Question about Sony Vaio PCG-9W1L PCG-9W7L PCG-9W8L (777093326323) AC Adapter
Sony PCG-9W1L powers on then shuts off before booting
I press the power button the computer turns on for a few seconds then I hear three beeps and it shuts down.
  • Sony Master
  • 27,725 Answers
The beeps are post during post the very first work is done by the ram all the memory in the ram is first transferred to the hard disk and remains active until turned off.
make sure that your RAM modules and Cmos battery sockets are clean and dust free and the ram modules are securely seated in some motherboards cmos batteries are soldered in
Test all leads that attach to your hard drive including electrical extensions
the leads from your ((motherboard to your hard drive)) SATA make sure they have a secure connection
and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
one bad lead will end with a computer error a computer needs its connections continue its cycle and have an end to function properly
even something as small as an electrical extension or a faulty fan lead can cause this problem computer needs all of the data and electrical current to travel through every device and to have an end to be able work properly
hope this helps you
Posted on Feb 14, 2012
PCV R44G, won't boot, no fans, won' turn on.
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 22, 2012 | Sony Computers & Internet
Sony pcg-grx52g/b not power ,when the power botton is press later it wil went off back and no more indicating charging.
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.
Apr 20, 2012 | Sony Computers & Internet
No light on Sony vaio pcg-981l
No light where?
Remove the Power Cord, Remove the Battery, Remove the cover that houses the memory then remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 16, 2012 | Sony Computers & Internet
How to start my computer wen iam not shut dow
Apr 01, 2012 | Compaq Computers & Internet
My sony vaio won't turn on
Mar 31, 2012 | Computers & Internet
Cq60-615dx power problem
Mar 31, 2012 | HEWLETT-PACKARD Compaq Presario CQ60-615DX...
My Sony pcg-9c1l won't turn on!! When I press the
Could be your adapter, adapter socket - most common issues.
AC ADAPTER CHARGER POWER FOR SONY VAIO PCG 9C1L PCG 9D1L VPCCW14FX... Test your power adapter with a multi-meter. Example below
Hope this works to help you and your situation.
Mar 11, 2012 | Sony Computers & Internet
My ps3 goes to boot up an then shuts down beeps three times shows a blue light then a quick yellow light then goes to blinkin red light
You could try pressing the power button and holding it down. You will hear the first beep when you press it but hold it down until it beeps a second time it will take 5 to 10 seconds. This will reset the console and it may boot up. If this does not work you can go to www.us.playstation.com and check the user knowledgebase and/or support for a solution.
Apr 04, 2011 | Sony Playstation 3 (PS3) Console
On ps3, when switched on, says hard drive corrupted, will restore. after a while trying to restore, same thing comes up again.
  • Turn off the PS3 console, if it isn't already.Press and hold the power button on the console as it powers on, and then powers off again.Press and hold the power button a second time until you hear two consecutive beeps. If your console powers down before you hear the second beep, try holding down the power button again. It should work during the second cycle.Connect your controller to the console with the USB cable when prompted to do so.Turn on the controller. You will now have access to the PS3 recovery menu.Select option three which states "Restore File System: Checks for corrupt/missing system files." This option will identify and correct and corrupt files. Your PS3 should now be fixed. If this option doesn't fix your problems, you'll want to do a complete system restore and follow the next step.Turn off the PS3 console by holding down the power button.Press and hold the power button on the console as it powers on, and then powers off again.Press and hold the power button a second time until you hear two consecutive beeps. If your console powers down before you hear the second beep, try holding down the power button again. It should work during the second cycle.Select option 5 which states "Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch." Be aware that performing a complete system restore will cause all data on the hard drive to be lost. This option restores the PS3 back to its original factory condition.
  • Dec 06, 2010 | Sony Playstation 3 (PS3) Console
    I turned on my playstation three, you can hear the audio but there is no picture. is this a known problem? is there a fix?
    try video reset
    when ps3 is in standby mode( red light) press and hold the power button till you hear a second beep
    ps3 standby...press hold power............"beep"......."beep" ......release power button.
    Sep 20, 2009 | Sony Playstation 3 (PS3) Console
    Sony Vaio PCG-9W1L PCG-9W7L PCG-9W8L (777093326323) AC Adapter Logo
    127 people viewed this question
    Top Sony Computers & Internet Experts
    Martin Murray
    Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
