Magellan Universal Ac Wall Power Supply for Roadmate 800
Problem for Magellan Universal Ac Wall Power Supply for Roadmate 800
Output voltage
By rcgibson on Oct 24, 2008
what should the output voltage be
Best Solution
posted on Nov 12, 2008
Helpful)
themoneypitt
Rank: Guru
Rating: 86%, 73 votes
Hello rcgibson, output of charger for (if this is correct 'Roadmate 800 GPS unit) AC wall power supply or 12/24 volt DC is 5 volt at 455 milliamp.
Was this helpful?
Yes
No
Popular Solutions for Magellan Universal Ac Wall
Questions and Unsolved Problems for Magellan Universal Ac Wall
Do you recommend Magellan Universal Ac Wall Power Supply for Roadmate 800?
Answer
Answer
1 have a mariner 15hp 2stroke manual outboard engine.can i wire it up to charge a 12v battery
Answer
I need the instructions on how to set the timer on the westinghouse outdoor digital power center .... (More)
Answer
how do you set the timer on a stanley automatic outdoor timer
Answer
I would like a instruction manual for your metal detector Bounty Hunter VLF-SPD rbs DISCRIMINATOR... (More)
Answer
it worked fine then we tried charging it and now it wont turn on
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Magellan Universal Ac Wall...:
Top Electric Power Supply Experts
Rank: Guru Guru
Solutions: 3922
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Electric Power Supply Experts
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
