Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Sub zero lights dont work - Sub-Zero 650 / O Bottom Freezer Refrigerator
  • 3 Answers
Try wiggling light switch side to side kinda hard, (the light switch is the one on the left) it should come on, showing you its a bad lt. switch.if that fails install 1 new 40watt,(long) appliance bulb. but it is going to be the switch or the bulb considering there wasn't any wiring work done on unit. part# for the light switch is 3060140 make sure the back of the switch is white not black (black is a fan switch) Good Luck !!!
Posted on Mar 04, 2012
I need to wire in a new freezer light for sub-zero 680 wires are just hanging
Refer to the wiring diagram located in service compartment.
Sep 12, 2014 | Sub-Zero 680 / F
SUb-Zero 650 fridge lighting issue
Just a bad door switch. Turn the unit off, remove the upper grill, then remove the cover over the switches. there are 2. 1 with a black backside, and one that is all white. you want to replace the all white one with a new all white one. it just has 2 wires, doesn't matter what order they go in. pull em off and pop that thing out, then snap the new one into place. all of this should be done with the power off and the door open. Good Luck!
Jan 03, 2014 | Sub-Zero 650 / O Bottom Freezer...
Lights all went out in refrigerator side of Sub Zero 632
I WILL BET THEY ARE DISCONNECTED !!!! CHECK FOR CONTINUITY AND SEE WHERE THE CONNECTION IS OUT.
Oct 13, 2012 | Sub-Zero 632 / S
The ice-cube maker on our Sub-Zero 611 has stopped...
i have a ice cube Machine (40 Cube) But he not working Properly
I dont know the Warring Daigrams in this Machine Athore Parts is Very well Conditions plz Solution My Probalms
i Need the Simple Wiring Digrams
Thanks & Regards
9816319449
Aug 05, 2012 | Sub-Zero Refrigerators
Side by side Sub Zero light switch works intermittently.
I had the same problem with my sub-zero and finally resolved it (much to my wife's delight) by just replacing it. R&R was a lot simpler than having to work on it every time my wife had a problem.
Dec 14, 2011 | Sub-Zero 690 Side by Side Refrigerator
We replaced all of the light bulbs in our 550 and the lights still do not work, any ideas?
Most likely light switch is bad. Could be light limit t-stat (prevents from overheating) and wiring problem too.
Sub-zero refrigerator repair in orange county, ca
Feb 06, 2010 | Sub-Zero Refrigerators
Sub-Zero 690 Side by Side Refrigerator light switch intermittent
This is a common problem - replace the left light switch with Sub Zero Part # 3060140.
Nov 25, 2009 | Sub-Zero 690 Side by Side Refrigerator
Light on refirgerator side doesn't come on unless I tap switch.
I had to take my switch apart and clean and lube it and it worked fine. Or just replace the switch. It may have gotten some sticky ketchup in it like mine did.
Sep 28, 2009 | Sub-Zero 690 Side by Side Refrigerator
Sub zero 550 refrigerator light not working
first try to tightin the bulb, it has a seal and it's hard to drive it home. otherwise it could be the door switch.
Dec 22, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
131 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
