Question about Daewoo FRSU20IC (21.8 cu. ft.) Side by Side Refrigerator
Daewoo frs-U2OIC top shelf freezer not freezing
The top shelf in our freezer is not freezing.
  • 16 Answers
Could be the internal fan at the top of the compartment or its electrical feed is not working. With the door open, hold the light switch in (the fan usually doesn't work when the door is open) and see if it is spinning. If not, it and its connections should be checked
Posted on Jan 22, 2014
4 Suggested Answers
SOURCE: my side by side frige
If the lights are on but the machine is not working, then you need to check for the temperature control. If it is off, turn it on. If not, then you need to check the compressor for overheating. You need to unplug the refrigerator and clean the condenser coils. If the compressor is bad, then you need to call the repair man. You need to check the temperature settings and see if there is enough air flow in the refrigerator and freezer. You need to check for air flow restrictions in the vents and clean the compressor coils. The door seals, door switch, defrost heater and timer has to be checked. Also clean the clogged drain tube and refrigerant leak.
Posted on Oct 17, 2010
SOURCE: Daewoo FRS U20 DAi side by side f/f fridge
MIne has the same problem, the insulation is breaking down and cannot be repaired.
Posted on Jan 14, 2011
  • 132 Answers
SOURCE: Hi, During the recent Brisbane
You poor fridge has developed a refrigerant leak.
While the fridge was working before the flood the refrigerant was cold and din't escape. While it was off the metal expanded, opened up the leak and let most of the refrigerant escape.
You will need an ARCTICK approved appliance repairer to fix that problem.
http://www.lookforthetick.com.au/business-search/
Posted on Mar 25, 2011
Testimonial: "Wow! Thanks! First time I have used this site and am very pleasantly surprised by the rapid and professional reply!"
My daewoo fridge freezer is freezing food I the fridge on every shelf
Turn down the cold control there can be 1 or 2 if 2 one is main electronic the other just a baffle that controls how much cold air in freezer is allowed into fridge that is be pushed by the fan located in freezer. Cold is only made in freezer then does a circular tour as it leaves cold in freezer moves top 2 bottom then as its warmed it enters freezer to do it all over again . Adjust baffle and or control in this unit it may show 0 or off but there seems to be a lot of movement available before it does turn fridge off. Ive had on a few occasions had how the shelf's are arranged deflect the or mess with the cold airs intended route.
Mar 16, 2017 | Daewoo Refrigerators
Ice maker problem daewoo frs-2031 IAL
I wouldn't buy a Daewoo fridge with Donald Trump's money!
Jun 27, 2016 | Daewoo Freezers
Why isnt the top part of my Daewoo FRS-U20BG larder fridge/freezer working although rest of freezer seems ok?
Is it just the freezer section? Open the freezer door for a minute and then, without shutting it, press the button on the inside that makes the light go out. The fan at the back at the top of the freezer should start whirring. This circulates the freezing air. If it doesn't start then that's your problem as the freezing air isn't getting to the top of the freezer. It's simple enough to replace. Buy a new part (30 pounds?) and replace from the inside by removing the back panels to the freezer. Turn the freezer off and unplug first though, obviously! Hope this helps.
Jun 16, 2014 | Daewoo FRSU20IA Freezer
Daewoo frs-u20dai service manual
my Daewoo side by side fridge freezer FRS-U2ODAI keeps leeking water from underneath and it says on screen DEODORIZER and FUZZY can u help
Apr 03, 2012 | Refrigerators
Daewoo frsu201 a1 not freezing food on top shelf of freezer
Check that the internal fan is spinning by holding the light switch in with the door open. If not, it may need replacing but it could also be stuck/frozen defrost cycle, broken connections or circuit board or just a broken fan
Oct 13, 2011 | Daewoo Refrigerators
Just bought DAEWOO FRS-U20DC,cannot get ice maker
how do i suse my model 230 gps
Aug 27, 2009 | Freezers
Daewoo FRSU20IC (21.8 cu. ft.) Side by Side Refrigerator Logo
303 people viewed this question
Top Daewoo Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
jasbo
jasbo
Are you a Daewoo Refrigerator Expert? Answer questions, earn points and help others
