy a new PC as I am wasting too much time on this. We tried usual stuff like cleaning inside, making cooler, removing certain virus software, still no luck. I have to restart 4 times a day and keep saving material. Can only restart by turning it off by pulling out power socket.
Jun 24, 2009 | Dell XPS 420 PC Desktop
Hard disk not detected
Hi there.
It depends on what state the hard drive is in on whether you can recover any data from it. Does the hard drive spin up or receive any power at all? if it does does it make any strange noises like clunking for example?
If you can tell me what state its in i can give you a better idea on what to do to attempt recovery of data.
Regards
Mar 14, 2009 | Dell XPS 420 PC Desktop
Computers & Internet Logo
David Payne
David Payne
