Feature Comforts Electric Space Heater model HV-0513F NO HEAT ONLY FAN
Fan works but no heat comes out
SOURCE: RLP 30 portable heater
out of fuel
Posted on Jul 29, 2007
Buffalo12980
  • 625 Answers
SOURCE: reddy heat/scheu kerosene space heater no ignition
Typical kero heater uses either a spark ignition or a hot surface. The hot surface igniter is very fragile. A small bump may break the elements. Flame is detected by a photocell, signal is sent to the lockout relay board. Change the igniter costs about 50 bucks.
Posted on Nov 29, 2007
  • 3 Answers
SOURCE: electric furnace/heater pump/fan unit won't shut off
There are dip switches on the main board.. When you remove the lower panel on the air handler there are instructions to where the dip switches should be for your units fan control. if the switches are in the correct configuration.. The Thermostat may be malfunctioning or not wired properly. and last.. and most expensive.. the motherboard may also be failing.
Posted on Jan 12, 2009
SOURCE: space heater will power up, but not start,
These fans have a safey feature (sensor) that shuts the heater off if it is tipped over. It sounds like this component is not functioning correctly - may be set wrong and will not allow the heater to turn on unless you shake it to reset the sensor. If it is still under warranty return heater, if not call Patton and ask for help.
Posted on Mar 01, 2009
SOURCE: electric fireplace does not heat
I have a cheap electric fireplace bought in SuperCentre store-heater no longer works. It says its a one piece system. Can these heaters be replaced or repaired(probably made in China) or am i better off scrapping it and buying a new one?
Posted on Oct 18, 2009
I'm looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
Electric Heaters and Accessories - Grainger
www.grainger.com/.../electric-heaters-and.../heaters/.../N...
W. W. GraingerCount on Grainger to supply high-quality electric heaters and accessories for ...Electric Wall Mount Heaters ... Electric Space Heater,Fan Forced,120V, ... SearchQ&A ... This fuse is used on driers heater elements, I'm unable to locate these in .... in Ask and Answer are not intended to replace or supplement any professional, ...
DAYTON Electric Space Heater,Fan Forced,120V, - Portable ...
www.grainger.com/.../DAYTON-Electric-Space-Heater-...
W. W. GraingerShop DAYTON Electric Space Heater,Fan Forced,120V, (3VU33) at Grainger. ... Item # 3VU33; Mfr. Model # 3VU33; NSN # ... Country of Origin China Country of Origin is subject to change. ... Alternate Search Terms ... I need a replacement fan motor .... Where can I find parts for Dayton fan forced wall heater mod.5ZK54D.
Dayton Industrial Fan: Amazon.com
Dec 21, 2015 | Dayton Heating & Cooling
Fan doesn't work in heat mode it works on all other functions. Heat does come out but fan doesn't kick in. Outside unit is operating
AC inside fan doesn't come on AUTO - DoItYourself.com Community Forums
www.doityourself.com > ... > Air Conditioning and Cooling Systems
Jul 21, 2004 - The inside FAN doesn't run when in AUTO mode. If I leave ... Is the thermostat not working correctly or something in the AC unit causing it to do this? Thanx ... The unit is electric central air-conditioning(heat and cool). It made ... Carrier A/C condenser fan not working
Jul 27, 2012
Heater Fan Doesn't Work on AUTO
Jan 23, 2006
Blower doesn't work in ON position after repair
Mar 25, 2005
Central AC/Heat, Blower Doesn't work on Auto
Nov 30, 2004
More results from www.doityourself.com
Nov 01, 2015 | Heating & Cooling
My tata indica model 2010 radieter fan not working.or heater light take extra time
bad engine thermostat, seems/
heater light? are you saying the cab fan heater is poor heat.
or are you saying engine heat is slow to hit 180F+ ???????
the fan only comes on when you over heat engine.
or if A/C is on.
the fan electric on newer cars is controlled by the PCM
if the coolant never hits the programmed trip point, the fan never goes on. (bad thermostat or air in the cooling of engine block)
if coolant really is hitting say 220f, at idle or more, (fan test is in FSM read that page)
then the ECT may be fibbing. Scan it.
scan the PCM does the ECT read , true reality or not.
that is it.
May 04, 2014 | Cars & Trucks
Heater fan on electric fireplace not working, so heat shuts off and won't come back on. The manufacturer is Southern Enterprises, Inc., model no. FA515500TX.
Was having same problem, found the fan needed a little oil on bearings. Was not spinning up to full speed so heater was cylcing on high limit
Jan 21, 2013 | Southern Enterprises Luxembourg Ivory...
My feature comforts fan heater won't turn back on
Many plastic cased heaters are provided with a safety device (thermotemp) to protect it from over heating, especially fan operated type heaters. Once blown only a tecnician could replace it. You did not state what type of heater this is.
Jan 18, 2013 | Refrigerators
Blower motor not coming on for electric heater
Talk about a misnomer? Electric heat works way diff than gas heating. On electric heat multiple strips and a fan of course. But if they all come on at the same time then the breaker would trip so they use a sequencer for that job. Gas heat uses a bi-metal probe which twists around and turns the fan on when the temp reaches 110 in the plenum. Yall either have a bad fan or capacitor OR the thang that turns the fan on ain't doin it.
Nov 04, 2011 | Coleman Propane Forced Air Heater...
My heater isn't sending any heat .It seems like the fan isn't comming on
Most units heat comes on first. Does it get hot at all? may have over temp switch open and needs reset, after that check for fan operation. If fan does not come on it may lock out again. That would confirm bad blower motor.
Not sure if this unit needs this blower? Some space heaters it is an option.
Sep 07, 2011 | Dimplex Compact Electric Flame Stove...
Feature comforts tower fan need owners manual- cant access the blades to clean
I have a Feature Comforts Tower Fan that doesnt work? It has never worked
Jul 22, 2011 | Dryers
My fostoria spacer stop producing heat model 1520 3A. Smell a burn odor fan still works. Sounds different too. can you help? Dennis
Your electric space heater works by using a quartz infrared element, something that can eventually burn out due to use/defects. To fix your space heater, you will have to get another element specific to your model fostoria. While I did a quick search online, I could not find any matches to a replacement, but you can still call the company for one. Before calling, though, check to see if your heater is still under warranty, probably 1 to 2 years. The number for fostoria is 1-800-495-4525. Best of luck.
Mar 03, 2011 | Fostoria FES - 1520 - 3A Heat Wave Utility...
Electric furnace. Just replaced the controller board but no heat. The blower does come on when the thermostat gives the heat command and I was wondering if that means the relays to the furnace coils is...
On a Trane furnace the fan realy must energize before the electric strips will come on. On the thermastat. See if there is setting for electric heat. This will bring the fan on and the strips should come on. First just turn on your heat and and turn fan to on postion if it works you need to set tstat to electric heat mode. Most of the time there is sswitch in the back of the stat that says gas elec. Turn to electric. Rus
Oct 29, 2009 | Heating & Cooling
Heating & Cooling Logo
285 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
