Dell dvd bad CD OK
GWA41648 drive on Precision 380 running Windows XP SP3 thanks This is on a Dell PRecision 580 desktop, the DVD RW drives are model GWA41648 and I have several of these computers, recently purchased used, all with the same problem. The drive does not recognize the existence of DVD discs, there's no error message, it just doesn't do anything. In Windows Explorer the drive appears but there's no indication there's a disc in it. With CDs, however, it operates normally. I have more than one PC, thought drive was defective at first and tried swapping it, then the cable, then realized all of them have the same problem. Running Windows XP SP3. I checked Dell site for updated drivers, but for this model they say there's just an optional update that relates to the rescue disc, seems irrelevant to my problem. Any suggestions?. Thanks for any ideas, I'm going crazy!
  • Cliff Roth Feb 13, 2012
    This answer is an insult to my attention. Of course they are DVD drives! Additionally, keep in mind the problem spans multiple computers.
    Yes, the drive is being detected -- read the question! How could it play CDs if it wasn't being detected? the problem is it works for CDs only, not DVDs.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 52 Answers
Please check what type of dive it is cdrw/dvdr or only COD -rom...if only cd rom it will not read DVD's...go to run ...then type msinfo32 then components finally under check the type of CD/DVD drive installed...if everything is ok...reinstall the chipset drivers....thanks...also if u can check in BIOS if the drive is getting detected.
Posted on Feb 13, 2012
  • 205 Answers
SOURCE: Dell Precision 380
So the 80GB drive is an IDE drive, right?
Different manufacturer's have different BIOS' so I can't say with certainty what you'll see in yours, but on my ASUS motherboards I have a one of three settings:
PATA
SATA
PATA+SATA
When I run both IDE and SATA drives I need to use the third setting. I sounds like you're shutting off the PATA when you enable the SATA so there's no drive from which to boot.
If I misunderstand your problem please let me know.
Posted on Dec 22, 2007
RescueTechLA
  • 2653 Answers
SOURCE: Boot a Sony DVD RW DRU-840A drive in DELL precision 530
Have you tried changing the boot order.
If you're trying to use it as a boot device you need to tell the system to boot the cd /dvd drive FIRST and of course you need to have a bootable cd / dvd in the drive.
Let me know if you're already tried this.
Posted on Mar 04, 2009
dww0642
  • 79 Answers
SOURCE: Heatsink for Dell Precision T5400
Actually what you need is a Heatsink & Fan for a Intel "Xeon" Processor. I believe some of these came with dual core and quad core CPU's. So make sure as to EXACTLY what type processor you have and look for a heatsink for that.
Or, you can call Dell directly and purchase it from them. Dell sometimes uses Fan tunnels in there machines, instead of directly mounting the fan on the CPU.
I hope this info helps, please rate my solution. Have a great day!
Posted on May 19, 2009
  • 8 Answers
SOURCE: Dell Precision 380 won't boot
I had a similar situation with a work computer; the power supply always tested good. A wiser and more experienced computer guru ordered a new power supply. He gave it to me told me to install it, I did and was laughing the whole time. Well it in fact was the power supply. Reason, power supplies are funny like that, they may test good under ideal conditions which is a minimum load put on the unit (enough to boot your system). They are not tested with the stresses of maintaining all your fans, hard drives, mother board, video card, monitor, CD drives, mouse, and keyboard. Its when those loads are applied is when the unit either surges or it is faulty and cannot maintain. First try finding some way to test that suspected bad circuit. If that's not it I would try replacing the power supply, that MAY NOT be your problem but it is certainly CHEAPER than replacing your processor and/or mother board. You could also have a hard drive problem; most drives have self testing features that are partitioned separate from the rest of drive. You can also try plugging your drive into a good computer and see if it boots.
I'll warn you though issues such as yours can take you down a costly road trying to trouble shoot. The components you are thinking of replacing pretty much will give you a brand new computer.
