Question about Konica Minolta Office Equipment & Supplies
Di470 problems Machine giving CODE 13F5, C10XX, C11XX
2 Suggested Answers
team leader
  • 40 Answers
SOURCE: my machine Di470 having problem
this problem in DFsection you most check and clean it maybe there is small paper on the sensor check it
Posted on Sep 01, 2010
Replace the print head, the print head houses the LASER for the machine
Apr 09, 2014 | Konica Minolta Office Equipment & Supplies
Minolta Di 5520 code Solution C-13f5
Yes there are 2 soft switches...... left side is for trouble reset.
Remove fuser unit from copier
Reset code co05XX
The copier needs to give you a scree with wait for warm up; if not some thing else it's going on
If you get the wait for warm up ...eventually you'll get a C05XX code
Reset and test it with the fuser unit in.
Troubleshoot fuser unit in case you get another C05XX
Tom
Apr 09, 2014 | Minolta bizhub 250 Black and White Copier
C-13f5 Code release
Print Head LASER section is bad Power off then On if it comes back look to see if you can get a LAASER Print head for your machine
Apr 09, 2014 | Minolta DiALTA Di183 Copier
Minolta Di 5520 solution code C-13f5
Sir/Mam either the code is wrong or the model is wrong. The code is for a Minolta or some konicaminolta machines the model you list do you mean Di5510 which is a Konica machine that use Konica codes like SC35-03. Also the machine problem is listed under Bizhub 250 which I could not fine the code for either.
Error code 13f5
please re check the code could not find in the service manual
Mar 17, 2014 | Konica Minolta bizhub C450P Laser Printer
Minolta Di470 Error code C-0F24
COF24 is an AIDC or Automatic Image Density Control failure code. It means that the machine can not properly detect the developer to toner mixture or ratio in the process/developer unit. This can be caused by an AIDC sensor failure, Developer Drive problem or for some reason the machine is not getting toner as it should. Has the machine been running low on toner?
Before calling for service I would try resetting the code by opening then closing the front door(s). Do this a few times and see if the code will go away. If not then you will need a service person to diagnose and repair which part is defective.
Good Luck and Thank You for using Fixya.
Apr 22, 2010 | Office Equipment & Supplies
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
