Question about Uniden V49753 Two Way Radio
Have purchased two sets radios s/hand. Will not work on any channels
Will not work radio to radio. As I have purchased s/hand could they be locked to a certain channel
Can you provide more details? What's the model of your radio? Or have you read the manual completely? There are radios that can't capture all channels. To be sure, ask the store where you bought it.
Posted on Feb 13, 2012
  • Jay Smith Sep 16, 2012
    HI Yes read the manual completelt, Terrain 750 , They were bought together as a twin set. Worked yesterday my daughter had one in the house and i had the other just out the back, Tried to talk to her and it wouldn't work. No -one had changed channels or pressed any buttons. Bought in argos
jdn74
  • 35 Answers
SOURCE: Hi, I have a Uniden uh043sx-2 or DT043.When I
Here is the manual.
Posted on Mar 26, 2009
SOURCE: 30 channel 10 band radio scanner
i dont have the instructions
Posted on Aug 04, 2008
  • 181 Answers
SOURCE: 1 radio wont receive the others transmission. they are on the
on this probablaby is a tone that has to be swithed off using the menu button and another up and down.use menu till 1 is flashing then press down till 1 says 0. this should fix problem
Posted on May 24, 2009
supernova278
  • 1932 Answers
SOURCE: I have a uniden GMR1448
Check whether the channel and the sub code are same?If this is not same it will not work.
Put the sub code to off.Follow the below steps
1.Press chan tone/scan in channel select mode.The subcode indicator will flash. 2. Press the UP arrow  or DOWN arrow key to increase or decrease the code number displayed.You can also select oF (OFF) at this stage. 3. Press chan tone/scan to exit the Menu.
Thank You
Posted on Nov 16, 2010
bikerdiy
  • 10 Answers
SOURCE: I HAVE A PAIR OF
If you buy the same brand/model radio it will work perfectly as long as all the devices are on the same channel.
If you buy a set from another manufacturer make shore that they are compatible.
Posted on Jun 29, 2011
Two sets of Motorola Walki Talki radios will not communicate.
In addition to the channel and privacy codes, some Motorola two-way radios have a feature called Eavesdrop Reducer where you have 3 scramble settings available; perhaps you have this set on one of sets of radios but not the other. It should be something like that because otherwise there is no reason that by setting the radios to the same channel and privacy code they wouldn't be able to send/receive to each other.
Nov 24, 2013 | Motorola Walkie Talkie 2-Way Radio
W do I turn off squelch control on a digitech DC-1065 marine radio hand held 5 Watt
Hi David,
Before I try to give advice, I need more info.
I possess a Digitech DC1065 UHF 80 Channel CB hand held, so there seems to be some confusion here.
I live near Perth, Western Australia.
Firstly, How many channels does your radio have?
If the answer is 80, then what you have is a UHF CB, not a marine band radio.
Marine band is VHF with 87 Channels, in Australia that is, and the default channel is always 16.
Digitech are an Australian radio manufacturer, so you'll get great backup service.
If your radio is not defaulting to Ch16, then I am right about it being a UHF CB.
Therefore, it is useless for VHF anything, let alone Marine band.
I'm almost 100% sure this is a UHF CB in your possession.
Try this to prove me right please.
Reply to me with your Country and nearest city, I'll then be able to find a solution for you real quick, though I believe I already have.
Looking forward to your response.
Regards,
Peter
Dec 21, 2012 | Motorola Walkie Talkie 2-Way Radio
Transceiver is locked on Channel 1. Up/down buttons and channel knob have no effect.
Hi Bob,
Firstly, you say you purchased the unit NIB = New In Box, so that would mean you should also have a user manual that came with it.
If this is not the case, take the whole box and dice, together with the purchase receipt to the place of purchase and ask for a copy of the user manual, which won't cost a thing.
If, on the other hand you do have the manual, read the instructions carefully, before you turn the radio on.
It will guide you step by step on how to get your radio setup & running.
