Question about Locks & Locksmithing
What is the factory default code for a Schlage Cobra Lock
  • 963 Answers
There is no '"factory default code". Sorry.
Try Schlage.com
Posted on Feb 22, 2012
SOURCE: my schlage BE365 will unlock but will not lock
your password be365 will be unlocked
Posted on May 16, 2009
SOURCE: Schlage FE365v keyless entry lock.. Lost manual. Forgot 6 digit programming code. Need instructions to restore and set all new codes.
look on the sticker located inside the outer panelo on the lock. you are going to need to disassemble the unit but it is in there.
Posted on Aug 08, 2010
  • 963 Answers
SOURCE: Schlage Cobra lock. The lock
Please re-post your question with more specific information about the problem.
Here is the contact info you need for customer service:
Schlage Lock Company
Customer Service Department
2119 E Kansas City Rd
Olathe, KS 66061
United States Customer Support
Warranty & Technical Information: 1.888.805.9837
http://consumer.schlage.com/Service-Support/Pages/ContactUs.aspx
Schlage FAQ: http://consumer.schlage.com/Service-Support/Pages/InstallationTroubleshooting.aspx
http://consumer.schlage.com/Service-Support/Pages/FAQ.aspx
Instructions & Manuals: http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Posted on May 13, 2011
  • 963 Answers
SOURCE: I can't put in the
I don't have a direct answer, but here is the contact info you need for customer service:
Olathe, KS 66061
BE-365 installation & programming PDF: http://consumer.schlage.com/Project%20Documents/P515-858.pdf
Posted on Jun 03, 2011
  • 963 Answers
SOURCE: My residential schlage cobra
Since you seem to be doing everything properly and following the instructions, I recommend that you contact Schlage for some technical assistance. Here is the contact information:
Olathe, KS 66061
Schlage FAQ:
Posted on Aug 04, 2011
Programming code will not work
I work for factorylocks.com. We get programing questions all the time for Schlage FE575/595. The factory default programming code and PIN codes are on a sticker stuck to the inside of the front housing of the lock. You will need to take the lock off of the door to see this sticker. Once you have done so, reset the lock back to the factory defaults and reprogram the locks to your settings using the programming instructions you can find here http://www.youtube.com/watch?v=z8BgHP712eg
Feb 03, 2013 | Schlage FE595 Plymouth Electronic Keypad...
Schlage keyless lock lost 6 digit code and no sticker inside either
You will need to take the keypad look off of your
door and record the 6 digit programming code and the two factory
default PIN codes. You then need to perform the factory reset to
erase any codes and restore the lock back to the factory defaults.
This procedure is outlined, as well as the programming of the device, in the attached instructions.
http://www.factorylocks.com/PDFs/Programming%20Instructions.pdf
Regards,
Leslie
Factorylocks.com
877-345-6257 (877-34-LOCKS)
Jan 13, 2013 | Schlage FE595 Plymouth Electronic Keypad...
Schlage cobra default code
There is no "factory default code". If there was such a thing, you could bet that any good thief would have it-rendering your lock useless as a security device.
Try Schlage.com for further information.
Feb 13, 2012 | Schlage COBRA by Keyless Lock
My residential schlage cobra lock no longer locks. I have checked the batteries. Using the programming instructions, I cannot get a "normal' code to program. I always get flashing lights...
Olathe, KS 66061
Schlage FAQ:
Aug 04, 2011 | Schlage COBRA by Keyless Lock
I can't put in the 6-digit PC to my new BE365 Schlage. When the lock is idle, I put in the 6-digit code and the lock thinks I'm putting in the 4-digit UC, so it errors out. My 2 default UC codes...
Olathe, KS 66061
Jun 03, 2011 | Schlage BE365-PLY BE365PLY626 Satin...
Schlage Cobra lock. The lock will not lock
Olathe, KS 66061
Mar 18, 2011 | Schlage COBRA by Keyless Lock
I have spent over an hour looking for information on how to set a code for my Schlage BE365 CAM 619 keyless access deadbolt. I want a very SIMPLE explanation. Don't tell me to go to the Schlage web...
First make sure you have a fresh new battery installed
Next if you feel you have fiddled with it so much you can reset the lock to the factory default settings, to do this
1.Disconnect the Battery
2. Press and hold the Schlage Button while reconnecting the battery
However proceed before resulting to a reset and see if you are sucessful.
There are preprogrammed user codes already programmed into the unit
These two USER CODES (UC) are on the Yellow Sticker and on the Installation documents that came with the lock. Also the 6 Digit PROGRAMMING CODE (PC) is listed in the same location.
Assuming the lock was installed correctly and tested for correct operation.. proceed...
First.. I agree with you about the instructions.. many places they use the word "press" when they should have used the word "enter".. or phrase.. "enter the user code by pressing the corrosponding numbers".. however..
With the door open test the lock function
Press the Schlage button.. this should extend the bolt
Next Enter one of the two supplied preprogrammed user code (a) or (b) and rotate the thumbturn away from the door edge (generally to your left or counter clockwise) This should retract the bolt.
To Enter a New USER CODE (UC)
1.Enter the 6 Digit Programming Code (PC) via the key pad
2.The Schlage button will glow Orange
3.Press and release 1 on the keypad
4.Enter your new/desired 4 Digit USER CODE (UC) via the keypad
5.Enter the new/desired 4 Digit USER CODE (UC) via the keypad again (yes a second time)
The Schlage button should flash green.. signalling the program was sucessful
Repeat the lock function test using the new User Code (UC)
Make sure you write the new UC number down.
This lock will store up to 19 UC codes.
Good Luck!
Mar 11, 2011 | Schlage BE365-CAM BE365CAM619 Satin...
My Cobra MPC by schlage lock is locked. The wrong code was entered and now the led lights will not light up and the door will not unlock. How can i reset this?
Olathe, KS 66061
Dec 28, 2010 | Schlage Camelot Deadbolt Keypad, Satin...
I have the same kind of problem. I have the programming code, but when I enter it, after entering the 4 th digit the lock blinks an error thinking I entered an incorrect user code?? So I think I might have...
Restore the lock first
1.disconnect battery
2.press and release the SCHLAGE button
3.reconnect the bat and wait until SCHLAGE is no longer lit.
4. within 10 sec,press and hold SCHLAGE until SCHLAGE lights green and the lock beeps.
The lock is back to factory now.
Now add your user code.
Adding a new user code
DPC is-digit programming code
DUC is digit user code
Yellow sticker has factory 6 digit programming and 4 digit user code on it.
1. 6DPC push SCHLAGE, push 1, enter 4DUC twice.
this lock will only take 2 user codes.
Hope this helps. Leave feedback for others if it helps
Aug 30, 2009 | Schlage BE365-PLY BE365PLY626 Satin...
I can't find my key code card to my lock: MFG
Rather than list all the steps, which get lengthy when typing them step-by-step, I'll provide you with a weblink to the Schlage web site that has both pdf's and videos showing you how to re-program and operate your lock set. You can download the instructions to print and save for future reference too.
As you've forgotten/lost your master code, you'll need to use the restoring instructions to reset your lock to the factory default settings, so you can then reprogram new codes into your lock.
Basically, you'll need to open up the inside compartment and push the reset pin/button in order to clear all current code programs and then start over with inputing new codes, etc. Have your key with you, as you'll need it in case you accidently lock yourself out, while reprogramming the lockset.
http://consumer.schlage.com/customerservice/FE595_install_inst.asp
Hope you find this Very Helpful - Best regards!
Aug 12, 2009 | Schlage BE365-PLY BE365PLY626 Satin...
Locks & Locksmithing Logo
262 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
