Question about Philips 50PF9631D 50 in. HD-Ready Plasma Television
Red light flashes
I have Philips 50pf9631d and when i turn on the tv green light turn on, then red light flashes for 6-7 times. is there any suggestion u can give me? thank you
  • 3 more comments
  • stevenbowen Dec 28, 2008
    red light flashes 6-7 times when i try and power up. 50pf9631d/37
  • mikemarlow66 Dec 31, 2008
    kids were playing wii not for more than 30 min and the tv shut down would not come on until i unplugged it and then plugged it in. i then had a fair picture but white noise for sound i turned it off again and it seems to be ok but its only two weeks old and i dont know what caused the problem
  • bbrutcher Jan 02, 2009
    our tv started this same thing 1 day after warranty expired philips said too bad 130 dollars just to have someone come to the door. never again will we buy another philips product
    turn tv on and green light comes on and then turns red blinks 6 or 7 times slowly then 3 times rapidly. philips will not help as product is out of warranty. tv started this 1 day after the warranty expired. help!!!!
  • markp-22 Jan 22, 2009
    I'm experiencing the same issue. When I attempt to turn the TV on, I hear a "click-click" sound coming from the rear of the unit. At that point, the LED on the front right panel turns red, flashes 6 times quickly and then flashes another 3 times slowly.
    I unplugged the unit and let it sit for an hour, then plugged it in, and unplugged the unit repeatedly about 10 times. Each time I plugged the unit back in, I tried to turn power on.
    Occasionally, the tv will turn on again and appear normal for several days.
    I have called the service tech Philips referred me.... but have not heard back from them yet.
    Clearly, there is an electronic part needing repair.
This is a well known and very common problem with all Philips plasma tvs 42 and 50 inch. The problem is they used under rated capacitors in the power supply. If you have electronics experience or a friend that is, remove the cover and look in the back for malformed or leaking capcitors. Replace them and see if that takes care of the problem. The caps only cost $2 or $3 each, so the cost to try this is pretty reasonable although you might have an added cost of buying beer for your electronics friend. If this does not fix your problem you are down to replacing boards that can be purchased around $300 ea.
I have found my set will come on "finally" after I get the back of the set warmed up and the bad caps finally charge up. Hope this is useful.
Posted on Feb 27, 2009
50PF9631D won't turn on... red light flashing/blinking 6 times
Your TV main board is damaged and you need a new one. You can order one on ebay and fix it yourself. Make sure you have the TV model/serial number on the back label of the TV to have the right part when ordering.
Jan 09, 2013 | Philips 50PF9631D 50 in. HD-Ready Plasma...
TV will not switch on. Light goes green for about 5 seconds and then flashes red
try to press and hold the power button for 15 seconds and then restart your tv. if it doesn't work, you might need to turn it in for repairs.
Jan 26, 2011 | Philips 50PF9631D 50 in. HD-Ready Plasma...
We have the power issue with the philips plasma 50 in (Model PF9631D) it turns itself off after turning on and then the red light flashes 7 times. (it is out of warranty by 6 months) My question is we...
Any big screen tv shops can repair this tv power supply board issue.The shops prices are depend on them.But useally the repair cost will be a third or half of the priced of a new tv.
Dec 04, 2010 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Plud the tv in and a click sound is heard like the tv is turning on but in 10 or 15 seconds green light goes off and a red light starts to flash. It flashes 4 times per cycle.
You may have the bad capacitor issue others have had in the power supply. Google your model number and the words "replace capacitors" for the solution. There is also a Youtube video. Also, check the fuses.
Sep 13, 2010 | Philips 50PF9631D 50 in. HD-Ready Plasma...
I have a philips 50'' television, model #50pf9631d/37 with a flashing red light on power light, sometimes i unplugged the unit about 5 or 6 times for about an hour, then try to turn it on quickly with the...
Two problems: first, tv turns off for about 10 seconds after being on awhile, then turns back on. 2nd, picture will sometimes go black horizontally displaying only half of the upper screen. This will go on for about an hour off and on.
Dec 31, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Philips 50pf9631d/37 no picture sound. Red light flashing
hey crs246, I have the same exact problem with my philips tv same model. Have you gotten any help that you can share with me. Any help would be appreciated.
Dec 15, 2009 | Philips 50PFP5332D 50 in. Plasma...
Phillips Plasma will not turn on.
that code is a power supply failure in philips you can get the part from Andrews Electronics
Dec 02, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Philips 50PF9631D Plasma
First step....check power supply components.....research
similar Model & problem.................T.
Mar 22, 2008 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Philips 50PF9631D 50 in. HD-Ready Plasma Television Logo
895 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