And if frequencies are required to be programmed into it, it will tell you exactly what is required to do so.
If during the course of setting up your radio for reception, you encounter problems, then towards the back of the manual there will be a trouble shooting section.
All being well, you should be up and running, if you follow my advice.
I hope I have assisted you.
Best regards,
Peter
Nov 19, 2012 | Vertex Standard VX-1700 FCCver. HF...
I have purchase a midland 75785 cb isit compatable with uk chanels
  • For 11 meter (CB) the standard 40 channels will be the exactly same as the "EU" set of frequencies (channels). However the "UK" 11 meter (40 channels) and the U.S.A. 40 11 meter (40channels CB) will not work together at all. This includes any actual Citizen Band radio, excluding Export 10 an 12 meter radios often labeled as "CB'S" which they are not.
  • Hope this helps.
Oct 29, 2011 | Midland 1001Z 40-Channels Base CB Radio
We just purchased the Motorola RDU 4100 radios. 8 of them to mix in with 4 others of the same model number. radios were working fine up until recently when 3 of the radios are now broadcasting the same...
Reset to Factory Defaults (Pg. 34)
Reset to Factory Defaults will set back all radio
features to the original factory default settings.
To do so, press PTT, SB2 and SB1
simultaneously while turning ON the radio until
you hear a high tone chirp.
Here is a link to the user guide: http://www.twowayradiosfor.com/pdf/RDX-Non-Display-manual.pdf
Programming instructions begin on page 36.
Best regards.
Aug 15, 2011 | Motorola RDU4100 Two Way Radio
I have a motorola mv11c and it works fine and I just purchased a pair of motorola mv21cv. They must be on a different frequency my question is how do I change the frequence on my mv21cv radios to be...
Hold in the PTT button while you turn on the radio. It will announce the frequency number. You can use the PTT button to change the number. Then press the Monitor (small possibly red) button to lock in your setting. The next number your radio announces will be the Code. Use the same method to change the code if needed. Then press the Monitor button to lock in your setting. Once you have set both your freq and code you can turn the radio off, then turn back on normally and use the radios.
Best regards.
Jul 22, 2011 | Motorola MU21CV (1 Channel) 2-Way Radio
I jus was wondering, can the cb radio and the handheld radio transmit on the same channel? Im a security officer and im interested in purchase a cb radio so we can use it at work but i dont know if its...
CB radios and hand-held CB radios can operate on the same channel and be in contact with each other. Other hand-held radios do not operate on the same frequencies and even though they may have channel numbers the channels have different frequencies and will not operate to CB radios.
Oct 29, 2010 | Cobra 150 GTL DX Base CB Radio
Can't change channel of a Motorola Visar Handie-Talkie FM Radio Model: H05RDD9AA4DN It seems that this radio operates in only one channel and I need to be able to chanmge channels. However everything else...
The Visar has a channel lock feature. If you hold down the two channel buttons at the same time, it will do one of two things depending on the settings. Either the channel will lock, or the channel numbers in the LCD will flip.
If you press the channel button and the "popples" "pop" (for lack of a better word) then the channel selection buttons re most likely OK. To fix it you just press both channel buttons at the same time for about 5 seconds. It will beep and you should be able to change the channels. If not, then it needs to be repaired.
Sep 17, 2009 | Motorola Radio Communications
Channel Lock
To lock the keypad on this unit do the following:
1. Press the SEL key to enter the menu mode.
2. Press the SEL key repeatedly to scroll through the menu funcions until the keylock indicator appears. (This appears as a padlock icon on the bottom left hand side of the display.)
3. Press the CHANNEL key to toggle between Keypad Lock On and Off.
4. Wait 10 seconds for the radio to automatically return to normal operation mode.
Best Regards,
Ken
Go Ahead. Use Us.
Mar 13, 2008 | Uniden GMRS680-2 (14 Channels) 2-Way Radio
Uniden V49753  Two Way Radio Logo
57 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
