Question about Epson Televison & Video
Why does my projector just turn off but the fan keeps runing for about 5min. Thn I have to reset it by unpluging it thn turning it back on
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 67 Answers
The fan is still cooling the unit after the power goes off. Let it run!
Posted on Apr 10, 2014
2 Suggested Answers
SOURCE: HDTV R52WH74 TV WILL NO TURN ON
Okay, so maybe I can't solve it, but mine was doing the same thing and I called the TV repair man. After $500 (a new power supply board was installed) all is fixed.
Posted on Dec 30, 2008
Transfer sms from phone to memory card in nokia x2 01
hey... Guyzz i knw how to move a msgs and contacts for other phn.. Just go to setting and select sync and backup.. Thn create a backup file.. Thn choose the back up files which tat maybi contact msg setting.. Thn click done... It starting to backup.. Ok try it.. or go to. Phn switch choose coppy from this thn select the file which u want... Thn click done..it asking for switch on the bluethooth thn send ur files ok..
Nov 25, 2012 | Cell Phones
Hiya my 6500 slide when i turn it on nokia comes up thn thy shake hands thn the screnn turn on and off thn it stays off can u tell mi whats wrng wiv it plzz
the power is not enough to stay your phone on. Your battery is ok, but the phone is not on its perfect condition. Go to nearest phone technician for check up. thanks
Jan 09, 2011 | Nokia 6500 Slide Cellular Phone
Hi ihave a fiat brava 1.2 x reg in the morning the car will not start it turns over rather lazy and only 2 or 3 turns and the digital clock trip meter reset to zero.it has new battery earth wires ok...
It seems the battery loses power over night.
There seems to be some electrical componant chewing up the battery.
Try to remove one of the battery terminal wire at night and thn fix it in the morning and thn see if it will start without jumping, if it does thn the battery is being chewed up overnight.
If after removing the battery terminal at night and refitting it in the morning and it still requires jump start ,thn the battery is faulty.
Hope this helps!
Nov 24, 2009 | 2006 Fiat 124
My honda 400 bros is not runing right 1 plug is wet the rest is sutted up as if runing rich what would think it is
Sooted plugs proves tht the air-mixture is too rich.(too much fuel going to the combustion chamber)
You have to set the air-mixture screw on the carb/s.
Clean the carb/s, replace 'inline' filter , if you don't have one ..install one, reset float level.
It's better to also check the valve clearance too.
Fit in new plugs (gapping them to specs.) and run the engine to its normal temperature thn set the air-mixture screw...standard setting....all the way in i.e. tighten it slowly to the end making sure not to damage the tip of the screw, thn 2 and half turns outwards to 3.
Start the engine....run to normal temperature and thn reset the air-mixture screw +/- either way.
Hope this helps!
Oct 24, 2009 | 1991 Honda NT 400
My 2007 yamaha v star 650 keeps blowing the fuse that goes to the turn signal brake lights and horn
There seem to a 'live' wire (in the turn signal, brake light or horn circuit) touching the frame of the bike and thus the fuse blowing.
You will have to trace out the short-circuit.
You can start wth removing the connections to the turn signals thn fit the fuse and see if it still blows ....like wise remove the wire to the brake light and thn check if the fuse blows, same to the horn.
In short ..you can remove all the wires connections to these and thn fit the fuse and refit the wiring connections one by one ,where the fuse will blow after connecting the wire to say brake light thn the problem is at the brake light wiring ....likewise to the others ...onces you identify the circuit tht has the problem thn it will be easy to trace it and rectify it.
Hope this helps!
Oct 08, 2009 | 2007 Yamaha V Star Classic
Hi, My Acer Aspire 5570 has a blank screen and seems dead. It turns on and the fan comes on but then has no other functions when any keys are used. I have found other information relating to different Acer...
first try to hard reset the system,you do it by removing the power adpter from the laptop the also remv the battry thn press power bttn for 60 sec thn put evrythn 2gther,if tht ddnt wok u cn tell me wts happenin thn will help u out
Aug 13, 2009 | Acer Aspire 5500 5570-2609 Laptop
My 2000 bugs a/c will not cool. It will work sometimes. The compressor is not kicking on when it not working. The freon is fine. I changed the fan relay and the fuse on the battery box looks fine.
check if the compressor has the apporpiate amount of pressure of gas and if its ok thn probably when next time u start ur car just wait for 3 mins and thn turn on the fan before starting the ac. it will work............ luck
rate meeeeeeee.......
Jul 08, 2009 | 2000 Volkswagen Beetle
Won't turn on.
hi,
try unplugging it and thn plug it back if the light comes for 3-5 sec. and goes off thn you will hear another click noise when it goes off. you never get a picture or sound.If im right thn there are several circuits in the tv that might cause this. the most common are the power supply and the convergence circuits. a cost of a repair for either will range around $400.00. this is a great model and well worth a repair.
good luck:)
Dont forget to rate me as fixya..
Jan 30, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Televison & Video Logo
100 people viewed this question
Top Epson Televison & Video Experts
janman
Terry Dovre
Terry Dovre
Are you an Epson Televison and Video Expert? Answer questions, earn points and help others