Hope this helps
Posted on Aug 01, 2009
  • 10406 Answers
SOURCE: Take a 2-CPU Precision 670 down to 1-CPU
You probably removed the "primary" CPU,
and the computer cannot operate only with the "secondary" CPU installed.
Move the CPU from the "secondary" slot to the "primary" slot.
Posted on Jan 13, 2010
Testimonial: "Very courteous and helpful response. While it did not answer my question, I do appreciate the response and I shared my findings in additional comment."
Boot up problem with Dell Precision 380 P4 Dual Core 3 GHz
Your computer is trying to boot from a floppy drive. Do you even have one? If not, then you need to go into the BIOS (set-up) menu and disable it. Be careful though, you could loose all your data on the computer if you make a wrong selection. As for an array message, you must have have a RAID disk configuration. That means you have 2 or more disk drives that mirror each other.
Mar 17, 2013 | Dell Precision 380 P4 Dual Core 3 GHz...
Can I Play gta IV/4 on my pc? Specs Ar As Follow: DELL PRECISION 650 With: 2X Seprate Intel Xenon CPU's @ 2.40Ghz Each (4.80Ghz Tot) 1.50GB RAM (Memory) 80GB IDE Primary, 40Gb IDE Seccondary, 40GB...
it will run, but get more ram, your best ram is 2 gig ram to run the game, and all so do a game test on he video card to see if it will lag, there a GTA IV demo out there i belive so try that b4 buing a new ram
Jun 15, 2010 | Dell PRECISION 650
Minimum System Requirements
  • OS: Windows Vista - Service Pack 1 / XP - Service Pack 3
  • Processor: Intel Core 2 Duo 1.8Ghz, AMD Athlon X2 64 2.4Ghz
  • Memory: 1.5GB, 16GB Free Hard Drive Space
  • Video Card: 256MB NVIDIA 7900 / 256MB ATI X1900
Recommended System Requirements
  • Processor: Intel Core 2 Quad 2.4Ghz, AMD Phenom X3 2.1Ghz
  • Memory: 2 GB (Windows XP) 2.5 GB (Windows Vista)
  • 18 GB Free Hard Drive Space
  • Video Card: 512MB NVIDIA 8600 / 512MB ATI 3870
Source :- IGN PC
this is what it says on the box...so if you dont have these specs..forgett it!!
Jun 15, 2010 | Rockstar Games Grand Theft Auto™ IV for...
Will not read cd or dvd
This is a common problem when drives are installed or removed.
Please check your jumper settings if this is the case.
If not, you may want to replace the drive with a DVD/RW
Nov 24, 2009 | Dell Precision Workstation 670 PC Desktop
Dell 340 will not recognize my cd or dvd drive.
check if you see any light on the drive, if yes. then the power is there and then the problem is with the data cable of the cd drive. try to repalce the cd drive with another cd drive. if it still doesnot work and if the same cables work with the hard drive, then the cd drive has gone bad. and if the new drive also doesnot work then reinstalling the operating system should fix the problem only and only if it appears in the bios. if it doesnot appear in the bios. then the problem is not of the operating system. then its the motherboard.
Oct 13, 2009 | Dell Precision 340 PC Desktop
Mar 04, 2009 | Dell Precision 530MT (WHL530MTGHEI31LE) PC...
Dell Precision 490 constant reboot after ghost image completed
Hello-
I figured out how to ghost a Dell Precision 490 with a 32 bit Windows XP Image! Like you I had the same problem where it would constantly reboot after I imaged it with an existing 490 image. The answer is actually very simple. Boot up your Precision 490 and hit F2 to enter the bios. Select Drives and then SATA Operation, change it to "Raid Autodetect / ATA". Reboot the 490 and re image the machine, it will now work!
Dec 01, 2008 | Dell Precision Workstation 490 - MT -...
HL-DT-ST DVD-RW GWA-4082
ya it ll work... first change the cd to write mode ..hence not able to burn files...
Jun 21, 2008 | LG GWA-4082N DVD RW Dual Layer Burner
Computers & Internet Logo
David Payne
David Payne
