Question about Exercise & Fitness
Cylinder does not move - Exercise & Fitness
    Top Expert:
  • 12,223 Answers
Dear Sir:
If i can understand the cylinder does not Move, you mean the rollers.
You must run the calibration software coming with the equipment, see the instruction under the Hood motor and follow the steps or user manual.
This software is for diagnose and troubleshooting your treadmill.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Posted on Feb 15, 2012
07 explorer transmission started slipping got it home now it will barely move
before you race out and buy a clutch kit there are some checks to do first
this could be a problem clutch master cylinder where the compensating port is blocked and that keeps the pressure plate partially disengaged
so check that the clutch is properly by bleeding the nipple at the slave cylinder and seeing if that makes a difference
bleed out excessive pressure and move the lever towards the slave cylinder
press on the clutch and see if it can be moved back when the foot is off the pedal
if not it is the master cylinder
if cable read clutch cable instead of master cylinder as it is jamming up and not moving freely
Sep 03, 2016 | 2007 Ford Explorer
My friend had clutch replaced 6 mths oago and now clutch is not engaging is there anyway to check hydraulics without removing tranny?
Check clutch fluid level in clutch master cylinder for proper level. You can also watch the slave cylinder move at the transmission where it pushes on the clutch fork. The slave cylinder should move when the clutch pedal is depressed. If the cylinder does not move, suspect a defective master cylinder/slave cylinder/air in system that will require bleeding. If all moves, suspect tranny removal for inspection
Feb 22, 2016 | Cars & Trucks
I replaced spark plugs because of a misfire in cylinder 2 and it ran great no issues for two months now a misfire in cylinder 2 again what could be the cause?
Can be a failing coil pack if you can move the coil pack to a different cylinder and then see if the code changes if it moves to the cylinder you moved it to then replace the coil pack should take care of the issue
Oct 01, 2015 | 2007 Ford Focus 2.0
1997 nissan altima 5 speed manual transmission will not shift, is it the clutch, master cylinder or slave cylinder?
first check to see if you have any fluid in the clutch master cylinder which is mounted by the firewall on l/h side of car. if fluid is inthere, follow the line/hose to the transmission. this line/hose goes to slave cylinder mounted somewhat on the front/top of trans with 2 bolts. that is the slave. have someone push the clutch as you are watching the slave cylinder for operation. it should move with clutch beeing pressed. if it doesnt move than you have a hydraulic issue/leaking master cylinder. if it moved nicely, tha i would be looking at the clutch.
Oct 01, 2011 | 1997 Nissan.5 Altima
Clutch doesn't work properly. Master cylinder about 2/3 full, but when clutch is depressed the fluid does not move. Shouldn't the fluid level change when the clutch is used?
The fluid in the reservoir shouldn't be moving. Pushing the peddle should move the fluid
IN the master cylinder which then moves the slave cylinder. If the reservoir is going down then you have a leak somewhere. Sometimes leaks are contained by the rubber caps on master or slave
cylinder rods and you don't see the fluid unless u check behind the cap.
Feb 05, 2011 | Dodge Neon Cars & Trucks
Fireing pin moves very slow, it seems to have no power. It comes out slow, I have to push it back inside the gun. It was leaking out the back so I adjusted the cyclinder and now the piston moves too slow...
When you trip the safety and fire the gun, the cylinder drops down into body of gun allowing a rush of air to push piston down with force. If the cylinder fits too tightly in body, it will not open enough to allow full air pressure into cylinder. Remove head and check that the cylinder moves rather easily down then back up (it should travel about 1/4 inch). If is difficult to move the cylinder then remove it and replace all the orings that contact its surface. Also make sure that the outer part of the cylinder is smooth where orings contact. If there are fine scratches, remove them with 400 grit sandpaper. Lube cylinder/orings with silicone paste lube. While cylinder is removed check that lower bumper is in good shape with no missing pieces. For best performance, also replace the three orings on the feed piston. Piston /driver should move down cylinder with only slight pressure yet it should not drop down the cylinder under its own weight. Good luck
Jan 16, 2011 | Hitachi NV45AB2 Roofing Coil Nailer
I took apart and replaced all the seals on my hitachi roofing gun and now air leaks out of the back. what did i do wrong?
If orings fit too tight cylinder will not move against the headvalve seal (headvalve is the black rubber or vinyl seat in the head). To help the cylinder reset, bump the head against rubber matt. If the cylinder resets, good to go, if however the cylinder does not move into position, remove the head and check that cylinder moves up/down about 1/4 inch. If it does not move pull cylinder and use 400 grit sandpaper on cylinder where orings contact. Remove all scratches and reinstall. Good holidays
Dec 13, 2010 | Hitachi Tools & Hardware - Others
Misfire #4 p0304 engine is sluggish.rough idle at times
Check the coil, a good test is to change the coil with another cylinder and see if the misfire moves to that cylinder, if it moves then you will know its the coil make sure to mark it so you know which one to replace, this is very common for coils to go bad, heres a diagram to help you locate #4 cylinder.couldnt get diagram but if its a four cylinder then #4 is the last one back if its a 6 cylinder then it will be the first cylinder on the driverside .first cylinder from the front to rear,
Dec 12, 2010 | 2005 Ford Escape
As I try to fire the gun, I just get a small thump of air and no nail fires This gun is 2 years old and worked perfectly when I put it away last spring.
Problem you describe is typical of stuck driver or firing valve. Easy to check; remove head and make sure piston moves down cylinder (upon removing head, piston should be at top). Your gun utilizes sliding cylinder instead of moving valve in head. When you pull the trigger the cylinder moves down allowing air pressure to drive piston down. Orings swell overtime which prevents the cylinder from moving/firing. If cylinder does not move down/up, may be time for rebuild kit. Parts are available at dewalt service center or can be ordered from www.toolpartsdirect.com. Good luck
Aug 30, 2010 | Dewalt D51825 Heavy Duty 31 Degree Clipped...
Misfire in #7 cylinder. think i need to change the plugs. don't know how.
This is what I do when I have a miss on one cylinder with a coil-on-plug ignition system: Take the coil off of the suspect cylinder, and remove the plug. If you see no obvious problems with these 2 parts, swap each with another in a different cylinder, paying close attention to where you moved them to. For example: move #7 plug to #5, and #7 coil to #3. Now run the engine and see which cylinder has the misfire. If it moved to #3, you have a bad coil. If it moved to #5, the plug is bad - replace them all unless they are very new. To replacce the plugs, remove each coil and you can access the plug beneath with a standard spark plug socket and extension. Good luck!
Jun 28, 2009 | 2000 Ford Expedition
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
