Question about LG WM-3677HW Front Load Washer / Dryer
Lg tromm washer wm3677hw cd error - LG WM-3677HW Front Load Washer / Dryer
rickzilla
  • 706 Answers
SOURCE: LE Error Code on Tromm
http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf page 18 of this service manual elaborates on the LE error code and what to check.. Hope this helps you..
Regards
Posted on Sep 20, 2008
  • 8 Answers
SOURCE: LG TROMM CLOTHES WASHER - "LE" ERROR CODE
I tried a solution I found elsewhere - worked great. I had turned my drum enough to cause the display to turn on (a glitch in their program, I think), then I got the LE code on the next cycle.
Unplug for 10 minutes. Turn back on and press the Rinse & Spin button, then set Spin Speed to No Spin. Run this cycle, which should work fine. Afterwards, you should be able to run your machine as normal. If this doesn't work, replacing the Hall sensor would be the next step.
Posted on Feb 28, 2009
Karthik316
  • 187 Answers
SOURCE: Front bottom leak from my LG TROMM HE Washer
  • Hi
  • Try these:
  1. Inspect the water supply connections
  2. Inspect the drain hose
  3. Inspect the water pump
  4. Inspect outer tub for cracks or corrosion
  5. Inspect the tub seal
  6. Inspect the tub bearing
please rate my suggestion...
Posted on May 22, 2009
  • 5 Answers
SOURCE: LG Tromm washer WM2688HWM tE error code. Very easy
LG Tromm Washing machine te error. The manual says to call for service. Not much help there. The reason for the error is the thermistor circuit (resistive element that becomes less resistive as it increases in temperature). The thermistor acts as a heat sensor. In many cases, the error occurs because the wireing harness is too tight at the bottom of the drum and one of the wires in this circuit becomes disconnected with all of the movement of the drum (unbalanced load, normal cylcing etc).
1. Unplug the washing machine from the wall. The thermistor circuit is at line voltage (110 in the U.S.) and it will bite! So do this first before proceeding.
2. Move the washer out so you can get access to the back of it.
3. Remove the stainless panel (the one that is not painted, it is large (aprox. 16x18 inches). It is held in place by 4 phillips screws.
4. Locate the thermistor connection block near the bottom of the machine, at the center of the wash drum. It is the small white connector that has two wires running to it. One wire is dark blue, the other is light blue. Insure that neither wire has pulled out of the connector. If either of them have, repair the connector and provide enough extra wire ( aprox. 2") to provide cable relief.
5. If the cable connector and wires are ok, there are other solutions here that recommend either cleaning or replacing the thermistor.
Good luck to you.
Posted on Aug 04, 2009
SOURCE: lg wm3677hw combo washer drain pump repair question
You replace the whole drain pump. Pretty easy to do from the opening in the bottom by resting the unit on its back. (Make sure you drain the unit completely) You should be able to get the drain pump (pt #4681EA2001D) from http://www.encompassparts.com/lgconsumer/ for less than $50 + s&h.
Posted on Sep 06, 2009
I have LG ,Tromm washer machine front load have problem. Door is not closing completely .
The "dE" error code indicates that the LG Tromm washer's door has not been properly closed. Closing the door firmly usually clears this error. If the error does not go away once the doors closed, a service technician should be consulted.
Jun 03, 2011 | LG WM-2277HW Front Load Washer
LG WM3677HW all in one washer dryer water not draining and have cleaned out drain filter. what now?
i had the same problem turns out it was a pressure sensor. as water fills it the tub air gets pushed into this sensor to fill to the appropriate level or to drain.
Feb 23, 2011 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Where does the lin tgo on my LG TROMM Model WM3677WH
Per the LG web site, the combo units are self cleaning. The trapped lint is washed out of the system automatically.
You should pay attention to the "cleaning" instructions for this unit. It is important to keep excessive soap buildup cleared out. Also be sure to use the correct soap - special, low suds.
Oct 11, 2009 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Lg wm3677hw combo washer drain pump repair question
Aug 31, 2009 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Washer-dryer # wm3677HW will not dry,heats up, run, on and on
You're a moron. This unit washes and dries. That's the whole point of it. Perhaps you should do some research before answering the question. the most likely cause is the water lever sensor.
Aug 09, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG washing machine problem.
LE is a locked motor error
make sure that all your connections are secured
Dec 29, 2008 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
LG WM-3677HW Front Load Washer / Dryer Logo
64 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
