PHILIPS 42PFL3403D/F7 WONT TURN ON - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 74,377 Answers
Hello
If there is no power light lights at its front panel, when you switch ON the Tv, the power regulator baord should be suspected. There is protection fuse with it. Check it first. if ithas blown up, be sure that there sis something wrong with it. Never insert an other fuse, till the fault has been rectifed. Get help fro anu experienced service technician.
Posted on Feb 13, 2012
Philips 42PFL3704D/F7. Why does it keep restarting?
Philips 42pfl3704d/f7 power reset when HDMI, USB, or cable ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Oct 9, 2012 - 5 posts - ‎2 authors
Philips 42pfl3704d/f7 power reset when HDMI, USB, or cable attached ... or Cable TV to unit the power resets, philips screen comes on and keeps on resetting. ... I tried a cable to the tv without the box and I do get picture.
Philips 42PFL3704D/F7 42-Inch 1080p LCD HDTV
www.amazon.com/Philips-42PFL3704D-F7.../B001LP...
Amazon.com, Inc.
Rating: 3.3 - ‎50 reviews
Amazon.com: Philips 42PFL3704D/F7 42-Inch 1080p LCD HDTV: Electronics. ... Will do all I can to prevent others from getting ripped off by Philips. ... came up every few weeks and would take an hour or so of reset before working properly.
Visit the support page for your Philips LCD TV 42PFL3704D ...
www.philips.ca > philips > Televisions > 3000 series
PhilipsFind support for your LCD TV 42PFL3704D/F7. ... How do I output sound from myPhilips TV to external audio devices such as Home Theaters, Soundbars, AV ...
42" Philips 42PFL3704D/F7 LCD TV WON'T COME ON - A
Dec 29, 2015 | Televison & Video
How to fix 40pfl4908/f7 will not turn on
My philips tv no 40pfl4908/f7 has a white flashing light and the tv does not turn on
Mar 15, 2014 | Philips 40PFL4908/F7 - 40 LED 1080p HDTV...
Picture is only black and white
Check its main board. Chroma section should be troubles-hooted. Contact any service technician. This is not a user repairable fault, especially to Philips Brand.
Oct 07, 2013 | Philips 42PFL3403D/27 42 in. LCD TV
Need to find out a part # for my philips 52PFL7403/f7 for the ir sensor
Join Date: Nov 2011 I have a Philips 47PFL3603D/F7 with the same problem. It was the IR sensor board causing the problem. You can search online to find the board, which almost everyone will most likely not have in stock, and cant be ordered. The part you need is this: 313926859181 IR Remote Sensor.
Models it will fit are as follows: Substitute Parts 313926859182
Known Models
MAGNAVOX 42MF438B/27
MAGNAVOX 42MF438B/F7
MAGNAVOX 52MF438B/27
MAGNAVOX 52MF438B/F7
PHILIPS 32PFL3403D/85
PHILIPS 42PFL3403D/27
PHILIPS 42PFL3603D/27
PHILIPS 42PFL3603D/F7
PHILIPS 47PFL3603D/27
PHILIPS 47PFL3603D/F7
PHILIPS 52PFL3603D/27
PHILIPS 52PFL3603D/F7
If you can find the board, great! A replacement board costs about $12.00. If you can't... we'll there is something you can try ; )
Either way, if you know it's the board, what's the harm in trying?
Remove the back from the TV. You can actually leave it on your stand to do this if you can spin it around to gain access to the back of it. Be sure to unplug everything first!!!
Looking at the back of the tv, the board will be located in the lower left side by the speaker. It will have 2 cables attached to it. Remove them, and take out the screw or two that holds it in place. There will be a plastic tab that keeps it in place also.
Take your fingernail and bend the tab back, and the board should come free. After that you should be holding the board in your hands. The side of the board with the connectors on it is the side you want to manipulate. There will be a tiny surface mounted capacitor beside one of the wire connection sockets. Take a utility knife and scrape it off/ you could use a soldering iron but it should come off very easy with a knife.
Plug it back in, and give it a try! If it works... great! If not, find a replacement board, and try that.
May 30, 2011 | Philips 52PFL7403D 52 in. LCD HDTV
I have a 22" Philips # 22PFL3504D/F7 The little red light no longer lites up, and it wont turn on with or wothout the remote, I changed the fuse inside , still nothing, its only 8 months of usage
Call the Phillips customer service department for warrenty repair service.The power supply board is dead.The warrenty still in effct until a year.
Jul 02, 2010 | Philips 22PFL3504D 22 in. LCD HDTV
Home Theater philips HTS3372D/F7 change for regio Free
Turn on the player
With the tray open press:
99990 on the remote
Region 0 will appear on the bottom left of the screen ]
from http://www.videohelp.com/dvdhacks
Mar 20, 2010 | Philips Audio Players & Recorders
My tv is actually a 42pfl3603d/f7 , had it for one year, the picture is green, but i can hear sound. what could be the problem?
Ur Tuner signal board is dead.Replaced this board will solved this problems.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Mar 13, 2010 | Philips 42PFL3403D 42 in. LCD HDTV
Green screen
Are you using HDMI to view your cable box? If you are, then the problem is firmware related. If you have access to the firmware to the television, then update. Try swapping the cable box.
If all else fails, then use component wires.
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
Electro Med Services...
