Question about NEC SD-V2-5U (SDV25U) Serial Adapter
PCI to USB 2.0 doesn't work
I installed the Syba SD-V2-5U PCI to USB 2.0 card on my computer and only USB 1.1 works. I installed the correct drivers and tried many different things such as disabling the windows drivers and only installing the drivers for the card. I have moved the card to different PCI slots, only to have the same results. The card works because everything I plug in works, its just really slow. Thanks you for the help!
  • ramprat101 Apr 06, 2008
    I also have the some problem with my dell dimenison l600c.
    O.S is windows XP.
    Does anyone have an idea on how to fix this
  • COatver May 13, 2009
    I have the same problem with the card installed in a HP-520w. However, I noticed that the onboard USB ports are only running at USB v1.x as well and continue to do so even now that I've removed the board. I suspect a BIOS problem with my computer that is affecting both.
2 Suggested Answers
SOURCE:
SOURCE: XP won't boot with NEC SD-V2-5U USB card installed
Have you tried moving the card to a different slot? The motherboard BIOS and/or the operating system may be trying to assign an interrupt that cannot be shared--especially if you have the card installed in the slot next to the video card (or shared with the onboard video).
Posted on Nov 07, 2007
(dual boot system)will not read a card reader in vista 32bit, but works fine in windows 7 64bit. Loaded drivers in Vista
Try driver download from her http://www.startech.com/Cards-Adapters/USB-3.0/Cards/2-Port-PCI-SuperSpeed-USB-3-Adapter-Card-with-SATA-Power~PCIUSB3S22
Although I dont understand your statement " will not read a card reader" since you state a problem with the Syba Infozone cable.
Is the problen your USB 3 port or the Syba cable.
Mar 29, 2014 | BestPriceCables Syba InfoZone SuperSpeed...
Need win 7 drivers for SD SIL680-Raid card
try the vista driver it should work ok
32 bit driver is here http://it.us.syba.com/bin/silicon_image/sil680/SD-ATA133I-VISTA-32bit.zip
64 bit driver is here http://it.us.syba.com/bin/silicon_image/sil680/SD-ATA133I-VISTA-64bit.zip
if you found this useful please vote for me
Apr 22, 2011 | SYBA SD-SIL680-RAID Ultra ATA 100/133 IDE...
In my system real tek ac 97 is not working
Go for set up the Bios again.
Set enable onboard audio for *********** board.
Now Install the driver again.
For set up bios follow the bellow link.
Phoenix BIOS setup and help
http://www.computerhope.com/help/ami.htm#01
BIOS - The setup program used in desktop and laptop computers/PCs - Page 1 of 2
If the problem is same
Install usb audio .
http://www.amazon.com/Syba-SD-CM-UAUD-Adapter-C-Media-Chipset/dp/B001MSS6CS/ref=sr_1_1?ie=UTF8&qid=1298800911&sr=8-1
Hope this helps.
Feb 27, 2011 | Computers & Internet
Have an SYBA PCI IDE RAIDx2 and very urgent need the driver for Windos 7 Ultimate x64. The VIA site is out of service..!!
hi I found this link below for all syba driver updates and downloads, hope this helps.
http://it.us.syba.com/support_download/download/index.html
Feb 13, 2011 | SYBA SD-SIL680-RAID Ultra ATA 100/133 IDE...
SunTech(SYBA) USB2.0 4+1 Ports PCI Card (NEC)
hi,
Kindly find the mother board manufacture and visit the site and download latest drivers and if your running xp kindly update with SP3 pack.
Jun 15, 2010 | E-Machines eMachines Desktop PC
I installed this card and still have no USB 2.0. I think I need a driver. XP did find the card and installed it. It works, just not high speed.
Speed depends not only on USB adapter but also on the device you plug in. In general, if you can copy to thumbdrive at 5Mbytes/sec than it's USB 2.0
Jun 03, 2010 | SYBA SD-VIA-5U Serial Adapter
Usb 2 card is only working at low speed after reinstalling windows xp. How can I get it to go to high speed? NEC 4 Port USB 2.0 PCI Controller Card
Make sure that you have the proper driver installed for your USB interface. Your motherboard should have come with a CD, or you can go to the motherboard manufacturers website and download the latest chipset drivers.
Once they are downloaded, install them and re-start your PC. Windows XP will then recognize a whole set of new components and allow your card to run at higher speeds.
You are looking for the PCI Bridge driver in particular, but I would recommend installing ALL the drivers that are available from the motherboard manufacturer.
Jan 22, 2010 | SYBA (SD-NECU2-3E1I) (SD-NECU2-3E1I) USB...
System freeze
The issue was resolved by uninstalling SP3. I uninstalled SP3 and the USB PCI card and rebooted. When SP2 reinstalled the device it installed the corect driver (5.1.2600.2180) and everything is now functional. Have no idea why the correct driver was not in XP SP3.
Jan 24, 2009 | SYBA (SD-NECU2-3E1I) (SD-NECU2-3E1I) USB...
USB PORT 2.0 INSTALL
what OS,? was it internet connected during all that? it must.
If XP its now a dead OS, for 3 years, , hp nor microsoft support
XP nor does HP support old SR1430nx.(now)
you installed PCI card ,called USB, no name stated or part number
use the drivers from THEM< the maker of the card.
there are always extra cables, most are power supply cables. in DT.
A tech would look and instantly see where they go and there purpose, explaining that is long long story.
my guess is the quesiton is formed backwards. lite me guess
Running XP "need some 8gb/mp4 player working."
this is the title deal but what is it? is it an external box tghat plays, DVD or is it just a software player. name that it is more clearly, even photos work 1000x best.
you find out XP does do USB well, , sure it does it horribly
XP does not support all USB devices, (some sure) but many not.
and must have SP3 installed, good luck finding that on dead OS
and not get infected with virus, XP is a Virus Magnet.
Getting XP up on new USB devices is a chore, no/?
why not ask the maker of both the mp4 player if it supports
XP. and then ask the card maker USB if it supports XP'
sr1430 (circa 2005?) 12years old, 2 past HP support.
Pentium 4.
what make s you think, this old pc with 512mb memory and slow pc and slow video are up to the large demands of videos movies.
it's not.
the front of the case (reading old review from2005)
shows a USB 2 port.
and that is wires there that go to the motherboard, USB2 jack.
if unplugged this wire USB2 there will be dead.
the mother board has a USB chip, and port.
but needs drivers you dont have, from HP that are no longer
offered.
how to cure that, you add a new PCI card, from a maker that supports
XP, , but who does that now in 2017.
hummmmmm
"Syba SD-VIA-2UH"
here is one with the VIA chip set for USB
note how it says box has PCI card, and CD driver.
with XP accept no cards, lacking DRIVERS.
https://www.newegg.com/Product/Product.aspx?Item=N82E16815124047&cm_re=usb_pci-_-15-124-047-_-Product
Apr 21, 2017 | HP Compaq Presario SR1430NX (PS566AA) PC...
Software for SD-CB5271B-4E6I
Hello Mr. Joe, Your drivers are here: http://www.syba.com/bin/ali/m5632/m5632_drv_util_v1.20s_multi.zip Please let us know if you need any additional information. Best regards, nightdiver
Oct 06, 2006 | Generic Memory PCI USB and Firewire Combo...
NEC SD-V2-5U (SDV25U) Serial Adapter Logo
65 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Thomas F. Schneider
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
