Question about JVC Televison & Video
HOW TO CONNECT MY PC TO TV?
How do I connect my laptop to my HDTV? Thank you.
  • 807 Answers
You can do it with a standard vga lead providing your laptop and tv both have a 15 pin vga socket. It's like a D shape, usually blue or black. The lead has a fifteen pin plug on both ends. Like this one at Amazon
It's called a 15 pin but does'nt have all 15 pins.
Connect it up and select the correct source channel on you tv.
You may have to select external display on your laptop. Could be the Fn key and a key with a little screen on it, depending on the make and model of laptop, some are different.
Posted on Feb 14, 2012
bestdarngood
  • 3037 Answers
SOURCE: How do I connect my Laptop to my HDTV TV?
Depending on your laptop connections, they will decide what adapters you need. Just take the laptop to a Radio Shack or similar store and they can get you the right connections. You will need an adapter for the video and the audio separately most likely. My laptop, I use the headphone jack for audio and I have the two adapters connecting to an RGB jack. You also want to buy some extra RGB cables for more length between the laptop and tv. You may need some double ended female connectors for those too.
Then in order to get the tv to be a second screen, you need to go into your video driver. I use nvidia. You can access it from a right click on the desktop>properties>settings. Depending on your driver, you can extend the image on a second screen which is what I do or you can also have the same image on both screens.
Let me know if you have any other questions, and I would be glad to help you out.
Posted on May 23, 2008
  • 53 Answers
SOURCE: samsung hdtv switches off when i connect my laptop
check your laptop display resolution before hooking up the avg. the max res. is 1366x 768. at higher resolution the tv will just turn itself off..
please rate my comments :D
Posted on Mar 19, 2009
Blackberry_U
  • 223 Answers
SOURCE: Trying to connect my laptop to my lcd hdtv.
change it to VGA and put the audio in the mic jack on the laptop and in the audio in jack on the tv.
Posted on Jun 17, 2009
  • 105 Answers
SOURCE: i can not connect my rca dlp HDTV to my hp laptop.
A lot of TVs only accept limite PC resolutions. Try 1028x768 60hz this normally works.
The Error message doesn't mean the TV or PC is not working, only that the signal is not compatible. try all resolutions until something works.
Posted on Jun 23, 2009
  • 11800 Answers
SOURCE: how can i connect a pc to my hdtv and watch tv to
Use an S-Video cable and configure it in Control Panel / Display / Settings.
Posted on Jan 26, 2010
No signal when I hook my Dell XPS laptop to my Element HDTV
turn off tv and laptop. connect the hdmi cable to your tv and laptop turn tv on then log onto your laptop Both devices need to be off when connecting the hdmi cable
Apr 13, 2013 | Dell XPS Computers & Internet
Connect pc to hdtv
depending on your tv and laptop, you will need the appropriate chord to connect to your tv. hdmi or vgi chord.
Dec 17, 2012 | Computers & Internet
How do i connect my pc to my hdtv
It is quite possible the tv may have a VGA input in which case a standard VGA cable will allow you to connect the laptop to the tv. Otherwise you will need one of the following depending on what connections the tv has:
1. VGA to HDMI cable: http://www.amazon.com/Video-Cable-Black-Support-Necessary/dp/B002TUC64W/ref=sr_1_1?s=electronics&ie=UTF8&qid=1355697785&sr=1-1&keywords=vga+to+hdmi+cable
2. VGA to RGB cable: http://www.amazon.com/eForCity-Premium-Component-Cable-Black/dp/B0012SPNII/ref=sr_1_1?s=electronics&ie=UTF8&qid=1355697879&sr=1-1&keywords=vga+to+rgb+cable
If you do not have an HDMI input, you will also need to get an audio cable as well. Standard mini-stereo audio cables should allow you to connect the laptop to the tv.
How to connect Aspire 5630 to HD TV
If your TY has a PC VGA input then you can connect a 15pin DSub cable from the TV to the video (GA) port on your Acer laptop.
Oct 14, 2012 | Computers & Internet
How to connect my dell inspiron 1501 laptop to my hdtv. am using a vga cable with rca out, to connect to the tv. i have tried everything but none works. if this can work please sent me step by step...
1 - the cable you are trying to use will not work - the RCA inputs in your tv can't accept the signal coming from the VGA. To connect the laptop to a tv the tv must have an VGA input, nothing else will work.
2 - When you start the laptop with an external device (such as an external monitor or tv) attached and turned on, the image may appear on either the laptop's display or the external device.
Press to switch the video image between the display only, the external device only, or the display and the external device simultaneously.
Apr 27, 2011 | Dell Inspiron 1501 Notebook
Connect hp laptop to tv to watch Netflix downloaded movies
how do i hook up my hitachi tv to my hp laptop to get netflix?
Jul 23, 2010 | Hitachi 51F59 51" HDTV Projection...
Laptop connection to TV - Sound Problems HELP!
#Select the best HDTV package for PC and laptops to suit your needs. #Plug HDTV USB Stick into any USB port on your computer.
#Connect your Antenna cable, cable TV cable, or satellite cable to your HDTV USB stick.
#Install your TV tuner software.
Jan 14, 2010 | Sony VAIO (PCWA-A200)
Do i need to set my lap top to be able to watch tv.if so what ?
you can watch tv tuner its USB device for laptop allow to watch or install softwarefor more information refer to http://laptoplogic.com/resources/detail.php?id=46 you can getinformation about tv tuners
Nov 18, 2009 | Compaq Presario CQ60-220US PC Laptop
Samsung hdtv to compaq pc
There should be a setting within the comp. Is it connected to the comp monitor and the tv? Perhaps from the comp to the tv with the monitor from the comp as well? Well if so, you may need a certain setting within the comp. Check under (on xp) display properties, and then under the settings tab. Please rate!
Apr 28, 2009 | HP Compaq nx6110 PC Laptop
Want to warch movie on tv from laptop
Connect to TV is easiest. just remember to set to the AV channel that the computer will be hooked into in order to watch. Hope this helps.
Dec 31, 2008 | Compaq Presario Notebook
Televison & Video Logo
93 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
