Question about Schlage COBRA by Keyless Lock
Schlage cobra default code - Schlage COBRA by Keyless Lock
  • 963 Answers
There is no "factory default code". If there was such a thing, you could bet that any good thief would have it-rendering your lock useless as a security device.
Try Schlage.com for further information.
Posted on Feb 22, 2012
My schlage keypad will not do anything anymore i even tried new batteries has happened on all three of my locks
Probably need to be reset to factory default. Since it is all your locks you probably change all the batteries same time.
provided link to Schlage
http://www.schlage.com/en/home/contact-us.html
Oct 01, 2016 | Schlage Deadbolt. Century Satin Nickel...
Programming code will not work
I work for factorylocks.com. We get programing questions all the time for Schlage FE575/595. The factory default programming code and PIN codes are on a sticker stuck to the inside of the front housing of the lock. You will need to take the lock off of the door to see this sticker. Once you have done so, reset the lock back to the factory defaults and reprogram the locks to your settings using the programming instructions you can find here http://www.youtube.com/watch?v=z8BgHP712eg
Feb 03, 2013 | Schlage FE595 Plymouth Electronic Keypad...
Schlage keyless lock lost 6 digit code and no sticker inside either
You will need to take the keypad look off of your
door and record the 6 digit programming code and the two factory
default PIN codes. You then need to perform the factory reset to
erase any codes and restore the lock back to the factory defaults.
This procedure is outlined, as well as the programming of the device, in the attached instructions.
http://www.factorylocks.com/PDFs/Programming%20Instructions.pdf
Regards,
Leslie
Factorylocks.com
877-345-6257 (877-34-LOCKS)
Jan 13, 2013 | Schlage FE595 Plymouth Electronic Keypad...
What is the factory default code for a Schlage Cobra Lock
There is no '"factory default code". Sorry.
Try Schlage.com
Feb 13, 2012 | Locks & Locksmithing
My residential schlage cobra lock no longer locks. I have checked the batteries. Using the programming instructions, I cannot get a "normal' code to program. I always get flashing lights...
Since you seem to be doing everything properly and following the instructions, I recommend that you contact Schlage for some technical assistance. Here is the contact information:
Schlage Lock Company
Customer Service Department
2119 E Kansas City Rd
Olathe, KS 66061
United States Customer Support
Warranty & Technical Information: 1.888.805.9837
http://consumer.schlage.com/Service-Support/Pages/ContactUs.aspx
Schlage FAQ:
http://consumer.schlage.com/Service-Support/Pages/InstallationTroubleshooting.aspx
http://consumer.schlage.com/Service-Support/Pages/FAQ.aspx
Instructions & Manuals:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Aug 04, 2011 | Schlage COBRA by Keyless Lock
I can't put in the 6-digit PC to my new BE365 Schlage. When the lock is idle, I put in the 6-digit code and the lock thinks I'm putting in the 4-digit UC, so it errors out. My 2 default UC codes...
I don't have a direct answer, but here is the contact info you need for customer service:
Olathe, KS 66061
Schlage FAQ: http://consumer.schlage.com/Service-Support/Pages/InstallationTroubleshooting.aspx
Instructions & Manuals: http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
BE-365 installation & programming PDF: http://consumer.schlage.com/Project%20Documents/P515-858.pdf
Jun 03, 2011 | Schlage BE365-PLY BE365PLY626 Satin...
Schlage Cobra lock. The lock will not lock
Please re-post your question with more specific information about the problem.
Here is the contact info you need for customer service:
Olathe, KS 66061
Mar 18, 2011 | Schlage COBRA by Keyless Lock
I have spent over an hour looking for information on how to set a code for my Schlage BE365 CAM 619 keyless access deadbolt. I want a very SIMPLE explanation. Don't tell me to go to the Schlage web...
First make sure you have a fresh new battery installed
Next if you feel you have fiddled with it so much you can reset the lock to the factory default settings, to do this
1.Disconnect the Battery
2. Press and hold the Schlage Button while reconnecting the battery
However proceed before resulting to a reset and see if you are sucessful.
There are preprogrammed user codes already programmed into the unit
These two USER CODES (UC) are on the Yellow Sticker and on the Installation documents that came with the lock. Also the 6 Digit PROGRAMMING CODE (PC) is listed in the same location.
Assuming the lock was installed correctly and tested for correct operation.. proceed...
First.. I agree with you about the instructions.. many places they use the word "press" when they should have used the word "enter".. or phrase.. "enter the user code by pressing the corrosponding numbers".. however..
With the door open test the lock function
Press the Schlage button.. this should extend the bolt
Next Enter one of the two supplied preprogrammed user code (a) or (b) and rotate the thumbturn away from the door edge (generally to your left or counter clockwise) This should retract the bolt.
To Enter a New USER CODE (UC)
1.Enter the 6 Digit Programming Code (PC) via the key pad
2.The Schlage button will glow Orange
3.Press and release 1 on the keypad
4.Enter your new/desired 4 Digit USER CODE (UC) via the keypad
5.Enter the new/desired 4 Digit USER CODE (UC) via the keypad again (yes a second time)
The Schlage button should flash green.. signalling the program was sucessful
Repeat the lock function test using the new User Code (UC)
Make sure you write the new UC number down.
This lock will store up to 19 UC codes.
Good Luck!
Mar 11, 2011 | Schlage BE365-CAM BE365CAM619 Satin...
My Cobra MPC by schlage lock is locked. The wrong code was entered and now the led lights will not light up and the door will not unlock. How can i reset this?
Olathe, KS 66061
Dec 28, 2010 | Schlage Camelot Deadbolt Keypad, Satin...
Schlage COBRA by  Keyless Lock Logo
277 people viewed this question
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
ken skalski
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
