posted by slongan on Aug 12, 2006
The picture on my TV is coming in wierd. It isn't centered and cuts the top 1/4 of the picture off. The result is that I watch TV with everyone's head cut off.
2 Other Users Have The Same Problem
Comment by Guest, posted on Jul 19, 2008
the picture is cut off at the bottom by 1/4 in My Toshiba portable TV.
I have got universal remote control - Philips- but it does not work with the TV.
this is a proble of mode but I do not know how to change it.
There is not many buttons on TV just volume control and channel change.
THanks for reading and helping.
Kristof
Comment by Dahlee, posted on Nov 13, 2007
Had HD TV power source supply repaired for $350; picture looks too big for screen; tops of heads and words are cut off at the top and bottom.
Solution #1
posted on Aug 12, 2006
Your problem sounds like it could be a vertical sweep fault. Sounds like a vertical output IC or a capcitor in the sweep power supply or a waveshaper capacitor. All these faults, should only be checked and replaced by a pro tech, as there is a safety issue involved with the High voltage, and your going to need to know how to use the equipment to check these parts as in this case , you most likly wont be able to look and see whats wrong or what part is defective. Good Luck
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for GE 46GW 948 46 in. Rear Projection
Email this problem
Email this problem
Can you Help with these Projection Televisions problems?
GE 46GW 948 46 in. Rear Projection Television
no picture or sound
no picture or sound
The set turns on, but no... Answer This...
projection tv
projection tv
am in need of a manual for my... Answer This...
cannot change to video...
can u change to video functions... Answer This...
clicking noise
clicking noise
clicking noise 4 times when i... Answer This...
Repair Service
Find Projection TV Repairman Near You:
Find Parts
