Question about AEG B5741-4 Electric Single Oven
Pyrolytic cleaning does not work.code C1 comes up.shelf rails have been removed
Oven lamp also lights and it should not.resetting all by turning mains off and on does not fix it
2 Suggested Answers
SOURCE: pyrolytic cleaning fault
fixed very simply just turned off oven at mains turned back on and it worked perfectly!!!!!!!!
Posted on Aug 20, 2008
How do I clean the electrolux oven? It won't start after i take the racks out
As you did not specify the exact model I assume that this is a self-cleaning oven, in other words with pyrolytic cleaning. It has a microswitch which is activated by removing the racks and just because that you can not run the pyrolytic cleaning otherwise racks would be destroyed. Do not forget that the temperature during pyrolytic cleaning is app. 500 degrees Celsius. For that reasons the oven door is locked when temperature increasing to app. 300 degrees and unlocked when the temperature decreasing to the app. 200 degrees. It is clear that when you remove the racks only program that you can run is pyrolytic cleaning.
Dado
Oct 10, 2014 | Electrolux ICON Designer E30SO75ESS Oven
Tip
If the door is locked shut after self cleaning
- Let the over cool down - unplug at the mains and leave it unplugged for a good minute or so - reset the clock The door may well open now. It happened to me today !
on Aug 13, 2007 | Neff B1476 Pyrolytic Stainless Steel...
Mile Pyrolytic Oven got a PY flashing
Mine is doing this too. Did you find a solution?
Apr 05, 2012 | Miele Ovens
Gaggenau EB944-110 Pyrolytic oven stuck in some kind of mode after power outage. Oven worked perfectly but there was a mains cut. After restoring power it appears to be stuck in some kind of strange...
Yes this could be the problem. If you can't set the timer to manual mode the oven will not work. Turn the oven to on so that when power goes to it you will see the oven indicator light come on. Play with the timer buttons until the oven indicator light comes on. If it won't work you probably need a new timer.
Feb 11, 2011 | Ovens
Pyrolytic cleaning won't start. Neff B15P42.0 GB
you have to remove the shelf supports (left and right) as well as the shelves. The manual tells you about the shelves but not the supports. I only found out as someone wrote the answer on another website
Sep 10, 2009 | Neff B1476 Pyrolytic Stainless Steel...
Neff B4562 Pyrolytic Cleaning Not Working
You need to remove the rack side supports too. Its not clear in the book as it just says shelves and racks but everything needs to come out the oven.
May 01, 2009 | Neff B1476 Pyrolytic Stainless Steel...
MIELE H 4641 PYROLYTIC OVEN
I HAVE THE SAME PROBLEM. KEEP HAVING TO TURN IT ON AND OFF TO USE IT.
Dec 26, 2008 | Miele DG 4080 Stainless Steel Electric...
Smeg oven not working
You have a element and or a faulty thermostat
Nov 25, 2008 | Smeg F170 Pyrolytic Stainless Steel...
Pyrolytic cleaning fault
Aug 18, 2008 | AEG B5741-4 Electric Single Oven
FAULTY TIMER/CLOCK
I found mine did the same I pusshed the face and it came back on. It appears fault within circuitry of clock and will need to be replaced
Dec 14, 2006 | Smeg F170 Pyrolytic Stainless Steel...
AEG B5741-4 Electric Single Oven Logo
80 people viewed this question
Top AEG Ovens Experts
ashburton
Sal DeAngelo
Steve
Are you an AEG Oven Expert? Answer questions, earn points and help others
