Question about Philips Televison & Video
42HFL5683L/F7 hotel unlock
HOW TO unlock at hotel
  • bennis256
    bennis256 Feb 13, 2012
    I should add what I am trying to do is to access the different inputs available on the tv so I can hook up my xbox. Any info would be a huge help. Thanks!
  • bennis256
    That is the model number of the Phillips tv in my room.
Unlock Philips model # 37HFL5581V/27
Hotel TVs use unique remote codes so guests will not steal the remotes. A universal remote is unlikely to contain the code.
Jul 27, 2016 | Philips Televison & Video
How can I take all the blocks off my hotel philips tv 42HFL5682D/F7?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Feb 28, 2016 | Philips Televison & Video
Bought TV / used to be in hotel - get no signal / how to I unlock hotel mode
Unlock procedure and to override the password lock to many popular brand TVs are given. Search the site by type in "Hotel mode" in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Dec 12, 2015 | Televison & Video
I have a Philips 42hfl5682l/f7 hospitality tv how do I get it out of hotel mode
You will need the RC2573GR remote. That is the "master" remote and needed to program TV.
Feb 13, 2015 | Philips Televison & Video
I believe you need a service remote to switch modes. I seem to remember it's called a green remote. You should be able to Google it, and I think it even comes with instructions.
I have a Philips television, Model # 32HFL56624/F7. How do I change it from a hotel mode to regular televison. I have the remote but it will not give me the menu section to change it back?
Usually hotel models are rewired so they will only show basic or pay channels. If you can get into main settings and you can do factory reset(which I doubt) that may work. I assume you bout this cheap or free, Old saying states "Buy cheap But twice".
Jul 21, 2014 | Philips Televison & Video
How can i unlick philips hotel tv 32hfl5662l/f7
How to switch your hotel Phillips 32HFL5662L/f7 to HDMI if you need to.
(I'm stuck in St Johns, Newfoundland, miles from the downtown....I must be bored)
1. You will need a serial DB9 M-F cable, your PC with a serial port and a terminal program like Hyper Terminal or Putty
2. Set your baud rate to 115200, n,8,1
3. Unplug the AC adaptor connecting the little smart box on the back of the TV. The TV may plug into this adaptor as well, so just plug the TV back into the wall. If you do not, the LCD TV will try to switch back to cable after you select HDMI.
4. Power on the LCD TV and you should see data on the PC screen in readable text.
5. You must send a carriage return after each command <cr> (the enter key on your PC)
6. Use only small letters (no caps)
i - info
u,d,l,r - Up, Down, Left, Right
p - PIP window toggle
To set to HDMI use the following sequence:
i <cr> (menu)
d <cr> (down)
d <cr> (down)
r <r> (right)
then use 'd' and 'r' to select the right input
Jun 13, 2012 | Philips Televison & Video
Akai TV - Stuck in Hotel Mode
M (menu) 7935 (regular menu appears), them press 4725 (menu service appears), then search HTLSRC (position 090), then set value 032 (this value disables Hotel Mode) - TV. Now Hotel Mode is deactivated. It is verified!
M 7935 4725, go to HTLSRC (090), fix 032 - press TV. Good luck!
Jul 28, 2009 | Akai Televison & Video
How can i unlock philips hotel tv 21ht3302/41?
hey pls help me.. I have this Tv and igit buttons 3,1,9,7,5,3
and the mute button was worked.
but recently
above code doesn't work,as i remeber I put high security in menu.but What can i do now,please help me.
please...
raveendramax@gmail.com
Aug 14, 2008 | Philips 20PT6441 20" TV
Televison & Video Logo
24 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
